5 messages2007-12-13 20:37 UTCthrough 2007-12-14 00:49 UTC
Sail Trim
Husar, Charlie [USA]2007-12-13 20:37 UTC
Fin, nailed most of what I meant to say. Just a few adds.
Two sails can have the same LP, but have totally different clew heights.
For racing we get "deck sweeper" #2s and #3s. These require additional
jib track farther forward for proper sheeting angle (except some
reaching sails for racing that Mike described - like the Jib Top.)
For cruising, you'd want you smaller sails to have higher and higher
clews so that they sheet back to approximately the same location. I've
attached a picture.
I believe the term "lapper" originates with a sail that does over"lap"
the mast by a little - say a 110 or 120 percent sail. Am I correct?
chalie
Re: Sail Trim
mtkennedy12007-12-13 21:09
--- In Ca… [at] yahoogroups.com, "Husar, Charlie [USA]" <husar_charlie@...> wrote:
I agree. Fin is the expert when it comes to racing. I didn't think the person asking was
likely to be beating to weather in that Cal 28 anytime soon. We have a high clew 120% jib
on the roller furler for going back and forth to Catalina. I'm too old to enjoy beating over
there close hauled in a breeze. I used to do that sitting on the rail or driving and I've
passed that course. I go to weather under power unless it's an unusual situation.
I might add a #3 and a forward inboard track if we do any class racing. That's in the
future.
> attached a picture.
That's my understanding.
Mike Kennedy
Conquest Cal 40 # 96
> Cheers
> chalie
Re: [Cal_Boats] Re: Sail Trim
Chris Campbell2007-12-13 21:47 UTC
> high clew 120% jib
> or driving and I've
> situation.
Well, maybe you're luckier with the weather than I am, but if I only
sailed off the wind, I'd never sail at all. The wind is usually coming
from wherever I want to go. There must be some law responsible for that
phenomenon.
For my evening sails off the mooring, I have to beat to go anywhere
about half the time. /And that's the fun part/ because our summer winds
tend to be light. The bad news comes when you've gone to windward and
must then go back. That means no apparent wind, and with the breeze
typically dropping at that time of evening, often no wind at all.
Suddenly I am grateful for beating. And sometimes I'll break down and
fire up the outboard when I get tired of slatting sails.
Sometimes when I'm lucky there will be a big blow from the north that
lets me reach back and forth across our Bay. My little Cal 20 shares
the Bay then with one or two of the schooners and perhaps one big
yacht. Everybody else is sitting at home, leaving the Bay to the one
fool in the little boat and to the tourists on the big schooners. I get
wet, cold, and happy and stay out until the wind-chill has drained too
much bodily warmth.
On our local historic schooner, going to weather is a diesel affair.
First of all, she doesn't much like beating anyway, and eventually makes
more leeway than forward motion--the bow points in the right direction
but the course is otherwise. Also, we're often trying to reach some
port on a schedule and don't have the freedom the old commercial
schooners had to get there when wind and weather permit. We often motor
sail, either to save a bit on diesel or to give the illusion of sailing.
Re: Sail Trim
slickbutfoxbuger2007-12-13 22:31
i don't know about Bruce,
and His intrepid Cal-28 down San Diego way......
but here is one crazy bitch, with a Cal-28 up in Puget Sound who
likes nothing more than going too-weather. and is planing her rebuild
of BB-54 to handle such first & foremost. and in standing winds of 20
knots or better.
part & parcel of this is adding a high-aspect rig and lowering
the *C of G*. adding towable jib-cars, windward main-sheeting, full-
batten main with harken mast track, and retractable sprit.
By-the way; any of you Cal-40 Guys got 8 foot or more of an old
original boom you want to donate to my project???? (cal-40 boom is
the same as cal-28 mast)
so, as you all mite guess; i have been listening to this sail-
trim discussion with great interest. however, i also temper what you
Guys have to say with how i see the J-boats designed. after all,
those are great up-wind boats. all-be them a little light in the
butt. not unlike the Cal-28.......
any comment's please....?
crazy fiver
heights.
additional
unusual situation.
> future.
higher
location. I've
> > attached a picture.
over"lap"
correct?
> Mike Kennedy
> > Cheers
> > chalie
Sail Trim, sheeting angles.
Fin Beven2007-12-14 00:49 UTC
At least on a Cal-40, it's pretty simple. Our #3 sheets to a point that's just aft of the shrouds, and about half-way between the cabin-sides and the shrouds. I think that the sheeting angle is about 15 degrees (which I will check and confirm). Curiously, if you follow that same line, at about 15 degrees, it intersects the toe-rail at a point very close to where the #1 sheets. Again, 15 degrees, or something close to that.
Any sail size in-between the #3 and the #1 has to pass outside of the shrouds and spreader, and ends up sheeting at a wider angle, and does not seem to sheet as well if you care to sail to windward efficiently. This is why we no longer use a #2 or a "lapper" or "mule".
Racing or cruising, that approximate 15-degree sheeting angle seems to do what we want in a typical day of sailing .... get to weather efficiently when the need is there. And (and here's the huge benefit for the crew) - - - the sheet length for the #3 is significantly shorter than for a #2, and way shorter than for a #1. In a typical tack on the Cal-40, using the #3, the new sheet only needs to be brought in about 5' total, from tack-to-tack. The "trimmers" and "grinders" love the #3. On a Cal-28, that would probably be somewhere between 3' and 4' to complete a tack. Very little speed is lost between tacks when that's all you need to bring in, so the whole trimming process can be done by one person with a self-tailing two-speed winch.
The "deck-sweeper" Mike referred to has its advantages and disadvantages. On the advantage side, there is supposedly an "end-plate" effect from the deck that steers the wind aft and supposedly makes the sail more efficient. The lower clew also lowers the center of effort of the sail, creating less heal for the same sail area. And, a high clew is also pushed even further to leeward (wider sheeting angle) by the pressure of the wind on the windward side of the sail.
On the down-side with a "deck-sweeper", there is virtually no visibility forward and to leeward from a typical windward steering position.
Unless you put a "window" in the sail, which wouldn't be such a bad idea.
Fin.
Sent: Thursday, December 13, 2007 1:09 PM
Subject: [Cal_Boats] Re: Sail Trim
--- In Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>, "Husar, Charlie [USA]" <husar_charlie@...> wrote:
future.
> attached a picture.
Mike Kennedy
> Cheers
> chalie
