10 messages2007-11-29 23:05 UTCthrough 2007-12-07 11:02 UTC
Cleat and Block help
John2007-11-29 23:05 UTC
Hi all,
Just starting the process of leading the main halyard aft on my Cal 31. By
my calculations I have a 210 sq. ft. main sail and I'm using a 3/8" Sta-set
X halyard. I think I've figured the specs for the deck block (around 2500
lbs SWL and 5000 BL), but I would appreciate any help in sizing a cheek
block (or organizer) and the cleat behind the cockpit winch (going to use an
old Belmar 20).
Advice greatly appreciated,
John Stacklyn
Cal 31 #33 "Sol Survivor"
Shell Point, FL
Re: [Cal_Boats] Cleat and Block help
Scott Sauvageot2007-11-30 00:48 UTC
Hi!
I used the Ronstan 40 blockes on my Cal 25, so my bet would be the Ronstan 50 block (though 40's would more than likely do) I also like the Lewmar Rope clutch. You can bring in lines with the clutch closed with minimal wear. The Lewmar uses dominos that don't crimp or gouge the line, but make it weave between a series of metal plates that add moderate friction along a section of line (instead of point loading).
Remember, the halyards aren't seeing thousands of pounds of load. The spinnaker halyard would see larger loads than the Jib and Main. I've raced on mid-30 something foot boats using the Ronstan 50's and lewmar rope clutches. the cheek blocks used were typically Ronstan 50 as well.
Cheers,
Scott
Sent: Thursday, November 29, 2007 3:05 PM
Subject: [Cal_Boats] Cleat and Block help
Hi all,
Just starting the process of leading the main halyard aft on my Cal 31. By my calculations I have a 210 sq. ft. main sail and I'm using a 3/8" Sta-set X halyard. I think I've figured the specs for the deck block (around 2500 lbs SWL and 5000 BL), but I would appreciate any help in sizing a cheek block (or organizer) and the cleat behind the cockpit winch (going to use an old Belmar 20).
John Stacklyn
Shell Point, FL
Re: Cleat and Block help
slickbutfoxbuger2007-11-30 14:21
Pardon me a moment.......
(not that any real sailor is going to take our opinion)
but i see your sailing down there in Florida...... and as i
reckon there just isn't much inland waters round those parts; i was
thinking that you mite just want the best of ocean-going hardware on
that-there boat of yours. and if'in that's so, let me suggest what
the big guys use. and what i personally wouldn't be caught dead out
to sea without......
to that ends, i have taken the liberty of gathering a few
choice pages (URL) below for your viewing pleasure. the first bunch
are on the *Harken* web-site. just about as good as it gets.
now the second group is the cats whiskers, and is on the
*Lewmar* web-site. just stay with their racing line, and you can't go
wrong.
they also have a down-load that cane help you double-check your
line-loading specks. they seem a little high for that size boat to
me.......
fiver
*Harken*
http://www.harken.com/blocks/blockspecs.php
http://harkenstore.com/uniface.urd/sccyspw1.eShowPage?
409Z56LC7FV66&409Z56LC7C9RU
409Z56LC7FV66&409Z56LC4B4LU
409Z56LC7FV66&409Z56LC5FMSA
409Z56LC7FV66&409Z56LC4WKD6
*Lewmar* (60-mm high-load racing)
http://en.lewmar.com/products/index.aspx?lang=1&page_id=90
http://en.lewmar.com/products/index.aspx?lang=1&page_id=542
--- In Ca… [at] yahoogroups.com, "John" <stacklynj@...> wrote:
> Hi all,
31. By
Sta-set
(around 2500
cheek
to use an
> old Belmar 20).
> John Stacklyn
> Shell Point, FL
slickbutfoxbuger2007-11-30 14:30
one more really good URL.....
http://en.lewmar.com/products/index.aspx?lang=1&page_id=78
--- In Ca… [at] yahoogroups.com, "slickbutfoxbuger"
on
go
> wrong.
your
> me.......
> fiver
> *Harken*
> --- In Ca… [at] yahoogroups.com, "John" <stacklynj@> wrote:
> > Hi all,
Cal
> 31. By
3/8"
> Sta-set
> (around 2500
> cheek
(going
> to use an
> > old Belmar 20).
> > John Stacklyn
> > Shell Point, FL
RE: [Cal_Boats] Re: Cleat and Block help
John2007-12-01 14:09 UTC
Fiver and Scott: Thanks so much for the input and links! very helpful.
One more question on design: it seems like, with a pad eye and block on the
deck at the mast, and an orgaizer back by the companionway hatch, that there
would be chaffing from the upper part of the organizer since it is lower
than where the halyard will exit the mast block. Comments?
John
Of slickbutfoxbuger
Sent: Friday, November 30, 2007 9:31 AM
Subject: [Cal_Boats] Re: Cleat and Block help
http://en.lewmar.
<http://en.lewmar.com/products/index.aspx?lang=1&page_id=78>
--- In Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com,
"slickbutfoxbuger"
on
go
> wrong.
your
> me.......
> fiver
> *Harken*
> http://www.harken. <http://www.harken.com/blocks/blockspecs.php>
> http://harkenstore.
<http://harkenstore.com/uniface.urd/sccyspw1.eShowPage?>
> http://harkenstore.
> http://harkenstore.
> http://harkenstore.
> http://en.lewmar.
<http://en.lewmar.com/products/index.aspx?lang=1&page_id=90>
> http://en.lewmar.
<http://en.lewmar.com/products/index.aspx?lang=1&page_id=542>
> > Hi all,
Cal
> 31. By
3/8"
> Sta-set
> (around 2500
> cheek
(going
> to use an
> > old Belmar 20).
> > John Stacklyn
> > Shell Point, FL
Re: [Cal_Boats] Re: Cleat and Block help
Scott Sauvageot2007-12-01 21:39 UTC
I forget whether your boat has a deck or keel stepped mast. if deck stepped, I would recommend getting a stainless mast base with attachment points for turning blocks. For the deck organizers, I actually used 1" thick teak spacers to raise the organizers to "nearly" the level of the blocks attached to the steel plate at the base of the mast. This way, the angle is minimal. the Line stoppers, I placed right on the deck, as the distance was great enough that there was no effect. Also, the Lewmar rope clutches have their entry points about an inch off the deck as well. Here are a couple photos of Indi with her deck organizers.
We'll see if the attachments come through
Sent: Saturday, December 01, 2007 6:09 AM
Subject: RE: [Cal_Boats] Re: Cleat and Block help
One more question on design: it seems like, with a pad eye and block on the deck at the mast, and an orgaizer back by the companionway hatch, that there would be chaffing from the upper part of the organizer since it is lower than where the halyard will exit the mast block. Comments?
John
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of slickbutfoxbuger
on
go
> wrong.
your
> me.......
> fiver
> *Harken*
> > Hi all,
Cal
> 31. By
3/8"
> Sta-set
> (around 2500
> cheek
(going
> to use an
> > old Belmar 20).
> > John Stacklyn
> > Shell Point, FL
Husar, Charlie [USA]2007-12-02 00:50 UTC
Hi, All. Looks good. The arrangement on my CAL 25 is a lot like that
on Scott's boat. I used wedge shaped teak pieces so the organizers cant
up toward the mast. I wanted the lines from the mast to feed in-line to
the sheaves in the organizer.
Also, note that spinnaker pole controls (pole lift and downhaul -
outboard lines in Scott's starboard photo) should not go through the
handled sheet stoppers since trim is almost continuous, especially for
the downhaul since it comes to center deck and must trim with lateral
pole angle.
Behalf Of Scott Sauvageot
Sent: Saturday, December 01, 2007 4:39 PM
Subject: Re: [Cal_Boats] Re: Cleat and Block help
helpful.
Comments?
John
<mailto:Cal_Boats%40yahoogroups.com> , "slickbutfoxbuger"
i was
hardware
on
what
dead out
bunch
can't
go
> wrong.
your
boat to
> me.......
> fiver
> *Harken*
<mailto:Cal_Boats%40yahoogroups.com> , "John" <stacklynj@> wrote:
> > Hi all,
my
Cal
> 31. By
a
3/8"
> Sta-set
> (around 2500
sizing a
> cheek
(going
> to use an
> > old Belmar 20).
> > John Stacklyn
> > Shell Point, FL
John2007-12-02 15:24 UTC
Thanks Scott and Charlie. This is exactly what I had in mind!
Of Scott Sauvageot
To: Cal_Boats@yahoogrou <mailto:Ca… [at] yahoogroups.com> ps.com
John
Of slickbutfoxbuger
http://en.lewmar.
"slickbutfoxbuger"
on
go
> wrong.
your
> me.......
> fiver
> *Harken*
> http://harkenstore.
> http://harkenstore.
> http://harkenstore.
> http://harkenstore.
> http://en.lewmar.
> http://en.lewmar.
> > Hi all,
Cal
> 31. By
3/8"
> Sta-set
> (around 2500
> cheek
(going
> to use an
> > old Belmar 20).
> > John Stacklyn
> > Shell Point, FL
RE: [Cal_Boats] Re: Cleat and Block help (John)
Kevin O2007-12-03 18:05 UTC
John,
My Cal-31 came with the mast ring and deck organizers on each side of the cabin top.
If I remember correctly the orginizer was placed on the slanted section of the cabin top so it would point directly to the turning block at the mast ring. So even though it is lower it is pointed correctly. Does this sound right? If not I will be forced to go visit my boat again and look. :-)
My issue is that my orginizer is not lined up with the cabin top winches
You can go to my photos "Cal 31 Kona" and see the port side orginizer in "Not a dry spot on deck".
Please note that the photos are from April when I became the owner and all the lines you see are now replaced!
KO
"Kona"
Cal-31
Las Vegas
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Scott Sauvageot
John
on
go
> wrong.
your
> me.......
> fiver
> *Harken*
> > Hi all,
Cal
> 31. By
3/8"
> Sta-set
> (around 2500
> cheek
(going
> to use an
> > old Belmar 20).
> > John Stacklyn
> > Shell Point, FL
Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how.
RE: [Cal_Boats] Re: Cleat and Block help (Kevin)
John2007-12-07 11:02 UTC
Kevin,
Thanks for the info and the refernce to the photo (looks like you are really
enjoying the boat!)
I think mine will be mounted on a more level area but a teak mounting plate
should raise it enoug to take care of it.
John S.
Shell Point, FL
Of Kevin O
Sent: Monday, December 03, 2007 1:06 PM
Subject: RE: [Cal_Boats] Re: Cleat and Block help (John)
John,
cabin top.
KO
"Kona"
Cal-31
Las Vegas
Of Scott Sauvageot
John
Of slickbutfoxbuger
http://en.lewmar.
"slickbutfoxbuger"
on
go
> wrong.
your
> me.......
> fiver
> *Harken*
> http://harkenstore.
> http://harkenstore.
> http://harkenstore.
> http://harkenstore.
> http://en.lewmar.
> http://en.lewmar.
> > Hi all,
Cal
> 31. By
3/8"
> Sta-set
> (around 2500
> cheek
(going
> to use an
> > old Belmar 20).
> > John Stacklyn
> > Shell Point, FL
<http://us.rd.yahoo.com/evt=51732/*http://overview.mail.yahoo.com/> how.
