13 messages2007-12-31 15:13 UTCthrough 2008-01-13 01:21
Re:Cal 29 Beam Replacement
Alfred Poor2007-12-31 15:13 UTC
Tim inquired:
"Is there a thread on how to replace the beam in my boat with good details
and hopefully pictures?"
Been there, done that, saw the movie, bought the soundtrack, wear the
t-shirt, and drink the beer. We replaced the beam on our 1969 Cal 29
"Pentaquod" (which we recently sold). One of the key factors in the
replacement was the incredible generosity and talents of erstwhile Cal List
member Roger Jones. He has been resurrecting "Swiss Navy", Cal 29 Hull #1,
and was working in the Jensen plant when it was originally built. In the
process, he replaced the beam, and provided mechanical drawings that he gave
out freely so that others could have a replacement beam fabricated. (The Cal
29 and 2-29 hulls are identical; the differences are in cabin layout, tiller
vs. wheel steering, and I believe Atomic 4 gas vs. diesel power plant.)
David Owens and I were both early and fortunate beneficiaries of Roger's
work.
Fortunately, pictures of our project are still available on SailJazz:
http://webftp.sailjazz.com/cal/cal_29/Pentaquod/. Here you'll find a "beam
and bulkhead" directory with lots of photos and explanation. We had rot in
all bulkheads, so we replaced them as part of the same renovation project.
As a result, we gained access to the beam by cutting out the floor pan for
head, and coming at it from that side. (David got at his from the saloon
side, I believe.) I can provide you with a copy of the beam drawing, if you
like. If you do use the drawings, you may want to try one change that we
made. Instead of welding the top plate onto the beam, we had it created by
simply bending the web over and then welding on the tabs. It's a straight
line, and it saved some money in fabrication costs. The bottom plate is
curved, so that was welded on as in the drawing.
Let me know if I can be of any help or support. I had almost no fiberglass
experience when we tackled this job, and it came out pretty well, so if you
have the time and patience, it's a reasonable do-it-yourself project.
Alfred Poor
1973 T34C #288, "Jambalaya"
clausont2007-12-31 22:02
Cal List
Hull #1,
he gave
(The Cal
layout, tiller
> work.
"beam
rot in
project.
pan for
if you
created by
straight
fiberglass
if you
> Alfred Poor
Alfred,
I recall seing "Pentaquod" for sale but I don't remember if it were on
Craigslist, Yachtworld or just where.
That sounds great! I like the idea of the bend rather than the welded
top flange - makes perfect sense to me. Drawings of the beam would be
fantastic if I could get a set. I will be going over the website that
you show here (probably several times). I hope that you don't mind me
pestering you some more here and there.
Here is a link to a picture of our Cal 29 so far. ( I hope that it is
ok to post a link)I am obviously still working on it:
http://www.cruisersforum.com/gallery/showimage.php?i=3879&c=2
BTW - How would I find what hull number that I have? (I am sure that
has been covered hundreds of times also :) )
Tim
Oregon
Alfred Poor2008-01-01 15:50 UTC
Tim wrote:
"Drawings of the beam would be fantastic if I could get a set. I will be
going over the website that you show here (probably several times). I hope
that you don't mind me pestering you some more here and there."
I have emailed you the drawings directly in a separate message. Feel free to
pester all you want; I have received a treasure of advice from this list
over the years, and I'm happy to do what I can to pay it back.
As for the hull number, this may not be the easiest method, but it's most
reliable. Since these boats were built before the requirement that the HIN
be molded into the stern, you have to look elsewhere. On most (all?) Cals of
this vintage, you can find the number by crawling into the starboard cockpit
locker and inspecting the inside of the stern. You should find a number in
magic marker on the wood core, glassed over. That's your hull number.
You may or may not be able to find the number on the drawers or other
furniture components in the cabin, but this information is less reliable as
apparently pieces got tossed about between boats in the production line, and
the numbers may not always match your hull number.
Alfred Poor
clausont2008-01-02 02:26
Well, I went ahead and dug in today and the beam ( or what is left of
it) has been removed. I followed the directions that everyone here has
given me and that made the job much easier. There were a few minor
variations that I found necessary though.
I found that the compression post had been glued the main bulkhead and
that I would not be able to separate the two without major damage so I
decided to try to remove the beam with the compression post in place.
It turned out to be no prob to remove the beam with the compression
post in place. The beam had been bonded to the fiberglass step so I
had to work at separating them some, but that was just a few minutes
of prying the two apart.
The next step will be having the new beam manufactured and installing
it. Thanks for the drawing Alfred - that is great. I have already sent
it to a friend of mine who does nothing but fab stainless 316 and 304.
I think installing it will be pretty easy, but I will have a lot of
questions on re-glassing it.
More to come.
I hope
free to
most
the HIN
Cals of
cockpit
number in
reliable as
line, and
> Alfred Poor
clausont2008-01-03 16:28
Ok, the beam had been removed, I have the drawing at the fab shop for
a quote (I should know later today on that) and I am preparing to
install the new beam when it is finished.
My next question is regarding re-glassing the cabin sole. I have seen
the pictures of the removal and a picture or two of the finished glass
work.
Does anyone have any input on the procedure for re-glassing the cabin
sole? I intend to glass in the section that I removed but I am not
sure of the finished strength and the strength requirements.
Thanks again for all of the help in removing the original.
There are pictures of the removal here:
http://www.flickr.com/photos/62028190@N00/2156335615/
I still need to sweep up the old beam. or vacuum it out :) There was
not much left of it.
I hope
free to
most
the HIN
Cals of
cockpit
number in
reliable as
line, and
> Alfred Poor
Re: [Cal_Boats] Re:Cal 29 Beam Replacement
Chris Campbell2008-01-03 16:57 UTC
I'm the list cheerleader for the Gougeon Brothers' West System Epoxies.
One reason is their extensive R&D work involving composite structures
and epoxy adhesives. Another reason is their extensive and useful
publications about using epoxies for boat building and boat repair. If
you have not done repair work on fiberglass boats, you should acquire
their publications on proper techniques. They're really well written
and based on their experience and testing. Even if you're fond of
somebody else's epoxies, the West System publications are first-rate.
There's another reason for my cheer-leading. I know several of their
employees. all sailors, all bright people. I trust them and admire
their business and their community activities (sailing and otherwise).
Alfred Poor2008-01-04 14:57 UTC
Oh, do those photos ever look familiar!
"Does anyone have any input on the procedure for re-glassing the cabin
sole? I intend to glass in the section that I removed but I am not sure of
the finished strength and the strength requirements."
The floor pan is not structural, as far as I know. We just used a few layers
of the same fiberglass tape that we used for tabbing, and put them over the
seam in the floor pan. Something like that will probably be sufficient for
your repairs.
I note in the pictures that there are visible signs of moisture around the
beam tabs on the bulkheads. Now would be a very good time to inspect the
bulkheads thoroughly: at the tabs, at the chainplates, and below the mast.
If there are signs of rot, you may want to sister or scarf in fresh wood.
The chainplate and tab attach points are definitely structural, and it will
never be as easy to make the repairs as it is now while you've got it
partially disassembled. (Do you detect a slippery slope in this project?)
Alfred Poor
clausont2008-01-04 23:11
I have done a cursory inspection of the bulkhead but still have to dig
into the chainplate mounts although at first glance they look good.
The fresh looking moisture in the pictures is because I did not cover
the mast step very well with all of the rain that we are having. It
ran down the wire channel before I pulled the channel. I do still need
to finish the inspection of the bulkhead. Thanks for the info on the
cabin sole. You answered my main concern - is it structural. As it is
not, I will just bevel the edges good and start filling in with tape
as you mention.
Boy, the quotes that I received to build a new beam is right in line
with what Roger said when he was building them plus inflation. Just
buying the metal to build it myself will cost $180. Spendy stuff.
But that will be done right that way.
Thanks again for your help.
And thanks to Chris for the comments on West system epoxy. The epipoxy
that I have used on some things works great but goes off way too fast
for any project of any size - even with the slow catalyst.
sure of
few layers
over the
sufficient for
> your repairs.
around the
mast.
wood.
it will
project?)
> Alfred Poor
pscalsailor2008-01-05 03:53
I recently replaced the transverse beam in my 29 Cal, but have not
yet replaced the pan. When I had the new beam made, I had the top
horizontal piece made 0.5" wider to support the aft end of the pan.
I am glad to read that the pan is not structural. At this point my
plan is to secure the pan, but not necessarily fiberglass it in
place.
cabin
sure of
few layers
over the
sufficient for
> your repairs.
around the
inspect the
the mast.
fresh wood.
and it will
it
project?)
> Alfred Poor
RE: [Cal_Boats] Re:Cal 29 Beam Replacement
Wilkie2008-01-05 05:26 UTC
I've been down with the flu and just now chiming in. I think it would be a
mistake to discount the structural element of the floor pan completely,
although I think the bond of the beam to the main bulkhead is certainly the
bulk of the rig load carrying mechanism. A channel of fiberglass makes a
pretty good beam of it's own, and with your beam completely gone, it may
have been carrying more load than you want to believe. I'm not an engineer,
of course, so maybe you should just listen to Alfred. It's moot, anyway, as
Dishing out the two pieces of pan and laying glass and epoxy was certainly
just fine with Roger and you've heard his credentials.
I am amazed at how far gone your beam was. Wow. Mine looked new by
comparison, yet had failed to do it's duty completely. After replacement, I
was amazed at how much stiffer the boat sailed. I bet your boat flexed like
an inflatable.
I also find it difficult to conceive of that much rust and damage to the
beam without delamination of the plywood bulkhead. Water has obviously been
streaming down your wiring for some time. It is essential to seal the
wiring as it comes through the deck, and in the case that it's been
obviously leaking -- I would check the core of the deck around the
compression post and check the bulkhead thoroughly. It's a tough job to
replace, but your rig won't have any stability without a solid bulkhead.
Your beam replacement will be for not if the rest of it fails, and you can
always scarf in some new ply or use a plate joiner and epoxy if it's just
rotten at the compression post..
Your doing good work. Please consider my points an "encouragement" and keep
the faith. Old Cals are great sailing boats and worth the TLC.
David Wilkie Owen
Cal 2-29 "Mariposa"
Santa Barbara, CA
http://www.mariposasailing.com <http://www.mariposasailing.com/>
Of clausont
Sent: Friday, January 04, 2008 3:12 PM
Subject: [Cal_Boats] Re:Cal 29 Beam Replacement
as you mention.
--- In Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com,
sure of
few layers
over the
sufficient for
> your repairs.
around the
mast.
wood.
it will
project?)
> Alfred Poor
clausont2008-01-07 21:53
Sorry to hear that you have been down with the flu - that is
miserable. I have just ordered the Stainless sheet to build a new beam
(Wow! That stuff is expensive these days!) I will hopefully have it
finished within a week or two and re-installed.
I have now checked out the compression post, deck coring (again - I
did when I bought the boat but I checked again just in case I missed
anything.)and the bulkhead around the compression post. All in very
good shape. The bulkhead where the tabs were bolted through is
discolored but very sound. Even at that I will use a penetrating epoxy
on all of those areas before I finish in that area. The main bulkhead
in the chainplate area is good and sound also upon cursory inspection
but I still need to pull the chainplates to be sure. As mentioned -
now is the time to do it.
This boat came up here from San Diego and I suspect that it may have
sat for some time with salt water in the bilge as the wood up high is
in excellent shape while I have found a small amount of water damaged
wood at the bottom of a couple of lockers as though they had sat for a
while in water.
In checking things out I did find the bulkhead just aft of the galley
stove is rotted under the tabbing so I will need to pull that apart
and repair it and I am suspicious of one area near the forward
bulkhead on the starboard side. I need to dig in there when I am
finished with this beam.
I will be beveling the glass on all of the cuts that I made in the
cabin sole and reglassing it with layers of glass tape and epoxy. I
agree that it could not hurt to have some strength there.
I will keep everyone here posted on the progress.
Incidentally, this boat was originally named, "Vagabond" with the home
port as San Diego if anyone here happens to have ever seen it.
would be a
certainly the
makes a
engineer,
anyway, as
certainly
replacement, I
flexed like
> an inflatable.
obviously been
you can
just
and keep
> David Wilkie Owen
> _________________
> Cal 2-29 "Mariposa"
> Santa Barbara, CA
> _____
On Behalf
> Of clausont
> as you mention.
> sure of
> few layers
> over the
> sufficient for
> > your repairs.
> around the
inspect the
> mast.
> wood.
> it will
> project?)
> > Alfred Poor
Wilkie2008-01-08 01:42 UTC
Tim,
Flu Gone and ready for an Island Trip.
Thanks for all of the updates on your beam project. It's fun to have all of
that behind me. When I had my beam done, the supplier raised the price of
stainless the day my guy ordered it. They gave him the old price on my
chunk, since he was a good customer and had a bid out on it, but he said it
was going up every few weeks.
Good work on all fronts. Glad you're doing all of the deep investigation.
I think your theory of the beam being submerged "holds water" so to speak
considering the solid nature of your bulkheads. I forgot to close a 1 3/4"
pump out hole that I made on the side-deck one weekend when the rain came
and was absolutely amazed at how little time it took to fill the hull past
the pan. Fortunately, I caught it and dried it all out pretty quick.
The bulkhead tabbing and re-fairing is a job I won't ever do again. I'd saw
the boat into chunks first. LOL.
David Wilkie Owen
Cal 2-29 "Mariposa"
Santa Barbara, CA
Of clausont
Sent: Monday, January 07, 2008 1:54 PM
while in water.
would be a
certainly the
makes a
engineer,
anyway, as
certainly
replacement, I
flexed like
> an inflatable.
obviously been
you can
just
and keep
> David Wilkie Owen
> _________________
> Cal 2-29 "Mariposa"
> Santa Barbara, CA
> http://www.mariposa <http://www.mariposasailing.com> sailing.com
<http://www.mariposa <http://www.mariposasailing.com/> sailing.com/>
> _____
> From: Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com
[mailto:Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com]
On Behalf
> Of clausont
> To: Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com
> as you mention.
> sure of
> few layers
> over the
> sufficient for
> > your repairs.
> around the
inspect the
> mast.
> wood.
> it will
> project?)
> > Alfred Poor
clausont2008-01-13 01:21
Well, the beam has been build and re-installed. The glass work has
been started and I should be nearly finished with the glass work
tomorrow with the exception of some fairing.
Just for information for anyone doing this project in the future:
Apparently there has been a design change in the beam somewhere along
the way. As I was verifying the drawings that Alfred had given me
compared to my boat I noticed a few minor changes in my beam compared
to the drawing. It is not a huge change but just some small changes in
the web depth, tab spacing and flange width.
I am very pleased that the beam went back in as easily as it did. A
few hours of final fitting, adjusting, welding, grinding and drilling
and it was completed.
At one point during the installation, I was having a problem getting
the beam to move as far forward as I thought it should be. After
checking everything completely and carefully, I realized that the
center tab on the beam that had corroded completely had allowed the
compression post to move forward about 1/4". When everything was
bolted up again, this was corrected.
Well, next to tackle the one area that I am suspicious of near the
galley stove.
Tim
sure of
few layers
over the
sufficient for
> your repairs.
around the
mast.
wood.
it will
project?)
> Alfred Poor
