Augmenting charging system
C. Peter Audet2008-01-12 04:19 UTC
OK, I'm trying to fix my sad little Fischer Panda (long story...) and would like to get into solar panels and wind generator. We are never at a dock, so self-sufficiency is a necessity. We have a 400 amp bank of golf-cart batteries.
Any recommendations for either solar or wind? The trade winds rarely let up in Fajardo PR, so a wind genarator would be great, except for the noise and potential danger from blades. I've had KISS recommended as relatively quiet and efficient...
Solar panel is passive and "safe", but more limited in what can be generated, unless multiple panels are used$$$.
I would consider a Honda 2000 gas generator, but hope to get the little diesel going again.
Peter
"Bribon" Cal 39-II
RE: [Cal_Boats] Augmenting charging system
Downing, Thomas2008-01-14 11:42 UTC
I liked the KISS unit when I looked at it. The Ampair 100 is also very
quiet. The LVM generators seem to be fairly quiet, and are usually
well recomended. In fact, the KISS people recommend LVM if you
are going places where parts and shipping are sketchier.
Before buying, investigate the windspeed to power curve, as they
vary dramatically from maker to maker, and model to model from
the same maker.
So I guess it's a question of priorities. If quiet is no. 1, then KISS or
the Ampair 100 seem the way to go, from what I've discovered.
td
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of C. Peter Audet
Sent: Friday, January 11, 2008 11:19 PM
To: Cal Yahoo
Subject: [Cal_Boats] Augmenting charging system
Peter
"Bribon" Cal 39-II
DISCLAIMER:
