Re: [Cal_Boats] audio hum
Peter,
Glad to help with your alternator issue, moving on;
In another life I was musician/studio engineer, now I am doing boat
electrical systems. So, this kind of calls for a bit of both areas, I think.
You are correct in that the square wave is part of the problem, power
supplies for audio circuits filter well when dealing with the ripple waveform
coming out of a sine wave powered unit. The problem with square waves is that
there are higher even order harmonics being generated along with the fundamental
60 Hz waveform. Without getting into a technical discussion of how the filters
work at various multiples of the fundamental frequencies, let's just say
square waves and audio can be problematic...
The other issue is that the ground on the laptop and the stereo system
ground are at differing potentials...Plus, chassis ground in the laptop may not be
the same as the audio ground is in the laptop.
You can try running a separate wire from the laptop chassis to the stereo
chassis, may help, may not...
Another option would be to obtain a couple of miniature audio isolation
transformers (one for left and one for right channel) and electrically isolate
the laptop from the stereo. In the pro stuff I was doing we used a lot of low
impedance (impedance being referred to as "Z")and high to low Z transformers
for matching input and output impedances. We used to carry cases of various
plug-in transformers for microphone and guitar cables to recording consoles.
Low Z typically being 600 ohms and high Z anywhere from 10K ohms to 50K ohms. I
am not a car audio expert, but I would guess a 1 to 1 ratio low Z would
work...they are cheap, (you don't need the entire adaptors like we used, just the
transformer itself) usually a couple of bucks each if I recall, and you can
cut a standard audio cable and wire them in the middle. If it works, make up
a little case for them, if not, you are not out much money.
If you are totally confused, then I have done my job...
What is the old saying? "If you can't impress 'em with your knowledge,
dazzle 'em with your BS"?
Anyway, hope this is at least somewhat helpful...
Best-Mark
Mark and Terry Rogers
"Seirenia", 1966 Cal 36 hull #22
Newburyport, Ma
Mobile Marine Electrical Services/MMES Custom Panels
www.wewireboats.com
ya… [at] aol.com
************************************** See what's new at http://www.aol.com
