Pulling a Farymann from a 2-29
8 messages2007-08-09 07:08 through 2007-08-10 20:37
John Caldwell2007-08-09 07:08
I know that some of you with a 29 have replaced your Farymann with a Beta Marine. I've started pulling my old Farymann apart in preparation for such a repower. Any tips or tricks from any of you who have made the swap would be much appreciated. Even if you didn't repower with the Beta Marine, if you've pulled a Farymann from a 29, I'd love to hear what you encountered in doing so. The Farymann sits rather tall in the engine compartment and is bound to hit the cockpit floor as it moves forward for removal. I'm anxious to hear how you handled that. Did you cut the cockpit floor? Did you drop it off of the mounts before pulling it forward? Did you go nuts with a gas axe? Thanks in advance for any input! John Caldwell 1977 2-29 Hull 966
Re: Pulling a Farymann from a 2-29
slickbutfoxbuger2007-08-09 08:20
set your type 3 phaser on level 5, and direct the weapon at the base of the engine block for no longer than 1.34 seconds. after that a simple ventilating of the cabin, and subsequent scraping of any localized glass-charring should solve your problem....... unless of course, you had intended to sell the old engine on "Crages- list" after removal......????? 5er...... *********************** --- In Ca… [at] yahoogroups.com, "John Caldwell" <jacaldwell@...> wrote: > > I know that some of you with a 29 have replaced your Farymann with a > Beta Marine. > > I've started pulling my old Farymann apart in preparation for such a > repower. > > Any tips or tricks from any of you who have made the swap would be > much appreciated. > > Even if you didn't repower with the Beta Marine, if you've pulled a > Farymann from a 29, I'd love to hear what you encountered in doing so. > > The Farymann sits rather tall in the engine compartment and is bound > to hit the cockpit floor as it moves forward for removal. I'm > anxious to hear how you handled that. Did you cut the cockpit > floor? Did you drop it off of the mounts before pulling it forward? > Did you go nuts with a gas axe? > > Thanks in advance for any input! > > John Caldwell > 1977 2-29 Hull 966 >
Re: [Cal_Boats] Pulling a Farymann from a 2-29
Terrence Spencer2007-08-09 13:38 UTC
I don¹t know if these are ³tips², but these procedures were helpful for me (assuming Fiver¹s phaser weapon does not work for you) 1. I cut a piece of cardboard to fit the salon floor and reach up the sides a bit and laid it down. 2. I cut a piece of 1/4 inch plywood to fit the salon floor and laid it on top of the cardboard. 3. All of this was to protect the floor when you set the new engine down on it. 4. I used a couple of 2 x 12¹s bolted together, one wide enough to set over my companionway hatch and the other just lightly smaller, to fit just inside the hatch frame. With a big eye bolt in the center to accept a ³come along² or ³engine lift² (not sure what they call these but it was a chain with a two way ratchet) which I borrowed for the procedure. 5. After cleaning out the battery area in front of the engine, I laid two 2x4s down to slide the Farymann out along. 6. Label every hose and wire as it came off the engine and battery. 7. Save every part or set of parts in a plastic baggy labeled with a permanent marker. 8. The engine slides up the two by¹s with the aid of the engine lift and human muscle power and has to be wrestled a bit to the cockpit floor. 9. When I took the Farymann completely out of the boat, I was towed to a nearby hoist and, using the same procedure, lifted it clear of the boat. In retrospect, the phaser idea sounds really great. I am sure others on the list will have done this procedure and have even better tips. Good luck with your project. Terry Spencer Capriccio Cal 2-29 From: "John Caldwell" <ja… [at] vel.net> Reply-To: Ca… [at] yahoogroups.com Date: Thu, 09 Aug 2007 07:08:54 -0000 To: Ca… [at] yahoogroups.com Subject: [Cal_Boats] Pulling a Farymann from a 2-29 I know that some of you with a 29 have replaced your Farymann with a Beta Marine. I've started pulling my old Farymann apart in preparation for such a repower. Any tips or tricks from any of you who have made the swap would be much appreciated. Even if you didn't repower with the Beta Marine, if you've pulled a Farymann from a 29, I'd love to hear what you encountered in doing so. The Farymann sits rather tall in the engine compartment and is bound to hit the cockpit floor as it moves forward for removal. I'm anxious to hear how you handled that. Did you cut the cockpit floor? Did you drop it off of the mounts before pulling it forward? Did you go nuts with a gas axe? Thanks in advance for any input! John Caldwell 1977 2-29 Hull 966
Chris Campbell2007-08-09 13:54 UTC
Terrence Spencer wrote: > > I don't know if these are "tips", but these procedures were helpful > for me (assuming Fiver's phaser weapon does not work for you) > Thanks, folks, for making me grateful for my outboard motor. Removal instructions: disconnect gas line; loosen clamps; lift. Chris Campbell
RE: [Cal_Boats] Pulling a Farymann from a 2-29(John)
rick lobb2007-08-09 16:22 UTC
John, Pulling the Farymann out of my 2-29 was probably one of the easiest projects I have done. It took two of us less than an hour to disconnect everything and hoist the engine out of the boat. I had no clearance issues, we just slid the engine forward and used the main halyard to hoist the engine out. If I remember correctly, we did place a couple of boards on edge to extend the rails a little further to slide the engine as far forward as possible. Rick Lobb Cal 2-29 "Rebecca Shea" Bellingham, WA _____ From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of John Caldwell Sent: Thursday, August 09, 2007 12:09 AM To: Ca… [at] yahoogroups.com Subject: [Cal_Boats] Pulling a Farymann from a 2-29 I know that some of you with a 29 have replaced your Farymann with a Beta Marine. I've started pulling my old Farymann apart in preparation for such a repower. Any tips or tricks from any of you who have made the swap would be much appreciated. Even if you didn't repower with the Beta Marine, if you've pulled a Farymann from a 29, I'd love to hear what you encountered in doing so. The Farymann sits rather tall in the engine compartment and is bound to hit the cockpit floor as it moves forward for removal. I'm anxious to hear how you handled that. Did you cut the cockpit floor? Did you drop it off of the mounts before pulling it forward? Did you go nuts with a gas axe? Thanks in advance for any input! John Caldwell 1977 2-29 Hull 966
grahamrevans2007-08-09 16:29
John, I pulled and rebuilt mine last year. I hooked a come-along to the boom to pull the engine straight out the companionway. You will need to guide the engine forward as you lift it out of the engine compartment. To make the attachment to the boom I wrapped carpet around it to protect it then wrapped a chain around it several times to distribute the load. I attached the come-along to this chain. To support the boom I attached two halyards close to where the come- along was attached to avoid bending the boom. Again, I padded the boom and wrapped each halyard around acouple of times. Obviously you need to disconnect all wiring, the prop shaft, and the fuel line. I unscrewed the motor mounts from the support rather than from the engine. This allowed me to slide it forward along the supports. I recommend taking digital pictures of everything from every angle before disconnecting anything. Be sure to plug up the opening to the bilge before you start in case you drop any parts. You might consider rebuilding it. The parts should still be available unless yours is too far gone. Good luck, Graham Nefertiti, 1974 2-29 --- In Ca… [at] yahoogroups.com, "John Caldwell" <jacaldwell@...> wrote: > > I know that some of you with a 29 have replaced your Farymann with a > Beta Marine. > > I've started pulling my old Farymann apart in preparation for such a > repower. > > Any tips or tricks from any of you who have made the swap would be > much appreciated. > > Even if you didn't repower with the Beta Marine, if you've pulled a > Farymann from a 29, I'd love to hear what you encountered in doing so. > > The Farymann sits rather tall in the engine compartment and is bound > to hit the cockpit floor as it moves forward for removal. I'm > anxious to hear how you handled that. Did you cut the cockpit > floor? Did you drop it off of the mounts before pulling it forward? > Did you go nuts with a gas axe? > > Thanks in advance for any input! > > John Caldwell > 1977 2-29 Hull 966 >
scott2007-08-10 01:30 UTC
Hi John Good to replace it thay are old salt water cooled on banger mine still runs good but there was water blockage in the water jacket now cleared. Since your tranny blew, the parts for the hurth are around but Nanni gearbox well they hard to find. They were good engines for there time but all engines wear out. Pulling the motor no problem. 1. 4x4 across the cabin top and add the boom and halyard for a little back up you can bend the or break it even if its Halyard supported. 2 Remove the Alternator for more room in there. 3 some assorted 2x4 and 4x4 and a small plywood piece to help shore and slide it 4. The back of motor will sag so you need to help it out. My 5cents worth Scott rick lobb <lr… [at] qwest.net> wrote: John, Pulling the Farymann out of my 2-29 was probably one of the easiest projects I have done. It took two of us less than an hour to disconnect everything and hoist the engine out of the boat. I had no clearance issues, we just slid the engine forward and used the main halyard to hoist the engine out. If I remember correctly, we did place a couple of boards on edge to extend the rails a little further to slide the engine as far forward as possible. Rick Lobb Cal 2-29 “Rebecca Shea” Bellingham, WA --------------------------------- From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of John Caldwell Sent: Thursday, August 09, 2007 12:09 AM To: Ca… [at] yahoogroups.com Subject: [Cal_Boats] Pulling a Farymann from a 2-29 I know that some of you with a 29 have replaced your Farymann with a Beta Marine. I've started pulling my old Farymann apart in preparation for such a repower. Any tips or tricks from any of you who have made the swap would be much appreciated. Even if you didn't repower with the Beta Marine, if you've pulled a Farymann from a 29, I'd love to hear what you encountered in doing so. The Farymann sits rather tall in the engine compartment and is bound to hit the cockpit floor as it moves forward for removal. I'm anxious to hear how you handled that. Did you cut the cockpit floor? Did you drop it off of the mounts before pulling it forward? Did you go nuts with a gas axe? Thanks in advance for any input! John Caldwell 1977 2-29 Hull 966 --------------------------------- Pinpoint customers who are looking for what you sell.
Thanks! Re: Pulling a Farymann from a 2-29
John Caldwell2007-08-10 20:37
Thanks for everyone's input! John Caldwell 1977 2-29 Hull 966 --- In Ca… [at] yahoogroups.com, "John Caldwell" <jacaldwell@...> wrote: > > I know that some of you with a 29 have replaced your Farymann with a > Beta Marine. > > I've started pulling my old Farymann apart in preparation for such a > repower. > > Any tips or tricks from any of you who have made the swap would be > much appreciated. > > Even if you didn't repower with the Beta Marine, if you've pulled a > Farymann from a 29, I'd love to hear what you encountered in doing so. > > The Farymann sits rather tall in the engine compartment and is bound > to hit the cockpit floor as it moves forward for removal. I'm > anxious to hear how you handled that. Did you cut the cockpit > floor? Did you drop it off of the mounts before pulling it forward? > Did you go nuts with a gas axe? > > Thanks in advance for any input! > > John Caldwell > 1977 2-29 Hull 966 >
