9 messages2005-11-03 20:23 through 2007-09-14 06:07 UTC
Transpac
mtkennedy12005-11-03 20:23
Reading the e-mails is fun and brings back memories. I made an 8 mm movie of the race in
1981. I had it transferred to VHS and I'm now busy restoring it with Final Cut EXpress. I also
have all the newspaper clippings from the race that one of my patients saved for me. The
idea is to learn enough editing to use the clippings as date marks to divide the day's
segments. If I ever get finished, and Final Cut has some powerful features that may allow me
to restore some spots that have faded in 25 years, I'm going to cut DVDs for my kids and the
guys who went on the race with me. They made fun of me for shooting the film but all came
slinking around for copies later. It has a sound track from a microphone plus I dubbed in the
popular songs from that summer.
If you have some video, and I think you mentioned you did, save it and maybe we can do
some video clips on the site. My film was not on a Cal 40 but the scenes are pretty good of
trade wind clouds and sail changes. That was a fast year and even in daytime you can see
how fast we are going.
When the day comes if anyone here wants a copy for vicarious thrills, let me know. I don't
know which will come first, the book or the movie. I have a rough cut that plays on my
laptop.
Mike Kennedy
Conquest Cal 40 # 96
Transpac
mtkennedy12007-07-18 15:14
Some of you might be interested in following the progress of Transpac. The Cal 40s,
especially Far Far and Psyche, are showing the way. You can follow them on the Transpac YC
web site. Go to www.transpacificyc.org and, on the left, select "track charts." The Cal 40s are
in division 6. All the boats carry transponders so the positions are updated automatically. Far
far is the farthest south and that is paying off. The TP 65 Rosebud has followed them down
there and may beat Pyewacket for the Barn Door trophy. Psyche and Far Far are the farthest
south boats and doing very well. California Girl stayed a bit more conservative and doesn't
seem to have done as well. This is a year to go south.
The reason why they are down there can be seen by clicking on "weather" on the TPYC site
and then selecting "passage weather." This shows the wind pattern. The high is not there this
year and the wind is south. Of course, you can go too far south and that is what makes races.
Mike Kennedy
Marine Refrigeration
Richard Dozier2007-09-12 19:38 UTC
Cal Listees:
My refrigeration unit--an Adler Barbour one I
guess to be about 20 yrs old--has stopped working. When I turn it on
and adjust the thermostat located near the evaporator, the compressor
(located aft) comes on, but there is no cooling. One of my dockmates
says that it merely needs recharging, but no one on our lake seems to
do this sort of thing.
Is this something I can do myself, or must it be
done by a professional? For that matter, I don't really know what kind
of refrigerant it uses. Is it likely to be freon, ammonia, or
something else? Any information or advice you can pass along would be
much appreciated.
Richard Dozier
"Pantera" Cal 40 #110
Re: [Cal_Boats] Marine Refrigeration
Carl2007-09-13 11:00 UTC
I just went through this last summer. The older Cold Machines use an older
refrigerant that is not compatible with the new stuff. I forgot all the
numbers here. Adler Barbour was helpful in explaining all this. It turned
out that to have the system purged and refilled was real expensive. The
other problem was the connections were not easily disconnected, and there
wasn't any port to recharge the unit. I ended up replacing the whole unit.
The new one has a port to recharge them. It was an easy replacement, only
took a couple of hours. All the piecec fit where the old ones were. The best
thing, the new unit worked a lot better, less power consumption and better
cooling. With a unit as old as yours, I would recommend replacement.
Carl
On 9/12/07, Richard Dozier <dd… [at] verizon.net> wrote:
> Cal Listees:
Walter2007-09-13 14:20 UTC
The refrigerant is probably R-12. It is difficult to find in the US now
and very expensive. I am told you can buy it in Mexico if you are near
the border. It used to be available in 1 lb. cans.
If it is a very slow leak you can buy a tap that will pierce a line
(usually the suction line somewhere) and it will furnish you with a
charging port. The whole procedure is not terribly complicated (well to
me, anyway). If the gas has leaked out it will leak out again but if it
is slow enough it might make it worthwhile.
But be aware that though the compressor runs, the valves may be damaged
and this is why it is not cooling. It is very easy to determine this if
one has the tools. If you don't now a "reefer guy" to assist you with
this perhaps I can write something up to guide you and source some
inexpensive gear to use.
You might be able to find assistance from an appliance repair shop that
does house calls. Anyone that works on window a/c's or refrigerators can
handle it
Let me know.
Walter MacArthur
'70 Cal 34 "Tejana"
Richard Dozier wrote:
> Cal Listees:
> much appreciated.
> Richard Dozier
steve honour2007-09-13 20:14 UTC
Another consideration:
Leaking R-12 is bad for the atmosphere and contributes to global warming. That is why the stuff is no longer available in the US. If there is a leak and you intend to keep the system, it is a moral obligation to future humans to make certain that the leak is detected and repaired.
handle it
Let me know.
Walter MacArthur
'70 Cal 34 "Tejana"
> Cal Listees:
> much appreciated.
> Richard Dozier
Be a better Heartthrob. Get better relationship answers from someone who knows.
Yahoo! Answers - Check it out.
Duane Knize2007-09-13 20:40 UTC
Steve, Walter,
R-12 causes depletion of the ozone layer. It should actually help
global warming.
I think that a qualified refrigeration technicion could recover the
R-12 from the old system.
I wonder what they do with it.
It would either need to be chemically changed or it will eventually
get into the environment anyway.
Duane
>handle it
>Let me know.
>Walter MacArthur
>'70 Cal 34 "Tejana"
> > Cal Listees:
> > much appreciated.
> > Richard Dozier
><http://us.rd.yahoo.com/evt=48255/*http://answers.yahoo.com/dir/_ylc=X3oDMTI5MGx2aThyBF9TAzIxMTU1MDAzNTIEX3MDMzk2NTQ1MTAzBHNlYwNCQUJwaWxsYXJfTklfMzYwBHNsawNQcm9kdWN0X3F1ZXN0aW9uX3BhZ2U-?link=list&sid=396545433>Get
Duane J. Knize
SAIC
Office: 858-826-6544
Cell: 858-220-3021
kn… [at] saic.com
Walter2007-09-14 04:00 UTC
Actually, it is available in the U.S. (legally) but there is more money
to be made by converting to 134a, etc.
I have to wonder about the difference in "damage" to the atmosphere of
the escape of a few ounces of freon versus the manufacturing cost
(environmental) of a new system. I suspect you are referring to the
"ozone hole" theory which, if you will pardon the pun, has gaping holes
in it. It is unfortunate that politics takes precedence over facts.
Walter
> and repaired.
> US now
> near
> (well to
> if it
> damaged
> this if
> that
> refrigerators can
> handle it
> Let me know.
> Walter MacArthur
> '70 Cal 34 "Tejana"
> > Cal Listees:
> compressor
> seems to
> what kind
> would be
> > much appreciated.
> > Richard Dozier
> <http://us.rd.yahoo.com/evt=48255/*http://answers.yahoo.com/dir/_ylc=X3oDMTI5MGx2aThyBF9TAzIxMTU1MDAzNTIEX3MDMzk2NTQ1MTAzBHNlYwNCQUJwaWxsYXJfTklfMzYwBHNsawNQcm9kdWN0X3F1ZXN0aW9uX3BhZ2U-?link=list&sid=396545433>from
> someone who knows.
Marsh Wise2007-09-14 06:07 UTC
"moral obligation" :-Þ Oh, I so won't go there.
>Walter
>>and repaired.
>> US now
>> near
>> (well to
>> if it
>> damaged
>> this if
>> that
>> refrigerators can
>> handle it
>> Let me know.
>> Walter MacArthur
>> '70 Cal 34 "Tejana"
>> > Cal Listees:
>> compressor
>> seems to
>> what kind
>> would be
>> > much appreciated.
>> > Richard Dozier
>>someone who knows.
>Yahoo! Groups Links
Marsh Wise
Webmaster:
-reenactor.Net: http://www.reenactor.net/
-Foresthill.us: http://www.foresthill.us/
-Legio IX Hispana Penna: http://www.reenactor.net/units/legio_ix_penna/
- 17. Luftwaffe Feld-Division <http://www.reenactor.net/units/17lwfd/>
Assistant Webmaster:
-VAQ-33 Squadron site: http://www.reenactor.net/vaq-33/
Proud Member (meaning I can just have fun...)
-LEGIO IX HISPANA COH III Penna Chapter: http://www.legio-ix-hispana.org/
*Last: Hey Dammit! Have you visited the reenactor.Net FORvMS? If not, WHY NOT?
Gett your butt over to: http://www.reenactor.net/forums/index.php right now!
