8 messages2007-06-24 03:07 through 2007-06-29 04:51 UTC
First set of questions -- Wheel steering and hull number
Richard2007-06-24 03:07
So I was up at the boat today finishing up the electrical project.
All looks good there (aside from some strangeness on the DC panel that
I'll have to trace out later)...
Anyway, questions..
1.) Does anyone know what the make model of the pedestal/wheel on my
'75 2-29 is? I think it's an Edson, possibly a 300 series. I took
the compass and top dome off today but I can't find ANY markings to
indicate a model or make. I measured the top plate at 7" but now that
I see the 300 series is 6 7/8" I'm thinking I may not have been
precise enough in measuring to be sure. I would like to install a
pedestal guard but I just don't know what pedestal I have to begin the
process of finding an appropriate guard.
2.) Where should I look to find the hull # of the boat? I have an old
bill of sale that was on the boat with a hull#, but I also have the
Jensen Marine owners manual which has a different hull#. So I am not
sure what the actual number is.
Thanks in advance..
Richard Anderson
"Sleipnir"
1975 Cal 2-29
Everett, WA
http://pics.livejournal.com/techsavvy/pic/0004sec8/t9678z
Re: [Cal_Boats] First set of questions -- Wheel steering and hull number
Matt Beland2007-06-24 05:20 UTC
I'm not sure exactly what the pedestal is, but if you've got dimensions, try
Popeye's (north end of Everett Marina, by the Yacht Club building) and
perhaps Dunato's Second Wave in Ballard. Both do consignment stuff and have
older gear that would be more likely to match perfectly. Second Wave has a
much larger selection, but Popeye's is a great resource (not just for used
stuff).
My Cal 25 and my old Cal 20 both had the hull number laminated behind a layer
of clear fiberglass inside the hull on the starboard transom. Both were
visible by looking straight aft from the starboard lazarette hatch.
Where in Everett are you located? My 25 (Firecracker) is in F-51 South in the
main PoE marina. There are a few other Cals around there as well.
Matt Beland
ma… [at] rearviewmirror.org
http://www.rearviewmirror.org
RE: [Cal_Boats] First set of questions -- Wheel steering and hull number
David W. Owen2007-06-24 08:30 UTC
Richard,
My 1975 Cal 2-29 has a pedestal manufactured by "Yacht Services." They have
been out of business for many years. Edson doesn't have any parts that are
specified, but some may actually fit. It's amazing what you can find if you
look in the right places, such as sheaves, chain, sprockets, etc.
You will find that the newer Edson pedestal guards are spaced a lot closer
together than the Yacht Services ones were. This makes finding a used
mounting plate a fruitless idea. You will probably have to manufacture an
adapter plate on your own and buy an Edson guard. I haven't talked to Edson
about rather or not their mounting plate would be close enough to adapt to
the old YS pedestal.
I have made a compass mounting plate out of wood as a temporary fix for a
corroded up plate that my Ritchie compass sat on. I painted it to look
pretty nice, but it will rot away in no time, so I will probably cut one
from Aluminum and have it powder coated when I get a little more time. I had
Ritchie re-manufacture the compass. They charge a flat rate and upgrade
every part to the newest specs. The only part that they re-used on mine was
the stainless shell..... LOL. I basically got a new $500 compass for $240.
If you look at the transom from the rear of the boat you will find the ID #
about 3/4 of the way up nearer the right (starboard) side. It's a small
indentation about 2 X 3" or so with the number recessed into the fiberglass.
It should read CAB297XXXX75. Mine is CAB297630675, which translates to
Cal-boats 29 Hull # 763 built June 1975.
Hope this all helps.
David Wilkie Owen
Cal 2-29 "Mariposa"
Santa Barbara, CA
http://www.mariposasailing.com
Of Richard
Sent: Saturday, June 23, 2007 8:08 PM
Subject: [Cal_Boats] First set of questions -- Wheel steering and hull
number
All looks good there (aside from some strangeness on the DC panel that I'll
Anyway, questions..
'75 2-29 is? I think it's an Edson, possibly a 300 series. I took the
compass and top dome off today but I can't find ANY markings to indicate a
model or make. I measured the top plate at 7" but now that I see the 300
series is 6 7/8" I'm thinking I may not have been precise enough in
measuring to be sure. I would like to install a pedestal guard but I just
don't know what pedestal I have to begin the process of finding an
appropriate guard.
2.) Where should I look to find the hull # of the boat? I have an old bill
of sale that was on the boat with a hull#, but I also have the Jensen Marine
owners manual which has a different hull#. So I am not sure what the actual
number is.
Thanks in advance..
Richard Anderson
"Sleipnir"
1975 Cal 2-29
Everett, WA
<http://pics.livejournal.com/techsavvy/pic/0004sec8/t9678z>
Re: First set of questions -- Wheel steering and hull number
Richard2007-06-25 03:54
Ooh, thanks for the tips on Popeyes and Second Wave, I'll have to
mosey over there next time I'm up there.
We are at South D61. I think we need to make a Cal registry for
Everett Marina or all of the surrounding area. Unless there is
already one. Might help with organizing local events.
Richard
dimensions, try
and have
has a
for used
> stuff).
behind a layer
South in the
> Matt Beland
> matt@...
Richard2007-06-25 04:04
Cool, I'll check it out.
By the way, before I was ever on this board, and actually before we
bought our Cal, I spent quite a bit of time on your website, I was
real interested in the Rigid Boom vang on your boat.
Richard
--- In Ca… [at] yahoogroups.com, "David W. Owen" <dwowen@...> wrote:
> Richard,
They have
that are
if you
closer
manufacture an
to Edson
adapt to
for a
time. I had
mine was
for $240.
the ID #
fiberglass.
> David Wilkie Owen
> _________________
> Cal 2-29 "Mariposa"
> Santa Barbara, CA
> -----Original Message-----
On Behalf
> Of Richard
> number
that I'll
> Anyway, questions..
indicate a
just
> appropriate guard.
old bill
Jensen Marine
actual
> number is.
> Thanks in advance..
> Richard Anderson
> "Sleipnir"
> 1975 Cal 2-29
> Everett, WA
RE: [Cal_Boats] Re: First set of questions -- Wheel steering and hull number
David W. Owen2007-06-26 04:36 UTC
I really like it a lot, and it's a great value for the buck.
David
Of Richard
Sent: Sunday, June 24, 2007 9:05 PM
Subject: [Cal_Boats] Re: First set of questions -- Wheel steering and hull
number
By the way, before I was ever on this board, and actually before we bought
our Cal, I spent quite a bit of time on your website, I was real interested
Richard
> Richard,
They have
that are
if you
closer
manufacture an
to Edson
adapt to
for a
> one from Aluminum and have it powder coated when I get a little more
time. I had
> upgrade every part to the newest specs. The only part that they
> re-used on
mine was
for $240.
the ID #
> small indentation about 2 X 3" or so with the number recessed into the
fiberglass.
> David Wilkie Owen
> _________________
> Cal 2-29 "Mariposa"
> Santa Barbara, CA
> http://www.mariposasailing.com <http://www.mariposasailing.com>
> From: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>
> [mailto:Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>
On Behalf
> Of Richard
> To: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>
> number
that I'll
> Anyway, questions..
indicate a
> 300 series is 6 7/8" I'm thinking I may not have been precise enough
> in measuring to be sure. I would like to install a pedestal guard but
> I
just
> appropriate guard.
old bill
Jensen Marine
actual
> number is.
> Thanks in advance..
> Richard Anderson
> "Sleipnir"
> 1975 Cal 2-29
> Everett, WA
> <http://pics.livejournal.com/techsavvy/pic/0004sec8/t9678z> >
RE: [Cal_Boats] Richard- Wheel steering Cal2-29
david dobbs2007-06-29 02:46 UTC
Richard,
Welcome to the group, you will learn a lot here. Just
one thing, and I hate to quibble, but your steering
was probably made by Yacht Specialties Inc. They are
indeed defunct and I am hoping my system holds up
another couple of years. I have a 29 that was
covnverted from tiller steering. I actually like the
wheel, but there are more parts, it's harder to get
at, etc.
As far as heeling, I think the 29 does best when on
her feet. I usually reef and try to keep her fairly
upright.
David Dobbs
Cal29 411
> the buck.
> David
> Of Richard
> number
> Richard
> > Richard,
> "Yacht Services."
> They have
> have any parts
> that are
> what you can find
> if you
> sprockets, etc.
> are spaced a lot
> closer
> have to
> manufacture an
> I haven't talked
> to Edson
> close enough to
> adapt to
> as a temporary fix
> for a
> will probably cut
> get a little more
> time. I had
> flat rate and
> part that they
> > re-used on
> mine was
> new $500 compass
> for $240.
> boat you will find
> the ID #
> fiberglass.
> which translates to
> > David Wilkie Owen
> > _________________
> > Cal 2-29 "Mariposa"
> > Santa Barbara, CA
> On Behalf
> > Of Richard
> > number
> electrical project.
> on the DC panel
> that I'll
> > Anyway, questions..
> series. I took the
> ANY markings to
> indicate a
> now that I see the
> been precise enough
> pedestal guard but
> > I
> just
> > appropriate guard.
> boat? I have an
> old bill
> also have the
> Jensen Marine
> not sure what the
> actual
> > number is.
> > Thanks in advance..
> > Richard Anderson
> > "Sleipnir"
> > 1975 Cal 2-29
> > Everett, WA
Don't pick lemons.
See all the new 2007 cars at Yahoo! Autos.
http://autos.yahoo.com/new_cars.html
Randy Alcorn2007-06-29 04:51 UTC
Wow, I just saw the picture of the interior and thougt it was my boat till I saw the cusions were blue.
I am just catching up.
Randy
Out Patient
Cal 2-29 #512
Channle Islands CA
david dobbs <tm… [at] yahoo.com> wrote:
Richard,
at, etc.
upright.
David Dobbs
Cal29 411
> the buck.
> David
> Of Richard
> number
> Richard
> > Richard,
> "Yacht Services."
> They have
> have any parts
> that are
> what you can find
> if you
> sprockets, etc.
> are spaced a lot
> closer
> have to
> manufacture an
> I haven't talked
> to Edson
> close enough to
> adapt to
> as a temporary fix
> for a
> will probably cut
> get a little more
> time. I had
> flat rate and
> part that they
> > re-used on
> mine was
> new $500 compass
> for $240.
> boat you will find
> the ID #
> fiberglass.
> which translates to
> > David Wilkie Owen
> > _________________
> > Cal 2-29 "Mariposa"
> > Santa Barbara, CA
> On Behalf
> > Of Richard
> > number
> electrical project.
> on the DC panel
> that I'll
> > Anyway, questions..
> series. I took the
> ANY markings to
> indicate a
> now that I see the
> been precise enough
> pedestal guard but
> > I
> just
> > appropriate guard.
> boat? I have an
> old bill
> also have the
> Jensen Marine
> not sure what the
> actual
> > number is.
> > Thanks in advance..
> > Richard Anderson
> > "Sleipnir"
> > 1975 Cal 2-29
> > Everett, WA
Don't pick lemons.
Shape Yahoo! in your own image. Join our Network Research Panel today!
