7 messages2007-10-01 22:39 through 2007-10-03 05:56 UTC
sheets and haylards
johnraxter2007-10-01 22:39
I am replacing some of the sheets and haylards on my Cal 33. without
going with the new high tech lines at multi dolars per ft. what would
everyone recommend for a new Main sheet. Specs per the '87 owners
manual says 1/2". I have looked on-line for pricing and this size
will run $0.78 per foot to $1.25 in polyester lines. I do not race so
the high tech do not seem to justify the 3x pricing. Does anyone have
a decent argument for the added cost?
So, cheap, sta-set, sta-set-x or xls or hi-tech?
TIA
John
RE: [Cal_Boats] sheets and haylards
ti… [at] ch2m.com2007-10-01 22:53 UTC
Main sheets are constantly trimmed... so I would not worry about
stretching lines.
I look for the line that best suits the feel in my hand, and resists
twisting when going through multiblocks.. a line that has "no lay"
like New England's @ 10mm for a 30' boat... halyards are another
story...
Regatta Braid
View Larger Image
<javascript:openWin('ProductImages/large/regattabraid_lg.jpg', 350, 350,
'no');>
Product Description:
Twelve strand single polyester single braid with spun filament for great
performance and superior handling..
Features:
* Soft
* Durable
* Supple
* Kink free
Applications:
* Mainsheets
* Furling lines
Colors Available:
* White
Lengths Available:
* 600'
Size Weight Tensile
lbs/100' g/m lbs kg
6mm 2.0 29.8 2,500 1,135
8mm 3.0 44.6 3,400 1,544
10mm 3.8 56.5 4,500 2,043
Behalf Of johnraxter
Sent: Monday, October 01, 2007 4:39 PM
Subject: [Cal_Boats] sheets and haylards
TIA
John
Husar, Charlie [USA]2007-10-02 00:20 UTC
Yeah, I was gonna say something like Timm said. 1/2" sounds kind of
fat. Handling is the biggest item, and not to worry a whole lot about
stretch.
Greetings from San Diego.
Behalf Of ti… [at] ch2m.com
Sent: Monday, October 01, 2007 6:53 PM
Subject: RE: [Cal_Boats] sheets and haylards
stretching lines.
story...
Regatta Braid
View Larger Image
'no');>
Features:
* Soft
* Durable
* Supple
* Kink free
Applications:
* Mainsheets
* Furling lines
Colors Available:
* White
Lengths Available:
* 600'
Size Weight Tensile
lbs/100' g/m lbs kg
TIA
John
Re: [Cal_Boats] sheets and haylards
Chris Campbell2007-10-02 13:11 UTC
> stretching lines.
> like New England's @ 10mm for a 30' boat... halyards are another story...
I agree. The mainsheet is perhaps the least critical running rigging
since it's relatively lightly loaded and adjustable. I recall when we
replaced the mainsheet on my other boat many years ago. We moved up a
size just because it was easier on the hands. A lot of iceboats have a
skinny running part spliced to a big fat grab-onto part because you're
usually wearing mittens or gloves and it's always much easier to grasp
a fat line.
Now maybe Timm can tell us about the "resists twisting" thing. "No lay"
means "not three-strand twisted" in my mind. But the Sta-set I use on
the Cal 20 for a mainsheet keeps twisting when it runs through the five
sheaves and one fairlead on my mainsheet setup. Pretty soon one of the
outboard blocks will rotate and then the sheet is twisted around
itself. In light air, you have to push the boom out by hand.
Eventually I untie the end and take the twist out and pretty soon it's
back again.
No, it isn't from coiling the mainsheet for storage. I figure-eight it
instead of coiling and theoretically this should avoid twisting the
line. What's going on here?
Marsh Wise2007-10-02 22:06 UTC
www.ebay.com
>TIA
>John
>Yahoo! Groups Links
Marsh Wise
Webmaster:
-reenactor.Net: http://www.reenactor.net/
-Foresthill.us: http://www.foresthill.us/
-Legio IX Hispana Penna: http://www.reenactor.net/units/legio_ix_penna/
- 17. Luftwaffe Feld-Division <http://www.reenactor.net/units/17lwfd/>
Assistant Webmaster:
-VAQ-33 Squadron site: http://www.reenactor.net/vaq-33/
Proud Member (meaning I can just have fun...)
-LEGIO IX HISPANA COH III Penna Chapter: http://www.legio-ix-hispana.org/
*Last: Hey Dammit! Have you visited the reenactor.Net FORvMS? If not, WHY NOT?
Gett your butt over to: http://www.reenactor.net/forums/index.php right now!
feet2007-10-02 22:36 UTC
I Think the low stretch stuff would be wasted on a mainsheet since there would be minimal stretch due to multiplying effect of the 6:1 or 8:1 tackle you likely have.
I would only use spectra (or other) for stuff like halyards and jib or spin sheets.
An rigger friend of mine once told me there is no point in low stretch lines unless you have a low stretch boat... ie melges or other carbon fiber dingy on steroids. Of course it can be a pain so splice too......
Frank
Cal 31
restless
Re: [Cal_Boats] Nix to Sta-set X, was:sheets and haylards
Gerald Sobel2007-10-03 05:56 UTC
I'd stay away from sta-set X for sheets, the stuff is way too stiff, better to have softer lines that don't kink and jam up in your blocks!!!! I had a friend who had sta-set X in his jib halyards, and in my opinion it was unsatisfactory.
In fact if there is something better than double braid, I'd go for it. My double braid jib halyards, I think they are sta-set, tend to kink and jam. Ick! Some folks said it is better not to "twist-coil" double braid. Better to lay them down in figure eights.
Marsh Wise <ma… [at] reenactor.net> wrote: www.ebay.com
TIA
John
Yahoo! Groups Links
Marsh Wise
Webmaster:
-reenactor.Net: http://www.reenactor.net/ -Foresthill.us: http://www.foresthill.us/ -Legio IX Hispana Penna: http://www.reenactor.net/units/legio_ix_penna/ - 17. Luftwaffe Feld-Division <http://www.reenactor.net/units/17lwfd/> Assistant Webmaster: -VAQ-33 Squadron site: http://www.reenactor.net/vaq-33/ Proud Member (meaning I can just have fun...) -LEGIO IX HISPANA COH III Penna Chapter: http://www.legio-ix-hispana.org/ Netscape Aim/AOL screen name: Sturmkatze Yahoo Messenger screen name: sturmkatze Alteris renumera duplum de quoquo tibi numeraverunt Suppose you were an idiot. And suppose you were a member of Congress.... But then I repeat myself. ~Mark Twain *Last: Hey Dammit! Have you visited the reenactor.Net FORvMS? If not, WHY NOT? Gett your butt over to: http://www.reenactor.net/forums/index.php right now!
