6 messages2007-11-04 04:20 through 2007-11-06 01:16 UTC
Mast Step Plate
Neil McBride2007-11-04 04:20
I pulled the mast off my Cal 2-29 today and will be re-rigging and
installing new wiring and lights etc. Before restepping the mast I
plan on installing the Mast Step Plate sold by Seal's Spars and
Rigging, but have a question. Do I remove the existing mast step and
them install the existing mast step onto the new stainless mast step
plate? The new mast step plate does not have anything that will hold
the mast in position so thought that might be the way to go.
Neil
Optima (Cal 2-29)
Victoria
RE: [Cal_Boats] Mast Step Plate
Husar, Charlie [USA]2007-11-04 11:31 UTC
Neil, you do put the old oval pedastal on top of the new steel plate,
and screw the two of them down. Make sure you seal the screws well. I
also suggest that you bring the wiring out the side/front/back of the
mast to an external hole. I don't like having blind holes inside the
mast where they are hard to inspect for leakage.
Annapolis
Behalf Of Neil McBride
Sent: Sunday, November 04, 2007 12:21 AM
Subject: [Cal_Boats] Mast Step Plate
installing new wiring and lights etc. Before restepping the mast I plan
on installing the Mast Step Plate sold by Seal's Spars and Rigging, but
have a question. Do I remove the existing mast step and them install the
existing mast step onto the new stainless mast step plate? The new mast
step plate does not have anything that will hold the mast in position so
Neil
Optima (Cal 2-29)
Victoria
Yahoo! Groups Links
Re: Mast Step Plate (Charlie)
Neil McBride2007-11-04 17:23
Thank you for the instructions, I like the idea of having external
wiring connections, don't want to pull the mast again for a minor
wiring problem.
Neil
Victoria
--- In Ca… [at] yahoogroups.com, "Husar, Charlie [USA]"
plate,
well. I
the
the
> Cheers
> Charlie
> Annapolis
> -----Original Message-----
On
plan
Rigging, but
install the
mast
position so
> Neil
> Optima (Cal 2-29)
> Victoria
> Yahoo! Groups Links
david dobbs2007-11-05 04:54 UTC
Charlie,
Besides that the damn lights never work and you have no way to troubleshoot without pulling the mast. Next season I plan to have a cannon plug in the deck and will lead the mast wires to it via a hole in the mast. I just have to find a source for cannon plugs. That's what we called them in my USAF days.
Dave Dobbs, Cal29 411
PS, I just put the cover on today, officially ended the 2007 season. Now I will only see it when I remember to drive there to check the cover, BS with the yard guys, drink coffee and tell stories, check the latest rumors, etc.
Annapolis
Neil
Optima (Cal 2-29)
Victoria
Yahoo! Groups Links
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
pat pat2007-11-06 01:06 UTC
I have a source for surplus new environmentally sealed circular connectors in Van Nuys, CA.. SS housing and strain relief, will post tommorrow from work
david dobbs <tm… [at] yahoo.com> wrote: Charlie,
Annapolis
Neil
Optima (Cal 2-29)
Victoria
Yahoo! Groups Links
Do You Yahoo!?
Do You Yahoo!?
Re: [Cal_Boats] Mast Step Plate
Scott Sauvageot2007-11-06 01:16 UTC
I would definitely be interested in that as well. Not that my Cal has many wires going up the mast....
Scott
Sent: Monday, November 05, 2007 5:06 PM
Subject: RE: [Cal_Boats] Mast Step Plate
Charlie,
Annapolis
Neil
Optima (Cal 2-29)
Victoria
Yahoo! Groups Links
Do You Yahoo!?
Do You Yahoo!?
