Re: GPS....
Good Grief !!!
how do you see anything with one of those; strap the bloody bugger
in-front of your eye-ball???
i say it's a good thing you float tested it! you would go bug-eyed
if you kept using the thing......
with all the fancy new expensive junk out there; i find that i
really like something a few years older and just a bit easier on the old mark-one
eye-ball (as they say).
to that ends, i have two of the unit's bellow for my cockpit. one
for the big picture of the area, and the other will be set-up for a close-up
view. i may even put a third at my nav-station down in the cabin for that
with-if situation. they are very reliable, and i have three of them. all of which
can be fed with the same GPS/sea-talk info......
fiver
"Raytheon-620"
(about $100 used on e-bay)
use's any external GPS or DGPS sore input
10" inch diagonal display
640 x 480 VGA 4 shade gray-scale
water proof to CFR-46 standards
NT CF-95 C-Map compatible (2-slot)
sea-talk, NMEA-0185, and NMEA-0180 in & out
power is less than 6-W @ 12-V
variable back lighting
plotting capable......
does not require magnifying equipment or optical-user glass-wear.....
**************Start the year off right. Easy ways to stay in shape.
http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489
