18 messages2007-08-07 17:29 through 2007-08-12 01:49 UTC
Stainless Steel Bolts
Jeff Baumgardner2007-08-07 17:29
How often should they be replaced? A couple of my stanchion bolt have
had the heads pop off quite easilly when I tried to remove them. I
intend to rebed them all eventually and am wondering if I should
replace all of the bolts and not just some of them. I'm an engineer and
not untill I bought a sailboat did I know that stainless steel has a
lifespan.
Also on that note what about rigging? I do not know how old my rigging
is but It was ok when I had a rigging inspection done. Are there key
thinks to inspect?
Re: Stainless Steel Bolts
slickbutfoxbuger2007-08-07 18:19
hi, Jeff;
as i get the idea that my not so subtle humor is falling flat
around here right now....... i will try and avoid any more of it in my
response to you.
i know what you mean about SS marine stock having a life-span. and i
find some of that due to fatigue in the metal it's self, or the wrong
grade of SS being used for the application. and some of it just do to
the engineering of the application and the fact that no choice is
the "best choice" for that purpose. SS doesn't like to be used in
certain environments where it's starved of oxygen. such as inside of
shaft-bearing that sit un-turned in water for months at a time.
it is for this reason that i never re-used a *Critical* SS fastener
twice in a row. and hand-rail bolt's are critical fasteners in my book.
but i was most surprised when i hulled down the mast on BB-54 before
bring it up from California to Seattle. in the last years of her life,
the boat had been used by amateurs. people who would do such things as
torque the standing rigging to the point one could play a jig on it if
they had bow. that rigging was the original stuff from the builder; 43
years old. and the only part that wasn't SS were the turn-buckles and
pin's therein. they were bronze. and with all of those years of use,
and end year's of abuse. all i found was one single newly snapped
wire.....
now i am not saying that i would take that old rig out in a north-coast
blow or anything, but i think it does say something in answer to your
question.
fiver.......
--- In Ca… [at] yahoogroups.com, "Jeff Baumgardner" <jeffbum1@...>
and
> lifespan.
rigging
> thinks to inspect?
RE: [Cal_Boats] Re: Stainless Steel Bolts
Downing, Thomas2007-08-07 19:08 UTC
My two bits worth:
I've heard differing opinions on the likelyhood of rigging failure due
to age. I would agree with fiver that just high tension alone should
not directly cause failure. In fact, failure is reputed to be caused
or hurried by too LITTLE tension, resulting in excessive bending
of the wire at the point of entry to the swage, and also to fittings
due to mechanical wear and shock.
Rigging often fails at the point of entry to the swage, or sometimes
(if the swaging was not perfect) just inside the swage. Penetrant
dye testing or magnaflux testing would reveal these. Magnaflux is
a bit tricky for several reasons. Penatrant dye is easy, but won't
directly reveal cacks in the wire inside the swage, though it may
reveal cracks at the point of entry.
Sometimes failure can be detected by a crack in the swage itself
in the area that was rolled to form the swage. This will show easily
by dye testing, and can be bad enough to be visible on close
inspection without dye. Any such crack would be, IMHO, reason
to replace that bit of rigging.
The first year I had my 2-27 I detected such a crack in the starboard
lower shroud. As I sail in snotty weather, I decided to replace all
the standing rigging as insurance.
BTW, it's recomended to go up one size from stock on the 2-27, I
don't know about other Cal's.
I'm also with fiver on reuse of stainless fasteners in safety related
applications.
td
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of slickbutfoxbuger
Sent: Tuesday, August 07, 2007 2:20 PM
Subject: [Cal_Boats] Re: Stainless Steel Bolts
hi, Jeff;
response to you.
wire.....
question.
fiver.......
--- In Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com, "Jeff Baumgardner" <jeffbum1@...>
and
> lifespan.
rigging
> thinks to inspect?
DISCLAIMER:
Re: [Cal_Boats] Re: Stainless Steel Bolts
Chris Campbell2007-08-07 19:44 UTC
> wire.....
On my other boat, a 1961 Seafarer (26' 3", with wooden mast), all of the
standing rigging was original. That made it 45 years old this spring.
Based on simple caution and the warnings from others, I had new standing
rigging made up this spring before launching. I had no evidence of any
sort of failure in the original rigging. It just seemed wise to be
cautious after 45 years of service. It's all SS wire with swaged
fittings, and with bronze open-body turnbuckles. I have reused the
original turnbuckles which have no likelihood of failure.
This boat has been sailed exclusively in fresh water and, because our
water gets hard every fall, the boat is in service only 6 months per
year. The rest of the time the mast is unstepped and everything is
stored indoors & dry. That gives the materials a longevity advantage
over you folks in the warm and salty parts of the earth who get to sail
on soft water year-round.
Now the old iceboat is another matter. The standing rigging has a
fairly high failure rate from overloading or underdesign. And on my
Cal 20, I've had a backstay fail and a friend had his original spreader
brackets fail this spring. I had replaced mine with Steve Seal's
heavy-duty ones and he had also supplied a larger-diameter backstay for
me. Those seem like under-design issues. We used my old original
spreader brackets on the friend's boat so he could go sailing.
Chris Campbell2007-08-07 19:50 UTC
Somebody on one of these boat lists pointed out a few years back that
there can be higher shock loads on too-slack shrouds when they go slack
then tight as the mast moves in seas. I have observed this on my boats,
which tend to have slack rigging (I'm not sure the Cal 20 could ever
have bar-tight shrouds without lots of under-deck reinforcement of mast
step and the "chainplate" brackets that the shrouds end on). As the
boat rolls in seas and light air, the slack shrouds tend to snap tight.
That kind of cyclical loading ultimately leads to failure (as the folks
in Minneapolis have learned with their bridge). My intent is to work a
bit on the Cal 20 this winter so I can keep the shrouds tighter next year.
mkmcelhaney2007-08-07 21:16
> lifespan.
> thinks to inspect?
Jeff,
I don't know about a "lifespan" per se, but if you have the original
bolts connecting the upper and lower shrouds, REPLACE THEM. I recently
went through a dismasting on my Cal-25 because the lower shroud bolt
had a fatigue crack INSIDE the compression tube in the mast. This
happened during a race when the winds were 30 knots. Not fun. I was
really lucky nobody was hurt. i happened to have a spare mast in my
backyard and replaced those bolts with ones where the shoulder goes
all the way through to the tang on the other side. This way there will
be no threads inside the mast. The threads are the weak point since
they are cut with a die. (I have heard rumors of aircraft grade bolts
where the threads are rolled but haven't seen them). The only way to
have discovered the stress fractures in the bolt on my mast would have
been to disassemble the shroud connection, take out the bolt, slide
off the compression tube (ha ha! Good luck!) and then dip the bolt in
fluorescent dye and inspect with a UV light. If you have changed them
within the last ten years, then I wouldn't worry overmuch. I hope this
helps and if there are other opinions, I would like to hear them.
RE: [Cal_Boats] Stainless Steel Bolts
r good2007-08-08 03:20 UTC
if there is any moisture getting to the stainless bolt/screw and no oxygen,
it will rust through. We ound that on our boat when we bought it.
We ended up removing all deck fittings for re-bedding and replacing quite a
few screws/bolts. We also took that opportunity to add backing plates.
If you don't know the copndition of yoru rig, dye test all swages. Kits are
cheap. Masts are not.
>From: "Jeff Baumgardner" <je… [at] yahoo.com>
>Subject: [Cal_Boats] Stainless Steel Bolts
>Date: Tue, 07 Aug 2007 17:29:00 -0000
>lifespan.
>thinks to inspect?
Puzzles, trivia teasers, word scrambles and more. Play for your chance to
win! http://club.live.com/home.aspx?icid=CLUB_hotmailtextlink
Downing, Thomas2007-08-08 10:56 UTC
The Cal 2-27 is kept fairly taut. My problem is with my Aloha 32.
In the generlly light western/central Long Island Sound airs it sails
notably faster with the rigging as slack as possible. This means
that when I am lucky enough to see 12 knoits, pointing causes
the lee side to be a little to slack. So that means that I don't
have any cotter pins in my turnbuckles so when out for a bit
in higher winds when the chop kicks up I can take out the slack
by hand if it gets rough enough. Doesn't happen oftern here.
I'm sure fiver will design a centrally controlled hydraulic tension
system for all the shrouds for me :-)
td
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of Chris Campbell
Sent: Tuesday, August 07, 2007 3:50 PM
Subject: Re: [Cal_Boats] Re: Stainless Steel Bolts
Somebody on one of these boat lists pointed out a few years back that there can be higher shock loads on too-slack shrouds when they go slack then tight as the mast moves in seas. I have observed this on my boats, which tend to have slack rigging (I'm not sure the Cal 20 could ever have bar-tight shrouds without lots of under-deck reinforcement of mast step and the "chainplate" brackets that the shrouds end on). As the boat rolls in seas and light air, the slack shrouds tend to snap tight.
That kind of cyclical loading ultimately leads to failure (as the folks in Minneapolis have learned with their bridge). My intent is to work a bit on the Cal 20 this winter so I can keep the shrouds tighter next year.
DISCLAIMER:
Husar, Charlie2007-08-08 13:22 UTC
Also, I've heard that those skinny plastic covers that some people put
on their shrouds and lifelines are not healthy for the stainless for the
same reasons of moistrue and air.
Behalf Of r good
Sent: Tuesday, August 07, 2007 11:21 PM
Subject: RE: [Cal_Boats] Stainless Steel Bolts
oxygen,
quite a few screws/bolts. We also took that opportunity to add backing
plates.
are cheap. Masts are not.
>lifespan.
>thinks to inspect?
to win! http://club.live.com/home.aspx?icid=CLUB_hotmailtextlink
Yahoo! Groups Links
Was Stainless Steel Bolts - Now Cotter Pins (TD)
Husar, Charlie2007-08-08 13:44 UTC
Tom, get left handed and right handed nuts to put outside the turnbuckle
barrels on the shrouds. You tighten these in place, but they can be
eased to redo rig. With no cotters or nuts, the turnbuckles will rotate
themselves and loosen. The nuts solve the problem and still readily
permit adjustment. The nuts should be fine threads (depends on your
shrouds). If your boat store does not have the nuts, McMaster-Carr in
NJ is a great on-line source for that and many stainless needs. Sell in
small qtys with very quick general shipping. I get mine in one day with
cheapest shipping method. I own no stock or interest in the place -
just get great service.
For All: Note that I retiled the mail and deleted a bunch of previous
stuff. This allows people to more readily track topics of interest, and
keeps the mails to a manageable size. Just a little list discipline
that we periodically put out.
Annapolis
Behalf Of Downing, Thomas
Sent: Wednesday, August 08, 2007 6:56 AM
Subject: RE: [Cal_Boats] Re: Stainless Steel Bolts
td
Re: [Cal_Boats] Stainless Steel Bolts
Marsh Wise2007-08-08 14:14 UTC
Yeah, mine came w/ those. I was told I should rip them off....
>Cheers
>Charlie
>-----Original Message-----
>Behalf Of r good
>oxygen,
>plates.
>Reggie
>>lifespan.
>>thinks to inspect?
>_________________________________________________________________
>Yahoo! Groups Links
>Yahoo! Groups Links
Marsh Wise
Webmaster:
-reenactor.Net: http://www.reenactor.net/
-Foresthill.us: http://www.foresthill.us/
-Legio IX Hispana Penna: http://www.reenactor.net/units/legio_ix_penna/
- 17. Luftwaffe Feld-Division <coming soon to a website near YOU!>
Assistant Webmaster:
-VAQ-33 Squadron site: http://www.reenactor.net/vaq-33/
Proud Member (meaning I can just have fun...)
-LEGIO IX HISPANA COH III Penna Chapter: http://www.legio-ix-hispana.org/
*Last: Hey Dammit! Have you visited the reenactor.Net FORvMS? If not, WHY NOT?
Gett your butt over to: http://www.reenactor.net/forums/index.php right now!
RE: [Cal_Boats] Platic on Stainless Steel Bolts
Gerald Sobel2007-08-08 14:52 UTC
Uh OH! What about them strips of VHS tape I been usin' as tell tales? Besides telling me where to go, is they rottin' me shrouds and causing a vapor trail of toxic plastic break down products and estrogen like hormones dat I be breathin' in? Aaarrrggghhhh...wooof......meow?..GULP!
"Husar, Charlie" <hu… [at] bah.com> wrote: Also, I've heard that those skinny plastic covers that some people put
Behalf Of r good
oxygen,
plates.
>lifespan.
>thinks to inspect?
Yahoo! Groups Links
RE: [Cal_Boats] Was Stainless Steel Bolts - Now Cotter Pins (TD)
Downing, Thomas2007-08-08 15:53 UTC
Thanks, that would be the solution. I wonder if I can get
left and right stainless wing-nuts?
I thougjht about using clips instead of cotters, but didn;t
as that would mean tapping the turnbukles, which would
defeat the purpose.
So far, turnbuckles turning hasn't been a problem for me -
I check my rig tension every couple of weeks, as I sail a few
times a week.
td
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of Husar, Charlie
Sent: Wednesday, August 08, 2007 9:44 AM
Subject: [Cal_Boats] Was Stainless Steel Bolts - Now Cotter Pins (TD)
Tom, get left handed and right handed nuts to put outside the turnbuckle barrels on the shrouds. You tighten these in place, but they can be eased to redo rig. With no cotters or nuts, the turnbuckles will rotate themselves and loosen. The nuts solve the problem and still readily permit adjustment. The nuts should be fine threads (depends on your shrouds). If your boat store does not have the nuts, McMaster-Carr in NJ is a great on-line source for that and many stainless needs. Sell in small qtys with very quick general shipping. I get mine in one day with cheapest shipping method. I own no stock or interest in the place - just get great service.
For All: Note that I retiled the mail and deleted a bunch of previous stuff. This allows people to more readily track topics of interest, and keeps the mails to a manageable size. Just a little list discipline that we periodically put out.
Annapolis
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Downing, Thomas
td
DISCLAIMER:
r p2007-08-08 16:09 UTC
Just my two cents, but it is realy fun to approach the dock under control. Everyone has time to do their job and if they flub tossing the line, which my wife can't yet figure out, we still have plenty of time to retry it, and even if it never works the boat just slides into place.
I have just been sailing for a dozen years and the more I sail the slower I want to go in tight situations.
Rich Pinkowitz
Cal 39, Tantrum
Cotuit, MA
Behalf Of r good
oxygen,
plates.
>lifespan.
>thinks to inspect?
Yahoo! Groups Links
Ready for the edge of your seat? Check out tonight's top picks on Yahoo! TV.
David W. Owen2007-08-08 16:19 UTC
Jerry, you been breathing in something more than hormones, my friend. LOL.
Wilkie
Of Gerald Sobel
Sent: Wednesday, August 08, 2007 7:52 AM
Subject: RE: [Cal_Boats] Platic on Stainless Steel Bolts
put
the
From: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>
[mailto:Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com> ] On
Behalf Of r good
To: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>
oxygen,
backing
plates.
Kits
<mailto:jeffbum1%40yahoo.com> >
have
and
a
>lifespan.
rigging
key
>thinks to inspect?
chance
<http://club.live.com/home.aspx?icid=CLUB_hotmailtextlink>
Yahoo! Groups Links
RE: [Cal_Boats] Plastic on Stainless Steel Bolts
Husar, Charlie2007-08-08 16:38 UTC
I'm worried that the wind stresses on Jerry's tape on the shrouds will
cause uneven loads on the chainplates, and ultimately cause his carbon
fiber hull to crack from the torque. Jerry, hope your boat does not
sink.
Behalf Of David W. Owen
Sent: Wednesday, August 08, 2007 12:20 PM
LOL.
Wilkie
Behalf Of Gerald Sobel
people put
for the
On
Behalf Of r good
no
oxygen,
it.
replacing
backing
plates.
swages.
Kits
bolt have
them. I
should
engineer and
has a
>lifespan.
rigging
there key
>thinks to inspect?
chance
Yahoo! Groups Links
Yahoo! Groups Links
Re: [Cal_Boats] Cracked Sweges was Re: Stainless Steel Bolts
Gerald Sobel2007-08-10 02:57 UTC
Jeff watch out for sweges that get salt water seeping into them, can't drain or be flushed out, and consequently crack in half-wards when the ends of the rigging wires start to rust.
I found that on my forestay and replaced the whole assembly.
slickbutfoxbuger <fi… [at] aol.com> wrote:
hi, Jeff;
response to you.
wire.....
question.
fiver.......
and
> lifespan.
rigging
> thinks to inspect?
RE: [Cal_Boats] Cracked Sweges was Re: Stainless Steel Bolts
Husar, Charlie2007-08-12 01:49 UTC
Hi, Jerry. For All: Make sure to use open barrel turnbuckles. the
closed barrel variety (original on many CALs) build up water and rust
(among other problems).
Sent: Thursday, August 09, 2007 10:57 PM
Subject: Re: [Cal_Boats] Cracked Sweges was Re: Stainless Steel Bolts
hi, Jeff;
in my
response to you.
and i
wrong
do to
is
in
inside of
fastener
my book.
before
life,
things as
it if
builder; 43
turn-buckles and
use,
snapped
wire.....
north-coast
your
question.
fiver.......
<mailto:Cal_Boats%40yahoogroups.com> , "Jeff Baumgardner" <jeffbum1@...>
bolt have
them. I
should
engineer
and
has a
> lifespan.
rigging
there key
> thinks to inspect?
