3 messages2007-12-20 23:07 UTCthrough 2007-12-21 04:11 UTC
Re: [Cal_Boats] Hurth gears and other boat toys(Tom)
Michael Robinson2007-12-20 23:07 UTC
Hello Tom,
Sorry to hear you're not feeling well but glad to hear you are still with
us.
Regarding Hurth (I have one, seems OK now). What do you recommend as a
replacement for aCal 36 with a Westerbeke 27?
Mike Robinson
Holiday
Cal 36 #4
Pt. Richmond, CA
On 12/19/07, Tom Vandiver <bs… [at] yahoo.com> wrote:
RE: [Cal_Boats] Hurth gears and other boat toys (Mike)
ti… [at] ch2m.com2007-12-21 02:21 UTC
Of course Mike, you'll have to check things out, but I replaced my
failed ZF/Hurth, with a Techno drive Twin Disc transmission TMC40P.
This was installed on the Universal / Westerbeke MD-20.
To re-gain alignment (different shaft offsets, the drop center of the
TMC40 is 68mm and the HBW50 is 62mm) I had to move (shim) the engine at
a slightly different height and angle. I did this by installing ironwood
pieces under the existing rubber dampened motor mounts... I could have
gone without the shims, possibly, as there was adjustment room on the
mounts, but the engine was near the top, and tended to wobble a bit too
much for my taste. With the shims, it now sits lower on the mounts, and
appears much more stable.
This is a most excellent replacement and has been done many times,
according to Joe DeMers, who sold me the new unit, with a new dampener
plate (required to match-up). There where some very small adjustments
made for me to accommodate the different position shift lever in my
engine bay (grinding back part of the engine bed).
I'm very happy that this worked out, as the new tranny has a better
friction method in my opinion (cone) and is rated to match my potential
HP output under any circumstances..
The Hurth appeared to be suitable "most of the time" just barely...
until it burned up.
Pleasure Rating:
Intermittent operation with very large variation in engine speed.
Maximum power capacity is intended only for personal use, planing hull
pleasure craft where full engine throttle operation will be less than
10% of the total time with balance of time at 80% of full throttle
engine RPM or less. Annual operating hours up to 500. (For TMC
transmissions 300 hours/year).
TMC40 Horse Power Input Rating
Pleasure RPM
Intermediate RPM
Continuous RPM
Ratio
3000
3600
2800
3000
1800
2300
1.45
34.9
34.9
34.9
34.9
24.1
30.8
2.00
34.9
34.9
28.2
32.2
17.4
22.8
2.60
29.5
34.9
22.8
25.5
12.1
16.1
ZF/Hurth Rating:
<http://www.simplicity-marine.com/ZF/Definitions/Definitions.htm>
PLEASURE DUTY CLASSIFICATION
MODEL RATIOS MAXIMUM INPUT POWER
"A" "B" 2600 rpm 2800 rpm 3200 rpm HP/rpm
ft.lb kW/rpm Nm
HP kW HP kW HP kW
ZF 5 M
(HBW 50)
2.050
1.860
23
17
25
18
28
21
0.0089
46
0.0066
63
2.720
2.150
16
12
18
13
20
15
0.0063
33
0.0047
45
Max engine speed: 5000 rpm. Max Input Power 20 kW.
CONTINUOUS DUTY CLASSIFICATION
"A" "B" 1800 rpm 2300 rpm 2600 rpm HP/rpm
ft.lb kW/rpm Nm
HP kW HP kW HP kW
ZF 5 M
(HBW 50) 2,050 1,860 13 10 16 12 18
14 0.0071 37 0.0053 51
2,720 2,150 9 7 11 9 13 10 0.0050
26 0.0037 35
Max engine speed: 5000 rpm. Max Input Power 15 kW.
Behalf Of Michael Robinson
Sent: Thursday, December 20, 2007 3:07 PM
Subject: Re: [Cal_Boats] Hurth gears and other boat toys(Tom)
Hello Tom,
with us.
Mike Robinson
Holiday
Cal 36 #4
Pt. Richmond, CA
<mailto:bs… [at] yahoo.com> > wrote:
RE: [Cal_Boats] Hurth gears and other boat toys (Timm)
Husar, Charlie [USA]2007-12-21 04:11 UTC
Somehow, I 've never associated a "pleasure rating" with engines. Maybe
it's just me.
Behalf Of ti… [at] ch2m.com
Sent: Thursday, December 20, 2007 9:22 PM
Subject: RE: [Cal_Boats] Hurth gears and other boat toys (Mike)
until it burned up.
Pleasure Rating:
Pleasure RPM
Intermediate RPM
Continuous RPM
Ratio
3000
3600
2800
3000
1800
2300
1.45
34.9
34.9
34.9
34.9
24.1
30.8
2.00
34.9
34.9
28.2
32.2
17.4
22.8
2.60
29.5
34.9
22.8
25.5
12.1
16.1
ZF/Hurth Rating:
ft.lb kW/rpm Nm
HP kW HP kW HP kW
ZF 5 M
(HBW 50)
2.050
1.860
23
17
25
18
28
21
0.0089
46
0.0066
63
2.720
2.150
16
12
18
13
20
15
0.0063
33
0.0047
45
ft.lb kW/rpm Nm
HP kW HP kW HP kW
ZF 5 M
26 0.0037 35
Hello Tom,
with us.
Mike Robinson
Holiday
Cal 36 #4
Pt. Richmond, CA
