Re: [Cal_Boats] info /(Mick) Hull Number
4 messages2007-12-19 03:08 UTCthrough 2007-12-31 03:27 UTC
david dobbs2007-12-19 03:08 UTC
Mick, To my knowledge, the 2-29 was an option. With that you got a diesel, wheel steering and a different head configuration. Same hull, same rig. Another place they put hull numbers was on the bottom of drawers in the salon. I'm not making this up. But if you have the CG documentation it should tell you the hull number. David Dobbs Cal29 411 From: Walter McNichols <wa… [at] mc-nichols.com> To: Ca… [at] yahoogroups.com Sent: Tuesday, December 18, 2007 10:26:50 AM Subject: Re: [Cal_Boats] info /(Mick) Hull Number David, Took the boat out yesterday for a couple of hours to get holding tank pumped out and test (engine) running speed against stiff breeze and tide running out as well as down wind etc. We spent some time looking for the hull number with no luck. Also (if it helps or not) she is a documented vessell with no state assigned number. I'm thinking from what I've seen 1972 mid production was when they changed over to the CAL 2-29. So I must be late Cal-29? Any suggestions on where else to look, how pictures etc? Regards, Mick Walter (Mick) J. McNichols walter@mc-nichols. com On 12/9/07, david dobbs <tmft567@yahoo. com> wrote: Mick, I forgot to ask if you know the hull number. Mine is a 1972 also, and doesn't have the standard CABxxxxxx number. You may have a state assigned number, usually when a title is issued. You can find the real Cal Boats number by looking in the starboard lazerette, up high on the hull. A three digit number painted and covered with polyester. Mine is 411. I found this info right here. David Dobbs Cal29 411 Walter McNichols <walter@mc-nichols. com > wrote: I recently made a deal to purchase a very well cared for 1972 Cal 29. I'm going to be sailing it back home to Port Orange, Florida next month ( it's a 2 day sail) and have run across the Cal_Boats Group. Thank you all for publishing this site and information . I'm info / specifications starved for this boat and am wondering if you have any more or can point me to where I can find more of the spec manual? I love the way this boat sails as well as the room below. I am initiating a couple of projects this new year: Project #1, I have already set into motion, is I'm having a aluminum trailer built and plan on incorporating a mast stepping solution to allow me to trailer her as well as launching / retrieval on a almost demand basis. Project 2 is to convert the tiller to an Edson Pedestal wheel steering. I'm looking forward to Great fun ahead and anything you have in the way of information regarding the Cal 29 would be greatly appreciated! Regards, -- Walter (Mick) J. McNichols walter@mc-nichols. com Never miss a thing. Make Yahoo your homepage. -- Walter (Mick) J. McNichols walter@mc-nichols. com ____________________________________________________________________________________ Looking for last minute shopping deals? Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
Walter McNichols2007-12-29 13:06 UTC
David, On the Certificate of Documentation there's a "IMO or Other Number" space and it lists "FLZ3349F572". How do I extract the (my) Hull Number from this? Regards, Walter (Mick) McNichols CAL29 ??? wa… [at] mc-nichols.com On 12/18/07, david dobbs <tm… [at] yahoo.com> wrote: > > Mick, > To my knowledge, the 2-29 was an option. With that you got a diesel, > wheel steering and a different head configuration. Same hull, same rig. > Another place they put hull numbers was on the bottom of drawers in the > salon. I'm not making this up. But if you have the CG documentation it > should tell you the hull number. > > David Dobbs > Cal29 411 > > > > ----- Original Message ---- > From: Walter McNichols <wa… [at] mc-nichols.com> > To: Ca… [at] yahoogroups.com > Sent: Tuesday, December 18, 2007 10:26:50 AM > Subject: Re: [Cal_Boats] info /(Mick) Hull Number > > David, > > Took the boat out yesterday for a couple of hours to get holding tank > pumped out and test (engine) running speed against stiff breeze and tide > running out as well as down wind etc. We spent some time looking for the > hull number with no luck. > > Also (if it helps or not) she is a documented vessell with no state > assigned number. I'm thinking from what I've seen 1972 mid production was > when they changed over to the CAL 2-29. So I must be late Cal-29? > > Any suggestions on where else to look, how pictures etc? > > Regards, > > Mick > > Walter (Mick) J. McNichols > walter@mc-nichols. com <wa… [at] mc-nichols.com> > > On 12/9/07, david dobbs <tmft567@yahoo. com <tm… [at] yahoo.com>> wrote: > > > > Mick, > > I forgot to ask if you know the hull number. Mine is a 1972 also, and > > doesn't have the standard CABxxxxxx number. You may have a state > > assigned number, usually when a title is issued. You can find the real > > Cal Boats number by looking in the starboard lazerette, up high on the > > hull. A three digit number painted and covered with polyester. Mine is > > 411. I found this info right here. > > > > David Dobbs > > Cal29 411 > > > > > > *Walter McNichols <walter@mc-nichols. com <wa… [at] mc-nichols.com>>*wrote: > > > > I recently made a deal to purchase a very well cared for 1972 Cal 29. > > I'm going to be sailing it back home to Port Orange, Florida next month ( > > it's a 2 day sail) and have run across *the Cal_Boats Group*. > > > > Thank you all for publishing this site and information . I'm *info / > > specifications starved* for this boat and am wondering if you have any > > more or can point me to where I can find more of the spec manual? > > > > *I love the way this boat sails* as well as the room below. > > > > I am initiating a couple of projects this new year: Project #1, I have > > already set into motion, is I'm having a aluminum trailer built and plan on > > incorporating a mast stepping solution to allow me to trailer her as well as > > launching / retrieval on a almost demand basis. > > > > Project 2 is to convert the tiller to an Edson Pedestal wheel steering. > > > > I'm looking forward to Great fun ahead and anything you have in the way > > of information regarding the Cal 29 would be greatly appreciated! > > > > Regards, > > -- > > Walter (Mick) J. McNichols > > walter@mc-nichols. com <wa… [at] mc-nichols.com> > > > > > > ------------------------------ > > Never miss a thing. Make Yahoo your homepage.<http://us.rd.yahoo.com/evt=51438/*http://www.yahoo.com/r/hs> > > > > > > > -- > Walter (Mick) J. McNichols > walter@mc-nichols. com <wa… [at] mc-nichols.com> > > > > ------------------------------ > Looking for last minute shopping deals? Find them fast with Yahoo! Search.<http://us.rd.yahoo.com/evt=51734/*http://tools.search.yahoo.com/newsearch/category.php?category=shopping> > > > -- Walter (Mick) J. McNichols wa… [at] mc-nichols.com
Rodney G Johnson2007-12-29 19:28 UTC
Walter, the number that you list "FLZ3349F572" is a State-Issued Hull I.D. Number, not a Jensen Marine issued (USCG?) HIN. So, most likely the Jensen Hull # is not included in that HIN. It appears that Florida at least tried to incorporate the original Model Year into the number, "572" I assume means that your boat was built in May of 1972. The Jensen Marine/Cal Boats HINs all started with "CAB" and theoretically would not appear on a boat built prior to November of 1972 (ie: starting with 1973 model year.). Rod Johnson, "NODROG" 1970 CAL 21, hull#285
Walter McNichols2007-12-31 03:27 UTC
Thanks, I took the old headliner down and found 341 written on the back of both pices. This also corosponds with an old survey I recieved from my seller that lists Hull # 341 and that this number was removed so as not to conflict with some HID requirements that assigned the other number that was on the Document. Thanks one and all. Walter (Mick) McNichols CAL29 #341 On 12/29/07, Rodney G Johnson <rj… [at] juno.com> wrote: > > Walter, the number that you list "FLZ3349F572" is a State-Issued Hull > I.D. Number, not a Jensen Marine issued (USCG?) HIN. So, most likely the > Jensen Hull # is not included in that HIN. It appears that Florida at least > tried to incorporate the original Model Year into the number, "572" I assume > means that your boat was built in May of 1972. > The Jensen Marine/Cal Boats HINs all started with "CAB" and theoretically > would not appear on a boat built prior to November of 1972 (ie: starting > with 1973 model year.). > > Rod Johnson, > "NODROG" > 1970 CAL 21, > hull#285 > > > -- Walter (Mick) J. McNichols wa… [at] mc-nichols.com
