paint
paint
11 messages2006-12-07 03:46 UTCthrough 2007-06-13 02:46 UTC
paint
Marsh Wise2006-12-07 03:46 UTC
What kind of paint do you all reccomend to pain the interior and overhead of a Cal 25? thanks, Marsh
Re: [Cal_Boats] paint
Bob Walden2006-12-07 03:55 UTC
The best quality exterior latex house paint you can afford. ----- Original Message ----- From: Marsh Wise To: Ca… [at] yahoogroups.com Sent: Wednesday, December 06, 2006 7:46 PM Subject: [Cal_Boats] paint What kind of paint do you all reccomend to pain the interior and overhead of a Cal 25? thanks, Marsh
Re: paint
mtkennedy12006-12-07 04:00
--- In Ca… [at] yahoogroups.com, Marsh Wise <marsh@...> wrote: > > What kind of paint do you all reccomend to pain the interior and > overhead of a Cal 25? > thanks, Marsh I've used KILZ primer and Sears Kitchen and Bathroom enamel. The Sears paint is supposed to prevent mildew. So far it looks good. MIke Kennedy Conquest Cal 40 # 96 >
Re: [Cal_Boats] Re: paint
Marsh Wise2006-12-07 04:10 UTC
anything special to prep it? mtkennedy1 wrote: >--- In Ca… [at] yahoogroups.com, Marsh Wise <marsh@...> wrote: > > >>What kind of paint do you all reccomend to pain the interior and >>overhead of a Cal 25? >>thanks, Marsh >> >> > >I've used KILZ primer and Sears Kitchen and Bathroom enamel. The Sears paint is supposed to >prevent mildew. So far it looks good. > >MIke Kennedy >Conquest Cal 40 # 96 > > > > > > > > >Yahoo! Groups Links > > > > > >
Re: paint
mtkennedy12006-12-07 05:26
--- In Ca… [at] yahoogroups.com, Marsh Wise <marsh@...> wrote: > > anything special to prep it? I think some 25s have adhesive holding carpet to the inner hull. That was not a problem with the 40. I have seen some comment on removing the liner material and other 25 owners can comment on that. I had a Cal 25 about 35 years ago and it had indoor- outdoor carpet on the inner hull. MIke Kennedy Conquest Cal 40 # 96. > > mtkennedy1 wrote: > > >--- In Ca… [at] yahoogroups.com, Marsh Wise <marsh@> wrote: > > > > > >>What kind of paint do you all reccomend to pain the interior and > >>overhead of a Cal 25? > >>thanks, Marsh > >> > >> > > > >I've used KILZ primer and Sears Kitchen and Bathroom enamel. The Sears paint is supposed to > >prevent mildew. So far it looks good. > > > >MIke Kennedy > >Conquest Cal 40 # 96 > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > >
Chris Campbell2006-12-07 14:01 UTC
Marsh Wise wrote: > > What kind of paint do you all reccomend to pain the interior and > overhead of a Cal 25? > thanks, Marsh > I have used Pettit's Dura-White, an interior paint designed for boats. Pettit touts it as adhering to any surface, even glossy, without sanding (but with washing first). They also claim that it discourages mildew. Now it just so happens that I am a skeptic about "adheres to any surface," just as I disbelieve an offer of "free" anything, or effortless accomplishment of any kind. So I prepped my surface a bit more than necessary. I've been very happy with the Dura-White. I also took my quart to the local Ace Hardware and had them tint it to match a chip of the original interior paint. Let's just say that I had a lot of chips of the original paint, or whatever that miserable substance was that Cal slathered over the inside. Later I found that the paint can had a big chunk of solids left at the bottom--the store's paint shaker had not completely mixed it up. The next time I'm going to stir it up first then take it in for tinting. Chris Campbell > >
RE: [Cal_Boats] Re: paint
Husar, Charlie2006-12-07 19:13 UTC
Marsh, after finishing the grinding and sanding, I did a dust washdown, then an acetone wipe-down prior ro painting several coats (of the exterior house paint mentioned in the other note). Cheers Charlie From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Marsh Wise Sent: Wednesday, December 06, 2006 11:10 PM To: Ca… [at] yahoogroups.com Subject: Re: [Cal_Boats] Re: paint anything special to prep it? mtkennedy1 wrote: --- In Ca… [at] yahoogroups.com, Marsh Wise <marsh@...> <mailto:marsh@...> wrote: What kind of paint do you all reccomend to pain the interior and overhead of a Cal 25? thanks, Marsh I've used KILZ primer and Sears Kitchen and Bathroom enamel. The Sears paint is supposed to prevent mildew. So far it looks good. MIke Kennedy Conquest Cal 40 # 96 Yahoo! Groups Links
RE: [Cal_Boats] Re: CAL 25 paint
Husar, Charlie2006-12-07 19:18 UTC
Yes, Mike, the later CAL 25s (and I'm sure other models) had the carpet on the wall. SOB to remove because of the adhesive and the fact the foam backing of the carpet stays with the glue on the walls. Mostly scraping. Also, that fibered stuff they used to paint the roof for a while is the dickens to get off, and edges will not sand smoothly. Paint I use on interior (don't like glossy interior surfaces) is Sears Weatherbeater or equivalent exterior house paint. It does have anti-mold components. Seems durable. Cheers Charlie of the 3 CAL 25s Annapolis From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of mtkennedy1 Sent: Thursday, December 07, 2006 12:27 AM To: Ca… [at] yahoogroups.com Subject: [Cal_Boats] Re: paint --- In Ca… [at] yahoogroups.com, Marsh Wise <marsh@...> wrote: > > anything special to prep it? I think some 25s have adhesive holding carpet to the inner hull. That was not a problem with the 40. I have seen some comment on removing the liner material and other 25 owners can comment on that. I had a Cal 25 about 35 years ago and it had indoor- outdoor carpet on the inner hull. MIke Kennedy Conquest Cal 40 # 96. > > mtkennedy1 wrote: > > >--- In Ca… [at] yahoogroups.com, Marsh Wise <marsh@> wrote: > > > > > >>What kind of paint do you all reccomend to pain the interior and > >>overhead of a Cal 25? > >>thanks, Marsh > >> > >> > > > >I've used KILZ primer and Sears Kitchen and Bathroom enamel. The > >Sears paint is supposed to > >prevent mildew. So far it looks good. > > > >MIke Kennedy > >Conquest Cal 40 # 96 > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > Yahoo! Groups Links
PAINT
Andy2007-06-12 23:29
I have a cal 27, i am looking for ideas on how to paint the hull above the waterline with the boat in the water. tips/tricks ? thanks andy
Re: [Cal_Boats] PAINT
Sail Away2007-06-13 01:47 UTC
Don't do it? In the water, there are too many variables that could mess up your work IMHO. Depends I guess what you expect the outcome to be and risks your willing to take....it is all personal with the one we love. I know a guy that painted his boat in the water at a dock...worked great "for him" and does look much better. I just would have chosen a more controlled environment on the hard. Good Luck Greg ----- Original Message ----- From: Andy To: Ca… [at] yahoogroups.com Sent: Tuesday, June 12, 2007 7:29 PM Subject: [Cal_Boats] PAINT I have a cal 27, i am looking for ideas on how to paint the hull above the waterline with the boat in the water. tips/tricks ? thanks andy
Bob Walden2007-06-13 02:46 UTC
The actual painting would be very hard. But the prep work would be downright nuts, not to mention very ecologically irresponsible. One reason to take a boat to the boatyard is because they're set up to handle the toxic runoff and airborne dust. It's *posssible* to do the topsides in the water, but I think it would be like painting you car on the way to work... bw ----- Original Message ----- From: Sail Away To: Ca… [at] yahoogroups.com Sent: Tuesday, June 12, 2007 6:47 PM Subject: Re: [Cal_Boats] PAINT Don't do it? In the water, there are too many variables that could mess up your work IMHO. Depends I guess what you expect the outcome to be and risks your willing to take....it is all personal with the one we love. I know a guy that painted his boat in the water at a dock...worked great "for him" and does look much better. I just would have chosen a more controlled environment on the hard. Good Luck Greg ----- Original Message ----- From: Andy To: Ca… [at] yahoogroups.com Sent: Tuesday, June 12, 2007 7:29 PM Subject: [Cal_Boats] PAINT I have a cal 27, i am looking for ideas on how to paint the hull above the waterline with the boat in the water. tips/tricks ? thanks andy
