7 messages2007-11-21 15:24 UTCthrough 2007-11-21 22:20 UTC
Cal 40 v. Cal 39 Performance Comparison
Bruce Stirling2007-11-21 15:24 UTC
Tried to send this twice with an embedded screen capture of the comparison
chart. No se puede, according to the mail demon. So here is the site and
you can perform your own comparisons. I just want to know what it really
means. I've been comparing the Cal 28 to everything in site and was glad to
see the hull speeds were not all that different from her larger sisters.
From: Bruce Stirling [mailto:br… [at] stirlinglaw.com]
Sent: Wednesday, November 21, 2007 8:09 AM
To: CalBoats
Subject: Cal 40 v. Cal 39 Performance Comparison
I stumbled across this site in the wee hours. There was a recent discussion
about the relative sailing characteristics of the Cal 40 and the Cal 39.
Here is the online comparison result based on someone's web site. It is fun
to compare all boats. Go to:
http://www.image-ination.com/sailcalc.html and scroll down. You can compare
almost any sailboat. So what do these figures mean in the real world?
Robert Bruce Stirling, II, Esq.
602.254.6638
602.460.5631 [Cell]
602.258.0706 [Fax]
http://www.stirlinglaw.com/lawyers
http://rockypointweekly.com
http://groups.yahoo.com/group/freecyclephoenix/
This message is protected by attorney/client privilege. This message is
intended only or the use of the person or entity to which it is addressed.
If the reader of this message is not the intended recipient, or the
employee, or agent responsible for delivering the message to the intended
recipient, you are hereby notified that any dissemination, distribution, or
copying of this message is strictly prohibited. If you received this
communication in error, please notify us immediately by replying to the
sender of this email or by telephone. If you believe it was sent to you in
error, do not read it. Please reply to the sender that you received the
message in error, then delete it.
RE: [Cal_Boats] Cal 40 v. Cal 39 Performance Comparison
Husar, Charlie [USA]2007-11-21 17:48 UTC
Bruce, easy reference is HS = 1.33 times the square root of the
waterline. Since it goes up as the sqrt for displacement hulls, the HS
number does not rise quickly. For a CAL 25 is is just about 6 knots.
Behalf Of Bruce Stirling
Sent: Wednesday, November 21, 2007 10:24 AM
To: CalBoats
Subject: [Cal_Boats] Cal 40 v. Cal 39 Performance Comparison
comparison chart. No se puede, according to the mail demon. So here is
the site and you can perform your own comparisons. I just want to know
what it really means. I've been comparing the Cal 28 to everything in
site and was glad to see the hull speeds were not all that different
To: CalBoats
discussion about the relative sailing characteristics of the Cal 40 and
the Cal 39. Here is the online comparison result based on someone's web
site. It is fun to compare all boats. Go to:
compare almost any sailboat. So what do these figures mean in the real
world?
602.254.6638
602.460.5631 [Cell]
602.258.0706 [Fax]
http://www.stirlinglaw.com/lawyers <http://www.stirlinglaw.com/lawyers>
http://rockypointweekly.com <http://rockypointweekly.com/>
<http://groups.yahoo.com/group/freecyclephoenix/>
addressed. If the reader of this message is not the intended recipient,
or the employee, or agent responsible for delivering the message to the
intended recipient, you are hereby notified that any dissemination,
distribution, or copying of this message is strictly prohibited. If you
received this communication in error, please notify us immediately by
replying to the sender of this email or by telephone. If you believe it
was sent to you in error, do not read it. Please reply to the sender
that you received the message in error, then delete it.
Downing, Thomas2007-11-21 18:10 UTC
There is some disagreement about this 1.33 * LWL^^.5 formula. Seems it
is a reasonable rule of thumb, but that a given displacement hull form may
vary from this to a considerable extent.
Also, that the hull speed of a given hull may be different under sail as
opposed to under engine power.
If you have a more-or-less correctly propped boat, finding your acutal hull
speed under power is pretty easy in flat water. The horsepower to
speed-through-water curve makes a pretty sharp bend at the hull speed.
Re: [Cal_Boats] Cal 40 v. Cal 39 Performance Comparison
Chris Campbell2007-11-21 18:21 UTC
> HS number does not rise quickly. For a CAL 25 is is just about 6 knots.
This is a subject that is of greater interest since I got a little GPS.
The Cal 20 can do over her theoretical hull speed fairly easily. It
calculates to just over 5.6 knots. On a good breezy day on a reach, I
can maintain 5.8 to 6 regularly, higher in puffs. This is in an area
without notable current so the GPS speed ought to be fairly accurate as
through-the-water speed.
That hull speed formula used to seem like one of those inexorable laws
of nature that just WAS. It was a rule, something that you'd just have
to live with unless you were surfing or otherwise planing. But the Cal
20 romps past it without surfing. So I sorta assume that it's a
guideline, not a law or a rule.
What's really interesting is that the Cal 20 is faster in similar
conditions than my other boat with a foot longer on the waterline. That
boat has a mechanical Sumlog that gives very optimistic speed
reports--great for the owner's ego, but not for accuracy. The GPS tells
me that she's going slower than the Cal 20 would likely go, or at least
not a bit faster. Of course, the boats are about 140 miles apart and I
can't race them--it would be fun--but you do get a sense for wind and
waves and comparability. This experience confirms Charlie's comment
that the square-root relationship makes the number change slowly, that a
small waterline length change doesn't do a lot to hull speed.
Re: Cal 40 v. Cal 39 Performance Comparison
Bruce Stirling2007-11-21 18:45
knots.
Before making my Ebay purchase I'd never heard of hullspeed or the
calculation used to figure it out. When we took possession in
Oceanside and moved her to San Diego my brother first mentioned it to
me. He calculated away as we headed south. I was impressed. My mind
glosses over when I hear math formulas. My little brother, though,
once tested as some kind of wizard in elementary school, and to
confirm it, he came out number one on the Arizona Bar Exam in February
1979. I just use him as a great resource.
But I was surprised to note the Cal 40's hullspeed was only about one
mile per hour faster than the Cal 28. I assumed that if I ever found
myself in a drag race with a Cal 40, that she would walk away from me
a little bit faster than at just one mile per hour. I take it that's
where all the other variables kick in. So how long would the Cal 40
remain in sight, more or less?
So how come those damn catamarans on the Potomac in D.C. would blast
past us in our Mobjacks like we were standing still? We were standing
still, but for the current taking us to Ft. Belvoir. I guess that's
the displacement hull v. lack thereof, or something like that.
Re: [Cal_Boats] Re: Cal 40 v. Cal 39 Performance Comparison
Chris Campbell2007-11-21 21:10 UTC
You've got it. Planing hulls are not limited by any theoretical hull
speed. For displacement hulls, the limit is created as the hull tries
to climb up onto plane, making a big bow wave that it can't overcome.
Planing hulls are designed to be lighter (usually) and to have a shape
that encourages getting up on top of that wave, as well as enough power
to get there.
I've read that even our sailboat hulls will try to plane if pulled with
enough power but that when they do, their hull shape causes really
unpleasant consequences--substantial misbehavior.
Catamaran speed - Was: Cal 40 v. Cal 39 Performance Comparison
Harleigh Ewell2007-11-21 22:20 UTC
Actually, I believe most sailing catamarans are non-planing designs.
However, because of their high length to beam ratio, the usual hull speed
formula for monohull displacement boats does not apply.
Harleigh Ewell
Of Chris Campbell
Sent: Wednesday, November 21, 2007 4:11 PM
Subject: Re: [Cal_Boats] Re: Cal 40 v. Cal 39 Performance Comparison
You've got it. Planing hulls are not limited by any theoretical hull speed.
For displacement hulls, the limit is created as the hull tries to climb up
onto plane, making a big bow wave that it can't overcome. Planing hulls are
designed to be lighter (usually) and to have a shape that encourages getting
up on top of that wave, as well as enough power to get there.
