16 messages2007-10-15 21:46 through 2007-10-17 13:23 UTC
Bruce, on your 28...
rickallwein2007-10-15 21:46
Do you have any fittings on your deck near the shroud chainplates?
Specifically about 12" in front of, and 18" behind them. Removing the
old ply core from the deck I found some old holes there that were
filled with caulk and covered with paint, but alas, nothing bolted
there.
I'm imagining they're for the storm and working jib??? The hole in
front of the chainplate is single and the one behind is a larger hole
with 2 smaller holes, one on either side
Thanks, Rick
Re: Bruce, on your 28...
Bruce Stirling2007-10-16 03:13
Rick,
All of the hardware on my deck can be seen on the photos found on this
page: http://www.stirlinglaw.com/cal28/cal28photos/
Not much there. Richard Fuller, owner of Old Flat Top, another 1965
Cal 28, could probably answer some of your questions. He tore his
boat apart and rebuilt it and posted all of the photos online for all
of us to see. He has the original Cal 28 site (at least it was there
before mine). Richard is a group member and probably saw your post,
too. There is a link to his site found on mine somewhere where I list
all individual Cal sites I can find.
Bruce
> there.
> Thanks, Rick
slickbutfoxbuger2007-10-16 03:32
if you don't mind me cutting in here......
my 28 was rigged for racing early on. and there is nothing on her
deck in the spots that you are concerned with........
fiver
--- In Ca… [at] yahoogroups.com, "Bruce Stirling" <bruce@...> wrote:
> Rick,
this
all
there
list
> Bruce
> --- In Ca… [at] yahoogroups.com, "rickallwein" <rickallwein@>
chainplates?
Removing the
> > there.
in
hole
> > Thanks, Rick
Holes in a CAL 28
Husar, Charlie [USA]2007-10-16 13:18 UTC
Several possibilities. There might have been a strap installed for
attaching twingers to control the chute in heavy air. There might have
been some pad eyes for leading back a jib Cunningham or even a jib
furler line. Might the holes match any of these.
The inside overhead of a much raced CAL 25 can look like Swiss cheese as
prior owners have added and taken out doodads to perform various
functions. Rigging is a very personal thing. (I know this statement is
a set-up for the wiseacres.)
Behalf Of Bruce Stirling
Sent: Monday, October 15, 2007 11:14 PM
Subject: [Cal_Boats] Re: Bruce, on your 28...
Rick,
Not much there. Richard Fuller, owner of Old Flat Top, another 1965 Cal
28, could probably answer some of your questions. He tore his boat
apart and rebuilt it and posted all of the photos online for all of us
to see. He has the original Cal 28 site (at least it was there before
mine). Richard is a group member and probably saw your post, too.
There is a link to his site found on mine somewhere where I list all
Bruce
> there.
> Thanks, Rick
rickallwein2007-10-16 18:49
> Do you have any fittings-
Thanks Charlie and Fiver- Your right, they could have been almost
anything, but then where is the storm or working jib supposed to be
sheeted?
Bruce I've seen alot of the recent pics on your site, your boat is a
real beauty! And also some new data on original sails,great stuff!
But even on the original drawing and pictures it doesn't seem to show
this info.
Thanks, Rick
RE: [Cal_Boats] Re: Bruce, on your 28...
Husar, Charlie [USA]2007-10-16 19:04 UTC
Rick, a storm or working jib is usually high cut at the clew, so it
comes back to the block that is used for larger jibs/jennys. There is a
sail called a jib top that has a high clew as a mid size sail and sheets
aft. I think it is supposed to keep the seas from filling a lower
clewed sail. Also gives good visibility under the sail. I have one for
my CAL 40.
I have or had deck sweepers (low clew) No.2 and 90 percent blade jibs.
These require track on the foredeck. The 90 percenter sheeted inside
the shrouds. It is possible that a sail could track through a pad eye
or some such, but the sails we are discussing would normally have higher
clews, and thus trim farther back. Didn't like the blade. Shape did
not seem to be meant for a CAL 25.
Behalf Of rickallwein
Sent: Tuesday, October 16, 2007 2:49 PM
sheeted?
this info.
Thanks, Rick
Yahoo! Groups Links
rickallwein2007-10-16 19:39
Charlie, thanks for the reply, it seems possible that they could have
used the jennoa tracks and winch to sheet the jib, I understand what
your saying about the higher clew, makes sense. I guess a sailmaker,
perhaps Sailrite, would even have some idea if I were to pick up a
used jib that was sized differently.. I saw a C28 down in annapolis in
june but, regretably, didn't have the time to chat with them, and
didn't even think to look for a name on the boat.
Plenty of time though, it's just something that's been on my mind.
Thanks, Rick
http://pronecartcity.com/dasboot/lehiem.html
--- In Ca… [at] yahoogroups.com, "Husar, Charlie [USA]"
> my CAL 40.
> Cheers
> Charlie
> -----Original Message-----
> sheeted?
> this info.
> Thanks, Rick
> Yahoo! Groups Links
John Boyce2007-10-16 22:23 UTC
I once sailed on a CAL-28 that had a spinnaker staysail that was supposed to
fill the area down low under the chute. I think it was sheeted near the
chaiinplates. It was notably successful in keeping the crews attention away
from the spinnaker and thus slowed the boat down a great deal.
Of Husar, Charlie [USA]
Sent: Tuesday, October 16, 2007 2:05 PM
Subject: RE: [Cal_Boats] Re: Bruce, on your 28...
my CAL 40.
From: Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com
[mailto:Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com] On
To: Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com
--- In Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com,
sheeted?
this info.
Thanks, Rick
Yahoo! Groups Links
Bruce Stirling2007-10-16 23:28 UTC
Fiver,
You can always cut in. Fiver is in the process of remaking her Cal 28, too,
but to a standard never imagined by Jensen Marine. I anxiously await her
progress.
Bruce
Of slickbutfoxbuger
Sent: Monday, October 15, 2007 8:33 PM
fiver
> Rick,
this
all
there
list
> Bruce
chainplates?
Removing the
> > there.
in
hole
> > Thanks, Rick
Bruce Stirling2007-10-17 01:02 UTC
Thanks, Rick. There are several photos of Cal 28s found online in for sale
ads I borrowed. If I see a good looking Cal boat I borrow the photo for
"fair use" instructional purposes to educate the world about Cals. Like I
know anything . . . . Build a web site and they will come! So some of the
photos you liked may have been the boats of others. There is a really nice
one from British Columbia named Island Fling. Looks like the raised deck is
covered with some kind of wood, as is the cockpit, kind of like the bigger
Cals. But on behalf of all displayed boats, they thank you.
Here is Island Fling. Anyone know anything about her? How much hassle to
do the woodwork like this? Cost mucho?
Of rickallwein
Sent: Tuesday, October 16, 2007 11:49 AM
sheeted?
this info.
Thanks, Rick
Bruce Stirling2007-10-17 01:21 UTC
Or is that just paint?
Of Bruce Stirling
Sent: Tuesday, October 16, 2007 6:02 PM
Of rickallwein
sheeted?
this info.
Thanks, Rick
Re: [Cal_Boats] Re: Bruce, on your 28...
Marsh Wise2007-10-17 02:33 UTC
Me too.... I'm kinda curious where the Harpoon missle laucher and
Phalanx gun will go :-)
Bruce Stirling wrote:
> Fiver,
> 28, too, but to a standard never imagined by Jensen Marine. I
> anxiously await her progress.
> Bruce
> Behalf Of slickbutfoxbuger
> fiver
> --- In Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>,
> > Rick,
> this
> <http://www.stirlinglaw.com/cal28/cal28photos/>
> all
> there
> list
> > Bruce
> <mailto:Cal_Boats%40yahoogroups.com>, "rickallwein" <rickallwein@>
> chainplates?
> Removing the
> > > there.
> in
> hole
> > > Thanks, Rick
Marsh Wise
Webmaster:
-reenactor.Net: http://www.reenactor.net/
-Foresthill.us: http://www.foresthill.us/
-Legio IX Hispana Penna: http://www.reenactor.net/units/legio_ix_penna/
- 17. Luftwaffe Feld-Division <http://www.reenactor.net/units/17lwfd/>
Assistant Webmaster:
-VAQ-33 Squadron site: http://www.reenactor.net/vaq-33/
Proud Member (meaning I can just have fun...)
-LEGIO IX HISPANA COH III Penna Chapter: http://www.legio-ix-hispana.org/
*Last: Hey Dammit! Have you visited the reenactor.Net FORvMS? If not, WHY NOT?
Gett your butt over to: http://www.reenactor.net/forums/index.php right now!
snagging Cal pix (Bruce)
Marsh Wise2007-10-17 02:38 UTC
I do the same thing... if I see a Cal 25 pix, I save it... seen some
neat stuff doing that.
Marsh
> sale ads I borrowed. If I see a good looking Cal boat I borrow the
> photo for "fair use" instructional purposes to educate the world about
> Cals. Like I know anything . . . . Build a web site and they will come!
Wood on CAL 28 and Sail Stuff (Bruce)
Husar, Charlie [USA]2007-10-17 10:34 UTC
May not be wood, Bruce, but if it is, don't even think about it. Will
be painful forever more.
Note the high cut jib that blocks back in the cockpit. Also note that
you would like to have your reef lines pull back some on the main (to
flatten the foot) rather than having the lines come straight down as
shown.
Sent: Tuesday, October 16, 2007 9:02 PM
come! So some of the photos you liked may have been the boats of
others. There is a really nice one from British Columbia named Island
Fling. Looks like the raised deck is covered with some kind of wood, as
is the cockpit, kind of like the bigger Cals. But on behalf of all
to do the woodwork like this? Cost mucho?
sheeted?
this info.
Thanks, Rick
RE: [Cal_Boats] Reefing lines (was Wood on CAL 28)
Downing, Thomas2007-10-17 12:00 UTC
I dunno if it is a 'done thing' or not, but I take a bit different approach
to controling the foot when reefed. I have my flattener hooked into
the flattener cringle by a cunningham hook. When I reef I just move
the hook tot the reef cringle, and control the foot that way. Saves
tinkering with the ideal location of the reef line without the alternative
of the placing the reef cheek block on a track. Both the leach reef
and the flattener run through the boom and back to the cockpit.
td
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of Husar, Charlie [USA]
Sent: Wednesday, October 17, 2007 6:34 AM
Subject: [Cal_Boats] Wood on CAL 28 and Sail Stuff (Bruce)
May not be wood, Bruce, but if it is, don't even think about it. Will be painful forever more.
Note the high cut jib that blocks back in the cockpit. Also note that you would like to have your reef lines pull back some on the main (to flatten the foot) rather than having the lines come straight down as shown.
Recent Activity
2
New <http://groups.yahoo.com/group/Cal_Boats/members;_ylc=X3oDMTJnMjN2amNpBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDdnRsBHNsawN2bWJycwRzdGltZQMxMTkyNjE3MzY5> Members
Visit <http://groups.yahoo.com/group/Cal_Boats;_ylc=X3oDMTJmdGZudmZnBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDdnRsBHNsawN2Z2hwBHN0aW1lAzExOTI2MTczNjk-> Your Group
Y! Sports for TV
Access <http://us.ard.yahoo.com/SIG=12j1lv4b9/M=493064.10729671.11699924.9977693/D=groups/S=1705065792:NC/Y=YAHOO/EXP=1192624569/A=4767085/R=0/SIG=127pn01k0/*http://us.rd.yahoo.com/evt=49021/*http://digitalhome.yahoo.com/sports> it for free
Get Fantasy Sports
stats on your TV.
Yahoo! News
Odd <http://us.ard.yahoo.com/SIG=12jlfnvn1/M=493064.10729659.11333350.8674578/D=groups/S=1705065792:NC/Y=YAHOO/EXP=1192624569/A=3848614/R=0/SIG=12t4qk00m/*http://news.yahoo.com/i/757;_ylt=A9FJqYzfwK5EFCQAswis0NUE;_ylu=X3oDMTA3NW1oMDRpBHNlYwM3NTc-> News
You won't believe
it, but it's true
Yahoo! Finance
It's <http://us.ard.yahoo.com/SIG=12jo6799d/M=493064.10729649.11333340.8674578/D=groups/S=1705065792:NC/Y=YAHOO/EXP=1192624569/A=4507179/R=0/SIG=12de4rskk/*http://us.rd.yahoo.com/evt=50284/*http://finance.yahoo.com/personal-finance> Now Personal
Guides, news,
advice & more.
<http://portal.mxlogic.com/images/transparent.gif>
DISCLAIMER:
Chris Campbell2007-10-17 13:23 UTC
> *From:* Ca… [at] yahoogroups.com
> [mailto:Ca… [at] yahoogroups.com]*On Behalf Of *Bruce Stirling
> There is a really nice one from British Columbia named Island Fling.
> Looks like the raised deck is covered with some kind of wood, as is
> hassle to do the woodwork like this? Cost mucho?
Looks like somebody dressed up a standard-issue Cal 28 with a lot of
wood trim. Looks good in the photo. But let me warn you that
bright-finished wood trim is only for those willing to do the annual
maintenance.
My other boat, a 1961 Seafarer "Polaris" model, has lots of mahogany
trim and parts. There's a toe rail around the deck, hatches, coamings,
handrails, winch pads. She has spruce spars and spinnaker pole and an
ash tiller. The toe rail and mast get varnished every year, since
they're exposed. Other sections, protected by a cover, get it in a
rotation depending upon need. Last spring was the 39th time I've done
this. She looks good and gets lots of admiring comments, so I have
incentive to be diligent. I see a lot of woodworking projects on boats
that suffer from (a) poor engineering or understanding of water, and (b)
lack of maintenance. You must keep moisture out of your bright-finished
project or it will lift the varnish right off. This means proper sealing
and bedding. And you must apply enough varnish initially, and keep it
up afterward, to prevent rapid deterioration. It can be done. My boat
looks pretty good in her 46th year. I sailed on the schooner
/Brilliant/ a couple years ago, and she was beautiful, but she has a
paid crew including a devoted captain.
My Cal 20 has a varnished mahogany rudder and tiller and a varnished
companionway drop board. I've also made mahogany pads for under the
forward mooring cleats, the cabin-top jib sheet cleats, and the stern
light. There's a mahogany flagstaff holder at the after end of the
cockpit. It's not too much work but dresses up the boat.
The addition of a lot of wood trim to the Cal 28 in the picture must
affect weight and center of gravity. You pay a price for looks when
they are applied and not integral to the structure.
