11 messages2007-04-26 18:26 through 2007-05-06 13:52
Replacing Conventional Lights with LED--Issues?
Travis2007-04-26 18:26
I am thinking about replacing some of the lighting in my Cal 33-2 with
LED lights. I've seen some posts on LEDs and I have the impression
that it may be not just as simple as replacing the fixtures/bulbs with
LEDs. Can anyone help with this? Can I simply buy a LED fixture and
wire it up?
Travis Porter
CAL 33-2 HIN 64
Recently renamed "Vital" after my brother's
former ship USS VITAL MSO 474
RE: [Cal_Boats] Replacing Conventional Lights with LED--Issues?
Husar, Charlie2007-04-26 18:34 UTC
Travis, the LED lamps are built for the 12 volt service. The only
kicker is polarity. Standard lamps can hook up either way (depending on
possible case ground), but LEDs must have + to +.
Behalf Of Travis
Sent: Thursday, April 26, 2007 2:26 PM
Subject: [Cal_Boats] Replacing Conventional Lights with LED--Issues?
LED lights. I've seen some posts on LEDs and I have the impression that
it may be not just as simple as replacing the fixtures/bulbs with LEDs.
Can anyone help with this? Can I simply buy a LED fixture and wire it
up?
Travis Porter
CAL 33-2 HIN 64
Recently renamed "Vital" after my brother's former ship USS VITAL MSO
474
Yahoo! Groups Links
RE: [Cal_Boats] Replacing Conventional Lights with LED--Issues (Charlie, Travis)?
Elwers, George A.2007-04-26 20:51 UTC
I just replaced the bow running lights on Hana (Cal 40) with Hella 2 mile fixtures. They can be made to fit in the recesses built into the bow, which is why I chose them. They've only been in for a week now, but I'm impressed with the brightness and vertical beam pattern. They came with short leads and a very cheesy mounting device, but those can be worked around.
From: sentto-16485695-1148-1177612568-george.a.elwers=sa… [at] returns.groups.yahoo.com on behalf of Husar, Charlie
Sent: Thu 4/26/2007 11:34 AM
Subject: RE: [Cal_Boats] Replacing Conventional Lights with LED--Issues?
From: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com> [mailto:Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com> ] On
Behalf Of Travis
To: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>
up?
Travis Porter
CAL 33-2 HIN 64
Re: [Cal_Boats] Replacing Conventional Lights with LED--Issues?
Chris Campbell2007-04-26 20:52 UTC
> wire it up?
Travis:
Practical Sailor has addressed this question at some length. I don't
have the copies here at my office. You may want to go to their web site
and se if you can acquire the articles.
Re: Replacing Conventional running Lights with LED--Issues ( the Group)
slickbutfoxbuger2007-04-26 23:34
Greetings, Folks........
i don't mean to be the wet-mop around here. but where it
comes to a Ships/boat's navigational lights; i have a really big
problem with "leds".
that problem is called "Raw Candle Power"!!!
i know that as kids, most of you probably thought nothing of
riding your bicycles all over the towns and city's that you lived in.
and when you got old enough, you most probably though nothing of
riding those same bikes around after dark. after all, you had no
difficulty seeing the cars and trucks; you were young and had the
best of eye's, Right!
and then you got older and started driving some of those cars
and trucks. and damned if you didn't start noticing just how bloody
hard it is to see the kids out riding on their bicycles after dark.
and then you knew, didn't you........
well, i have been in the wheel-house of tugs as big as 100' at
night. and i have been responsible and in the conning town of 10,000
ton military vessels. and some other stuff in between. and i just
have-to be blunt here;
do you want to know what all your cheesey little minimum
required USCG approved 2 mile nav lights look like at the best of
times out in that inky blackness? all of you with boats made of the
stealthiest of non-reflective EM "Plastic" material. and most large
ships using a combination of "X" and "Y" band radar. the "X" band
mounted do high that you can easily be under it's scaning height and
they and you would not know it. and the "Y" band will never even see
you period.
well, those little lights that you are so proud of might as
well be pained red and green. they are hard to keep track of and even
notice at the best of times. and then there is the back-ground light
coming from ones own ship. have you ever noticed those big ships run
dark, how about the big fishing boats? no, they have thousands of
watt's of lights glaring on deck. and i sure as hope that you see
them, as it's been this navigators experience that we most often
times don't see you. or even worse; you will see us and mossy on over
and get right up under our rail to look at the big boat and then we
can't help be see you as you pass out of sight under your sheer.
<Deep Sight.....>
so, hears the point from someone whos been there.
BB-54 is going to meet the USCG requirements for
ships/boat's 65' and longer. and do so with "incandescent" bulbs. she
will have a independent battery for this alone. and we will carry the
little "Honda" portable 900 watt gen as a back-up. it's cheep and
quite and the safest possible of all solutions. and when one factors
in the damn cost of those fracking leds; a $600 Honda gen is
frankly "Cheap". and i can use the gen for other stuff too. can you
take your leds home or camping with your........?
remember, safety at sea is not being penny wise while being
pound foolish.......?
fiver,
Master of The "BB-54"
one of the famous Cal-28 flush-decks
out of Sierra-5, Papa Hotel (in days gone by)
now resting outside my shop
Federal Way, Wa.
(built like a Battleship; sails like a Sub......)
--- In Ca… [at] yahoogroups.com, "Elwers, George A."
> From: sentto-16485695-1148-1177612568-george.a.elwers=saic.com@...
Issues?
(depending on
> Cheers
> Charlie
> -----Original Message-----
> Behalf Of Travis
with
that
LEDs.
it
> up?
> Thanks,
> Travis Porter
> CAL 33-2 HIN 64
MSO
Re: [Cal_Boats] Re: Replacing Conventional running Lights with LED--Issues ( the Group)
Marsh Wise2007-04-27 05:36 UTC
So Madam, tell us how you really feel about LED's :-Þ
Marsh
>you period.
> <Deep Sight.....>
>fiver,
>Federal Way, Wa.
>Issues?
>(depending on
>>Cheers
>>Charlie
>>Behalf Of Travis
>with
>that
>LEDs.
>it
>>up?
>>Thanks,
>>Travis Porter
>>CAL 33-2 HIN 64
>MSO
>Yahoo! Groups Links
slickbutfoxbuger2007-04-27 07:27
Well, Capt. Marsh;
i was having one hell-of-a problem with the "IR" led in my
stinking mouse for the last two or three days. it's a wireless job so
i can use it on the bed, and it was getting so the dumb pointer just
wouldn't move at all. sort-of like it had steped in gum; it wanted to
move. and it did a little some times. but towred the end, one just
got the idea it wanted to grunt and give up.
now i tried everything i could think of including setting the
computer back 4 days. and this only after i had run full scans
several times with each of the different ass-chewing programs that i
use to keep the bad-guys at bay.
but in the end, none of this worked. and then i was looking at
the dumb mouse and trying to think of how it was different then the
first one of the same type and brand that i had and lost.
and then it hit me like a rock! this bloody thing had no bloody
red led! Logiteck had changed it in all their wisdom to a "IR" Led. i
guess to keep it out of peoples eyes. and then it doned on me! a
bright red Led would not be bothered by a little lint from the
comforter on my bed. but i bet that the damn "IR" would. so i put my
reading glasses on and took a good look and sure enough, there was a
nice little ball of lint in the hole where the "IR" Led is. so i just
hufft and i puffed and i blow that lint right out!
and now my little mouse-rod is working just like a big rat-
rod.....
fiver
> Marsh
NYBoilermaker2007-04-28 00:56 UTC
Hiya Travis-
I don't know if I missed something but if you're referring to
replacing interior overhead lights with LEDs, go for it.
I replaced all the interior bulbs in Serendip last year and I save a
ton of power.
Check out http://www.sailorssolutions.com
Their bulbs replace the existing bulbs on our 33-2 with an easy to
install adaptor.
-JD
Serendipity
CAL 33-2 #153
> wire it up?
> Thanks,
> Travis Porter
> CAL 33-2 HIN 64
tr… [at] sbcglobal.net2007-04-29 13:54 UTC
JD, George, Chris, Charlie,
Thanks for the tips on the lighting. I think it is not going to be the pain that I thought it would be.
Travis
Vital
Cal 33-2, 1986
Sent: Friday, April 27, 2007 7:56 PM
Subject: Re: [Cal_Boats] Replacing Conventional Lights with LED--Issues?
Hiya Travis-
ton of power.
install adaptor.
-JD
Serendipity
CAL 33-2 #153
> wire it up?
> Thanks,
> Travis Porter
> CAL 33-2 HIN 64
Re: [Cal_Boats] To Russia Via the Azores!
Sail Away2007-05-06 13:25 UTC
Well looks like my 1977 Cal 34 III is sold. Cash was exchanged Friday for the price and new owners are working on her. The purchasers live in St. Petersburg Russia, however are from Ireland and have a long history of long distance sailing. Also, one of his friends is here in the States (Irish National) and is a Navel Architect and came to the boat several times to check her out. They plan on taking her back in the next 3+/- weeks...I was completely worried about the a scam, however can see no angle. Even had the cash checked for counterfeit money. Also, the boat is still on the hard blocked in by other boats and has to be trucked to the water, so I still have control as the yard manager is a friend and knows my concerns
Was interesting why they purchased the boat here. According to them, due to the exchange rate, significant European taxes, Safety inspection costs and other $ items imposed on purchase of used boats as well as a lack of quality used fiberglass boats, the best bet for their money was here in the States.
What an adventure the old Cal will have! Wonder if there are any Cals over in Europe? Now there will be one!
Greg
Former 1977 Cal 34 III
Re: To Russia Via the Azores!
mtkennedy12007-05-06 13:52
snipped
There is a Cal 40 in Sweden and one in the Med that was sold new to a German who kept it
in the Med for cruising. The Swedish boat did at least one Bermuda Race.
Mike Kennedy
Conqust Cal 40 # 96
There are also Cal 40s in South Africa and Brazil.
> Greg
