14 messages2007-09-08 03:16 through 2007-09-11 14:27 UTC
Oil Anchor Lights--Enough Light
Travis2007-09-08 03:16
I'm on a lake and the masthead anchor light is way too high for the
powerboaters racing across the lake to see. I've been thinking about
getting an oil lamp and hanging from the forestay. I see Weems &
Plath and Den Haan lamps that are allegedly "anchor lamps." However,
on West Marine's site they have a disclaimer: "not USCG approved for
navigation/anchoring."
Does anyone use these oil lamps for anchoring? If so how effective
are they?
Travis
Re: Oil Anchor Lights--Enough Light
Neil McBride2007-09-08 03:24
I went to Home Depot and purchased a couple of rechargable garden
lights. I hung them on my boat and leave them there all the time.
Provide lots of light for those pesky things buzzing around on the
water.
Neil
Victoria
the
about
However,
for
effective
> are they?
> Thanks,
> Travis
Re: [Cal_Boats] Oil Anchor Lights--Enough Light
Matt Beland2007-09-08 04:07 UTC
Coast Guard rules state that you must have one 360degree visible white light,
plus "working or cabin lights as required" for visibility. Those oil lamps
aren't usable as the single anchor light, but as additional lights, they'll
work just fine.
RE: [Cal_Boats] Oil Anchor Lights--Enough Light
r good2007-09-08 06:52 UTC
I would keep the original anchor light in good repair and used when
anchoring, to stay legal. Then add several solar powered lights. Newer
ones are pretty bright. They can be hung from boom, lifelines, etc.
Several lights make you look bigger and you can find yoru way back in the
dark. Also, my bride used one to read the combination for re-entry to the
boat the other night. No oil, no fire risk, no batteries to replace or
recharge.
>From: "Travis" <tr… [at] sbcglobal.net>
>Subject: [Cal_Boats] Oil Anchor Lights--Enough Light
>Date: Sat, 08 Sep 2007 03:16:28 -0000
>are they?
>Thanks,
>Travis
Kick back and relax with hot games and cool activities at the Messenger
Caf�. http://www.cafemessenger.com?ocid=TXT_TAGHM_SeptHMtagline1
Re: [Cal_Boats] Pesky Buzzing things, was:Re: Oil Anchor Lights--Enough Light(Neil)
Gerald Sobel2007-09-08 07:06 UTC
Neil,
Have you considered using a yellow bug light, or instead, better yet, a big fly swatter, for them pesky buzzing things?
Arrggh,
Jerry.
Neil McBride <n-… [at] shaw.ca> wrote: I went to Home Depot and purchased a couple of rechargable garden
water.
Neil
Victoria
the
about
However,
for
effective
> are they?
> Thanks,
> Travis
RE: [SPAM] [Cal_Boats] Oil Anchor Lights--Enough Light
john raxter2007-09-08 11:11 UTC
Our boat came with one of these.
http://www.foreandaftmarine.com/85-452014.htm
The battery has lasted many years and the new ones are light activated to go
off in the morning. We swing ours from the first spreader on the burgee
halyard at dusk. Thinking it is more visible to any fast power boat
cruising through the anchorage, I sleep better.
YMMV
John
Of Travis
Sent: Friday, September 07, 2007 11:16 PM
Subject: [SPAM] [Cal_Boats] Oil Anchor Lights--Enough Light
are they?
Travis
Harleigh Ewell2007-09-08 13:57 UTC
I had one of these Guest lights when I had a Catalina 25, and it did the
job. I did get hassled by the DNR one evening when I had it rigged and it
didn't turn on by sunset (although there was still plenty of light). I
ended up turning on the steaming light to satisfy the DNR (go figure?) until
it got dark enough to activate the photoelectric switch. (It couldn't be
turned on manually.)
Also, I do not think these lights are bright enough to technically meet the
USCG requirements for anchor lights. This is implied in their ad where they
state it is suitable for "designated anchor areas," which IIRC do not
require anchor lights. If I'm right about all this, the wording in their ad
strikes me as being a little sharp. Nevertheless, this is a practical way
to provide for a low-mounted light in addition to a masthead light or,
except for the legality (brightness and 360 deg. visibility), as a
stand-alone light. Nobody ever complained about that.
Harleigh Ewell
Cal 31
Of john raxter
Sent: Saturday, September 08, 2007 7:12 AM
Subject: RE: [SPAM] [Cal_Boats] Oil Anchor Lights--Enough Light
http://www.foreanda <http://www.foreandaftmarine.com/85-452014.htm>
Chris Campbell2007-09-10 12:51 UTC
> are they?
Travis:
I've never used those lamps but have used an old kerosene lamp, pulled
partway of the forestay using the spinnaker halyard. This lets you put
the light at a height that will be effective.
You might also consider the LED light made by Davis--it's portable. It
plugs into a cigarette lighter receptacle (the car makers call them
power points now?). You can hang it where you want. A photoelectric
on/off switch is an option when you buy it. You could hang this one low
and it won't use much electricity, either.
Re: [SPAM] [Cal_Boats] Oil Anchor Lights--Enough Light
Chris Campbell2007-09-10 13:18 UTC
> meet the USCG requirements for anchor lights. This is implied in
> their ad where they state it is suitable for "designated anchor
> areas," which IIRC do not require anchor lights.
I think that the USCG specs for anchor lights are a standard "one size
fits all" rule. That is, they're designed to assure adequate visibility
in all circumstances. Nothing wrong with that, since the rules are
designed to avoid collisions in all circumstances. But as a practical
matter, most of us anchor in selected circumstances--places that are
protected and where we won't be encountering commercial vessels or other
large boats that need a mile's visibility so they can avoid us. Our
anchor lights are there so other slow-moving craft don't bump into us.
My Cal lies on a mooring just outside the designated mooring area here.
I don't use an anchor light because there are lots of other boats
around mine. My liability worries are diminished because my boat is on
one of the innermost moorings. A crazed powerboater would have to plow
through a field of larger boats to reach mine. I view them as
sacrificial vessels.
Randy Alcorn2007-09-11 05:17 UTC
Hi Travis,
I use the oil lantern out here at the islands. I sail the Channel Islands and spent many a night under the same oil lantern.
I bought it thinking it would be maintenance free.
Here are my pet peeves;
I have hung it from the forestay and the down haul; it has come apart and broke into little pieces. It twists together and under pressure, with rocking in the waves all night it has a tendency to untwist and crash on the deck. I use candle wax so it did not catch everything on fire.
I have replaced the smoke dome and internal globe(??) the little thing that prevents the wind from blowing out the flame behind the forensnal lens.
Now I hang it from the spreaders and I am not liking it either. Dave Paulson can tell you a story about a guy who swam to his boat in the middle of the night.
If you do not use it for a period of time, just because it looks nautical, empty the oil out of it. The wick draws the oil up and the oil collects on the reservoir then drips all over the place.
Now, what would I recommend?
I see a lot of those garden lamps that are solar charged, they last about 10 hours and put out a decent light. I just bought one for my boat and have a fishing pole holder on the stern rail that I slide the base into. However, I just got back from the islands and thinking about what you are asking, mast head anchor lights stand out pretty much against a dark sky.
But, what really stood out and was really obnoxious was a LED lantern that hung from the end of someones boom.
You could see it from all over the anchorage, and I liked it cause you can adjust it, it was solar charged and it was simple.
I can ask him where he got it and tell you.
But it was bright and we had to ask him if he could turn it down and he did a couple of notches.
Randy
CAL 2-29
Out Patient
Channel Islands Ca
are they?
Travis
Boardwalk for $500? In 2007? Ha!
Play Monopoly Here and Now (it's updated for today's economy) at Yahoo! Games.
Marsh Wise2007-09-11 05:52 UTC
yes, ask him please :-)
> that hung from the end of someone's boom.
> Randy
> CAL 2-29
> Out Patient
> Channel Islands Ca
Marsh Wise
Webmaster:
-reenactor.Net: http://www.reenactor.net/
-Foresthill.us: http://www.foresthill.us/
-Legio IX Hispana Penna: http://www.reenactor.net/units/legio_ix_penna/
- 17. Luftwaffe Feld-Division <http://www.reenactor.net/units/17lwfd/>
Assistant Webmaster:
-VAQ-33 Squadron site: http://www.reenactor.net/vaq-33/
Proud Member (meaning I can just have fun...)
-LEGIO IX HISPANA COH III Penna Chapter: http://www.legio-ix-hispana.org/
*Last: Hey Dammit! Have you visited the reenactor.Net FORvMS? If not, WHY NOT?
Gett your butt over to: http://www.reenactor.net/forums/index.php right now!
tr… [at] sbcglobal.net2007-09-11 12:33 UTC
Hi Randy and all,
Thanks for the oil lamp stories. Before the thread, I had one ordered, but based on the feedback, I've now cancelled the order. No oil for me! I would be interested in the solar charged LED light you mentioned.
Travis
Sent: Tuesday, September 11, 2007 12:17 AM
Subject: Re: [Cal_Boats] Oil Anchor Lights--Enough Light
Hi Travis,
But, what really stood out and was really obnoxious was a LED lantern that hung from the end of someone's boom.
Randy
CAL 2-29
Out Patient
Channel Islands Ca
are they?
Travis
Bruce Stirling2007-09-11 12:35
I think we are all interested in the solar LED light!
--- In Ca… [at] yahoogroups.com, <travlin74@...> wrote:
> Hi Randy and all,
mentioned.
> Travis
> From: Randy Alcorn
> Hi Travis,
everything on fire.
forensnal lens.
> Randy
> CAL 2-29
> Out Patient
> Channel Islands Ca
about
However,
for
> are they?
> Thanks,
> Travis
Yahoo! Games.
RE: [Cal_Boats] Re: Oil Anchor Lights--Enough Light
Husar, Charlie2007-09-11 14:27 UTC
Bruce, guess you have to leave it out there during the day to recharge.
What would really be neat is a lamp that provides its own
opto-electrical recharge capability. The true self licking popsicle.
Behalf Of Bruce Stirling
Sent: Tuesday, September 11, 2007 8:36 AM
Subject: [Cal_Boats] Re: Oil Anchor Lights--Enough Light
> Hi Randy and all,
mentioned.
> Travis
> From: Randy Alcorn
> Hi Travis,
everything on fire.
forensnal lens.
against a dark sky.
> Randy
> CAL 2-29
> Out Patient
> Channel Islands Ca
the
about
However,
for
> are they?
> Thanks,
> Travis
Yahoo! Games.
Yahoo! Groups Links
