7 messages2007-09-25 18:31 through 2007-09-25 22:07
diesel wouldn't stop
Jeff Baumgardner2007-09-25 18:31
This weekend while sailing I started the diesel. When I tried to hit
my "off" button, the engine kept running as if the button wasn't
pressed. I decided to just let it run till I got back to the dock. When
I arrived at the dock it shut off just as it should.
My instrument configuration consists of a pull swith to turn on the
ignition, gauges, etc. which stays out. Then there is one starter
button and one off button.
Cal 39 w/ a perkins 4108.
Any ideas?
Re: [Cal_Boats] diesel wouldn't stop
Marsh Wise2007-09-25 18:40 UTC
Doesn't your diesel have a manual kill switch? That's really important
as sometimes they WON'T shut off. My wife's old Mercedes had a problem
w/ the vaccuum system and for a bit, I used to have to use the manual kill.
Marsh
>Any ideas?
>Yahoo! Groups Links
Marsh Wise
Webmaster:
-reenactor.Net: http://www.reenactor.net/
-Foresthill.us: http://www.foresthill.us/
-Legio IX Hispana Penna: http://www.reenactor.net/units/legio_ix_penna/
- 17. Luftwaffe Feld-Division <http://www.reenactor.net/units/17lwfd/>
Assistant Webmaster:
-VAQ-33 Squadron site: http://www.reenactor.net/vaq-33/
Proud Member (meaning I can just have fun...)
-LEGIO IX HISPANA COH III Penna Chapter: http://www.legio-ix-hispana.org/
*Last: Hey Dammit! Have you visited the reenactor.Net FORvMS? If not, WHY NOT?
Gett your butt over to: http://www.reenactor.net/forums/index.php right now!
RE: [Cal_Boats] diesel wouldn't stop
Bruce Stirling2007-09-25 18:58 UTC
I had a similar problem with my outboard engine. I have a kill switch
mounted in the cockpit, but no matter what I did with the switch, the engine
continued to run. I pulled it apart and found corrosion on the wires
leading to and from the switch. Cleaned them up and reattached and all was
well again.
Of Jeff Baumgardner
Sent: Tuesday, September 25, 2007 11:32 AM
Subject: [Cal_Boats] diesel wouldn't stop
Any ideas?
Mark Alan Stahnke (MAS Consulting)2007-09-25 19:12 UTC
I haven't run into the won't shut off yet, but what comes to mind is that in a jam you can always turn off the fuel cock on your tank and run out of fuel shut off. Then you will have a time getting her restarted because of the air out of the lines, unless you have installed a hand squeeze pump between the tank and (in my case Racor) fuel filter. The squeeze pump allows you to push all the air out of the lines and back into the tank. You will still have to deal with the first problem!
Mark
Cal 2-29 Hull #618
San Pedro
Sent: Tuesday, September 25, 2007 11:40 AM
Subject: Re: [Cal_Boats] diesel wouldn't stop
Doesn't your diesel have a manual kill switch? That's really important as sometimes they WON'T shut off. My wife's old Mercedes had a problem w/ the vaccuum system and for a bit, I used to have to use the manual kill.
Marsh
Any ideas?
Yahoo! Groups Links
Marsh Wise
Webmaster:
Duane Knize2007-09-25 19:13 UTC
Jeff,
There should be a short cable protruding out from the front of the
4108 (near the top port side) that you can pull as backup to the solenoid.
I've had some intermittent problems with the kill solenoid. My lessons learned:
Check the solenoid electrical connections - spade lugs. Make sure
they are a tight fit.
My solenoid itself was sticking. I cleaned it with WD 40 -- bad. the
WD 40 makes the nylon bushings swell up and made the sticking worse.
Eventually the WD 40 evaporated and the mechanism loosened up.
Use detergent to clean the plastic parts. Solvent/WD40 would be OK on
the housing but make sure you dry it before re-assembly.
I hope this helps.
Duane
By the way what is your hull ID number?
Duane & Lynn Knize
Marlyn, 1978 Cal 2-39, #18
Berthed: Emeryville, CA
>Any ideas?
Duane & Lynn Knize
Chris Campbell2007-09-25 19:45 UTC
I'm not a marine diesel expert but they will run as long as they have
air & fuel. I assume that your "off" button is a fuel pump kill
switch. Sounds like it's not working. When diesels are excessively
worn, they can suck crankcase oil past the rings or from the blower
bearings and run on that. That's why they have a manual air valve for
emergency shutoff.
Re: diesel wouldn't stop, addition of priming pump.
Jeff Baumgardner2007-09-25 22:07
That would have been one of my last resort options as I got to the
dock.
I actually intalled an electric pump on a separate switch(that I
leave off) between the Raycor and the engine filter. Works like a
charm. I actually didn't need to bleed the injectors last time. The
electric pump did it all. I had a blockage from something in the tank
once, So I wanted the least ammount of obstructions before the
raycor, thats why I installed it after the raycor.
--- In Ca… [at] yahoogroups.com, "Mark Alan Stahnke \(MAS
the first problem!
> Mark
> Cal 2-29 Hull #618
> San Pedro
> From: Marsh Wise
> Marsh
hit
When
> Any ideas?
> Yahoo! Groups Links
> Marsh Wise
> Webmaster:
hispana.org/
not, WHY NOT?
right now!
