no-thru hull transducer
8 messages2008-02-08 14:28 UTCthrough 2008-02-08 18:41 UTC
carlos Solanilla2008-02-08 14:28 UTC
I purchased a while back a Charlie Morgan sailboat that had a thru hull transducer but it was mounted inside a pvc pipe that was cut at an angle and sealed with what I think is 5200 glue. The previous owner told me he use mineral oil as the conductive medium between the hull and the transducer crystals. I do not have the details on how to do it but it makes sense - I sell ultrasound equipment for a living and a depth finder is just that - the key is to avoid any air and sand the inner hull to the fibreglass level here is what I also found on a couple of site: http://www.alcommarine.com/transducers.htm or http://www.lei-extras.com/tips/transducer/default.asp I recalled one boat site wheere the owner showed pictures of how he took a thru-hull transducer but mounted it without cuttng the hull - I just can't recall it but it worked for him. In my Cal39 I just replaced the old transducer - the hole was there already so no biggie ____________________________________________________________________________________ Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
RE: [Cal_Boats] no-thru hull transducer
Downing, Thomas2008-02-08 15:42 UTC
This is a good way I believe. Get an end cap sized for the pipe you use, or even a threaded joint adapter and a threaded end cap. Cut a hole in the end cap to fit the transducer. This will keep the mineral oil from sloshing around while offering a secure mount for the xducer. td From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of carlos Solanilla Sent: Friday, February 08, 2008 9:29 AM To: Ca… [at] yahoogroups.com Subject: [Cal_Boats] no-thru hull transducer I purchased a while back a Charlie Morgan sailboat that had a thru hull transducer but it was mounted inside a pvc pipe that was cut at an angle and sealed with what I think is 5200 glue. The previous owner told me he use mineral oil as the conductive medium between the hull and the transducer crystals. Recent Activity * 1 New <http://groups.yahoo.com/group/Cal_Boats/spnew;_ylc=X3oDMTJnM2dpdWluBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDdnRsBHNsawN2cGhvdARzdGltZQMxMjAyNDgwOTI4> Photos Visit <http://groups.yahoo.com/group/Cal_Boats;_ylc=X3oDMTJmZjRvM2g4BF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDdnRsBHNsawN2Z2hwBHN0aW1lAzEyMDI0ODA5Mjg-> Your Group Health Zone Look <http://us.ard.yahoo.com/SIG=13odtqeio/M=493064.12016236.12445728.9977693/D=groups/S=1705065792:NC/Y=YAHOO/EXP=1202488129/L=/B=5MFaAkLaX9g-/J=1202480929195459/A=4430620/R=0/SIG=11fhbjsi1/*http://promotions.yahoo.com/healthandfitness/> your best! Groups to help you look & feel great. Yahoo! News Kevin <http://us.ard.yahoo.com/SIG=13ojhqgbn/M=493064.12016309.12445701.8674578/D=groups/S=1705065792:NC/Y=YAHOO/EXP=1202488129/L=/B=5cFaAkLaX9g-/J=1202480929195459/A=3848607/R=0/SIG=10q7s9jm5/*http://hotzone.yahoo.com> Sites Get coverage of world crises. Yahoo! Finance It's <http://us.ard.yahoo.com/SIG=13oajbu5j/M=493064.12016257.12445664.8674578/D=groups/S=1705065792:NC/Y=YAHOO/EXP=1202488129/L=/B=5sFaAkLaX9g-/J=1202480929195459/A=4507179/R=0/SIG=12de4rskk/*http://us.rd.yahoo.com/evt=50284/*http://finance.yahoo.com/personal-finance> Now Personal Guides, news, advice & more. . <http://portal.mxlogic.com/images/transparent.gif> DISCLAIMER: Important Notice ************************************************* This e-mail may contain information that is confidential, privileged or otherwise protected from disclosure. If you are not an intended recipient of this e-mail, do not duplicate or redistribute it by any means. Please delete it and any attachments and notify the sender that you have received it in error. Unintended recipients are prohibited from taking action on the basis of information in this e-mail.E-mail messages may contain computer viruses or other defects, may not be accurately replicated on other systems, or may be intercepted, deleted or interfered with without the knowledge of the sender or the intended recipient. If you are not comfortable with the risks associated with e-mail messages, you may decide not to use e-mail to communicate with IPC. IPC reserves the right, to the extent and under circumstances permitted by applicable law, to retain, monitor and intercept e-mail messages to and from its systems.
Wilkie2008-02-08 16:25 UTC
Put me in the epoxy camp. I have a cheapo Horizon DF with the thru hull puck. Horizon's puck has an angle on the bottom so that you can spin it around until it sits level on a somewhat sloped surface. I actually epoxied it in place under the aft portion of my interior floor pan where it can't get bumped or have stuff fall on it. Another TIP: Mix the epoxy very slowly to avoid bubbles and let it sit a while before deployment. As for it's effectiveness, it reads perfectly to around 450' depth and then gets spotty over 500'. Like many sailors, my interest starts to wander after about 30'. Even contour navigation shouldn't require over 400'. Wilkie From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Downing, Thomas Sent: Friday, February 08, 2008 7:43 AM To: Ca… [at] yahoogroups.com Subject: RE: [Cal_Boats] no-thru hull transducer This is a good way I believe. Get an end cap sized for the pipe you use, or even a threaded joint adapter and a threaded end cap. Cut a hole in the end cap to fit the transducer. This will keep the mineral oil from sloshing around while offering a secure mount for the xducer. td -----Original Message----- From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of carlos Solanilla Sent: Friday, February 08, 2008 9:29 AM To: Ca… [at] yahoogroups.com Subject: [Cal_Boats] no-thru hull transducer I purchased a while back a Charlie Morgan sailboat that had a thru hull transducer but it was mounted inside a pvc pipe that was cut at an angle and sealed with what I think is 5200 glue. The previous owner told me he use mineral oil as the conductive medium between the hull and the transducer crystals. . <http://portal.mxlogic.com/images/transparent.gif> DISCLAIMER: Important Notice ************************************************* This e-mail may contain information that is confidential, privileged or otherwise protected from disclosure. If you are not an intended recipient of this e-mail, do not duplicate or redistribute it by any means. Please delete it and any attachments and notify the sender that you have received it in error. Unintended recipients are prohibited from taking action on the basis of information in this e-mail.E-mail messages may contain computer viruses or other defects, may not be accurately replicated on other systems, or may be intercepted, deleted or interfered with without the knowledge of the sender or the intended recipient. If you are not comfortable with the risks associated with e-mail messages, you may decide not to use e-mail to communicate with IPC. IPC reserves the right, to the extent and under circumstances permitted by applicable law, to retain, monitor and intercept e-mail messages to and from its systems.
Re: no-thru hull transducer
mtkennedy12008-02-08 16:36
--- In Ca… [at] yahoogroups.com, carlos Solanilla <carlosproacarlos@...> wrote: > > I purchased a while back a Charlie Morgan sailboat that had a thru hull transducer but it was mounted inside a pvc pipe that was cut at an angle and sealed with what I think is 5200 glue. The previous owner told me he use mineral oil as the conductive medium between the hull and the transducer crystals. I do not have the details on how to do it but it makes sense - I sell ultrasound equipment for a living and a depth finder is just that - the key is to avoid any air and sand the inner hull to the fibreglass level I had just such a depth sounder transducer in one of my previous boats. It was mounted to the lid of a box that was glassed to the hull and filled with mineral oil. The box and lid were 1/2 inch plywood and the top could be removed with four screws to inspect or change the transducer. Of course, newer transducers like the one I have now, also have other functions, such as a water temperature gauge, which would not be accurate in such a mount. The depth sounder worked fine. Mike Kennedy Conquest Cal 40 # 96
r good2008-02-08 17:07 UTC
amazing amounts of knowledge, dude. Quick! Burn some frequent flyer miles. Meet us in Fort Lauderdale on Monday! Reggie and Barbara To: Ca… [at] yahoogroups.comFrom: wi… [at] mariposasailing.comDate: Fri, 8 Feb 2008 08:25:47 -0800Subject: RE: [Cal_Boats] no-thru hull transducer Put me in the epoxy camp. I have a cheapo Horizon DF with the thru hullpuck. Horizon's puck has an angle on the bottom so that you can spin itaround until it sits level on a somewhat sloped surface. I actually epoxiedit in place under the aft portion of my interior floor pan where it can'tget bumped or have stuff fall on it. Another TIP: Mix the epoxy veryslowly to avoid bubbles and let it sit a while before deployment.As for it's effectiveness, it reads perfectly to around 450' depth and thengets spotty over 500'. Like many sailors, my interest starts to wanderafter about 30'. Even contour navigation shouldn't require over 400'.Wilkie -----Original Message-----From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On BehalfOf Downing, ThomasSent: Friday, February 08, 2008 7:43 AMTo: Ca… [at] yahoogroups.comSubject: RE: [Cal_Boats] no-thru hull transducerThis is a good way I believe. Get an end cap sized for the pipe you use, oreven a threaded joint adapter and a threaded end cap. Cut a hole in the endcap to fit the transducer. This will keep the mineral oil from sloshingaround while offering a secure mount for the xducer.td-----Original Message-----From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]OnBehalf Of carlos SolanillaSent: Friday, February 08, 2008 9:29 AMTo: Ca… [at] yahoogroups.comSubject: [Cal_Boats] no-thru hull transducerI purchased a while back a Charlie Morgan sailboat that had a thruhull transducer but it was mounted inside a pvc pipe that was cut at anangle and sealed with what I think is 5200 glue. The previous owner told mehe use mineral oil as the conductive medium between the hull and thetransducer crystals. .<http://portal.mxlogic.com/images/transparent.gif> DISCLAIMER:Important Notice *************************************************This e-mail may contain information that is confidential, privileged orotherwise protected from disclosure. If you are not an intended recipient ofthis e-mail, do not duplicate or redistribute it by any means. Please deleteit and any attachments and notify the sender that you have received it inerror. Unintended recipients are prohibited from taking action on the basisof information in this e-mail.E-mail messages may contain computer virusesor other defects, may not be accurately replicated on other systems, or maybe intercepted, deleted or interfered with without the knowledge of thesender or the intended recipient. If you are not comfortable with the risksassociated with e-mail messages, you may decide not to use e-mail tocommunicate with IPC. IPC reserves the right, to the extent and undercircumstances permitted by applicable law, to retain, monitor and intercepte-mail messages to and from its systems.
RE: [Cal_Boats] no-thru hull transducer(Wilkei)
Gerald Sobel2008-02-08 17:19 UTC
Wilkie, Having spotty depth readings at over 500' depth? I can see this could be a problem if you boat has one of those new extreme estreme high aspect ratio keels that draws over 500'. You could easily run aground and sink her. What me worry? Shpritz jumped the sunken jetty while lost in the dark at the end of the Marina del Rey to San Diego Race, three years ago, wooooieeee! I draws only 2.5'. It did bang my centerboard a bit, which swung up into the keel when I struck the rocks. Ha Ha, I'll never do that again. Jerry --- On Fri, 2/8/08, Wilkie <wi… [at] mariposasailing.com> wrote: From: Wilkie <wi… [at] mariposasailing.com> Subject: RE: [Cal_Boats] no-thru hull transducer To: Ca… [at] yahoogroups.com Date: Friday, February 8, 2008, 8:25 AM Put me in the epoxy camp. I have a cheapo Horizon DF with the thru hull puck. Horizon's puck has an angle on the bottom so that you can spin it around until it sits level on a somewhat sloped surface. I actually epoxied it in place under the aft portion of my interior floor pan where it can't get bumped or have stuff fall on it. Another TIP: Mix the epoxy very slowly to avoid bubbles and let it sit a while before deployment. As for it's effectiveness, it reads perfectly to around 450' depth and then gets spotty over 500'. Like many sailors, my interest starts to wander after about 30'. Even contour navigation shouldn't require over 400'. Wilkie From: Cal_Boats@yahoogrou ps.com [mailto: Cal_Boats@yahoogrou ps.com ] On Behalf Of Downing, Thomas Sent: Friday, February 08, 2008 7:43 AM To: Cal_Boats@yahoogrou ps.com Subject: RE: [Cal_Boats] no-thru hull transducer This is a good way I believe. Get an end cap sized for the pipe you use, or even a threaded joint adapter and a threaded end cap. Cut a hole in the end cap to fit the transducer. This will keep the mineral oil from sloshing around while offering a secure mount for the xducer. td From: Cal_Boats@yahoogrou ps.com [mailto: Cal_Boats@yahoogrou ps.com ]On Behalf Of carlos Solanilla Sent: Friday, February 08, 2008 9:29 AM To: Cal_Boats@yahoogrou ps.com Subject: [Cal_Boats] no-thru hull transducer I purchased a while back a Charlie Morgan sailboat that had a thru hull transducer but it was mounted inside a pvc pipe that was cut at an angle and sealed with what I think is 5200 glue. The previous owner told me he use mineral oil as the conductive medium between the hull and the transducer crystals. . < http://portal. mxlogic.com/ images/transpare nt.gif > DISCLAIMER: Important Notice ************ ********* ********* ********* ********* * This e-mail may contain information that is confidential, privileged or otherwise protected from disclosure. If you are not an intended recipient of this e-mail, do not duplicate or redistribute it by any means. Please delete it and any attachments and notify the sender that you have received it in error. Unintended recipients are prohibited from taking action on the basis of information in this e-mail.E-mail messages may contain computer viruses or other defects, may not be accurately replicated on other systems, or may be intercepted, deleted or interfered with without the knowledge of the sender or the intended recipient. If you are not comfortable with the risks associated with e-mail messages, you may decide not to use e-mail to communicate with IPC. IPC reserves the right, to the extent and under circumstances permitted by applicable law, to retain, monitor and intercept e-mail messages to and from its systems.
CC36 in Florida
Wilkie2008-02-08 18:37 UTC
Good Lord, Man! Don't you know I've been thinking about this since you first posted? Just can't do it right now. sigh. Wilkie From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of r good Sent: Friday, February 08, 2008 9:07 AM To: ca… [at] yahoogroups.com Subject: RE: [Cal_Boats] no-thru hull transducer amazing amounts of knowledge, dude. Quick! Burn some frequent flyer miles. Meet us in Fort Lauderdale on Monday! Reggie and Barbara To: Ca… [at] yahoogroups.com From: wi… [at] mariposasailing.com Date: Fri, 8 Feb 2008 08:25:47 -0800 Subject: RE: [Cal_Boats] no-thru hull transducer Put me in the epoxy camp. I have a cheapo Horizon DF with the thru hull puck. Horizon's puck has an angle on the bottom so that you can spin it around until it sits level on a somewhat sloped surface. I actually epoxied it in place under the aft portion of my interior floor pan where it can't get bumped or have stuff fall on it. Another TIP: Mix the epoxy very slowly to avoid bubbles and let it sit a while before deployment. As for it's effectiveness, it reads perfectly to around 450' depth and then gets spotty over 500'. Like many sailors, my interest starts to wander after about 30'. Even contour navigation shouldn't require over 400'. Wilkie -----Original Message----- From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> ] On Behalf Of Downing, Thomas Sent: Friday, February 08, 2008 7:43 AM To: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> Subject: RE: [Cal_Boats] no-thru hull transducer This is a good way I believe. Get an end cap sized for the pipe you use, or even a threaded joint adapter and a threaded end cap. Cut a hole in the end cap to fit the transducer. This will keep the mineral oil from sloshing around while offering a secure mount for the xducer. td -----Original Message----- From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> ]On Behalf Of carlos Solanilla Sent: Friday, February 08, 2008 9:29 AM To: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> Subject: [Cal_Boats] no-thru hull transducer I purchased a while back a Charlie Morgan sailboat that had a thru hull transducer but it was mounted inside a pvc pipe that was cut at an angle and sealed with what I think is 5200 glue. The previous owner told me he use mineral oil as the conductive medium between the hull and the transducer crystals. . <http://portal.mxlogic.com/images/transparent.gif <http://portal.mxlogic.com/images/transparent.gif> > DISCLAIMER: Important Notice ************************************************* This e-mail may contain information that is confidential, privileged or otherwise protected from disclosure. If you are not an intended recipient of this e-mail, do not duplicate or redistribute it by any means. Please delete it and any attachments and notify the sender that you have received it in error. Unintended recipients are prohibited from taking action on the basis of information in this e-mail.E-mail messages may contain computer viruses or other defects, may not be accurately replicated on other systems, or may be intercepted, deleted or interfered with without the knowledge of the sender or the intended recipient. If you are not comfortable with the risks associated with e-mail messages, you may decide not to use e-mail to communicate with IPC. IPC reserves the right, to the extent and under circumstances permitted by applicable law, to retain, monitor and intercept e-mail messages to and from its systems.
RE: [Cal_Boats] CC36 in Florida
r good2008-02-08 18:41 UTC
it will be a many day trip. Join us along the way.........once we know where we are going! To: Ca… [at] yahoogroups.comFrom: wi… [at] mariposasailing.comDate: Fri, 8 Feb 2008 10:37:47 -0800Subject: [Cal_Boats] CC36 in Florida Good Lord, Man! Don't you know I've been thinking about this since youfirst posted?Just can't do it right now. sigh.Wilkie -----Original Message-----From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On BehalfOf r goodSent: Friday, February 08, 2008 9:07 AMTo: ca… [at] yahoogroups.comSubject: RE: [Cal_Boats] no-thru hull transduceramazing amounts of knowledge, dude.Quick! Burn some frequent flyer miles. Meet us in Fort Lauderdale onMonday!Reggie and Barbara________________________________To: Ca… [at] yahoogroups.comFrom: wi… [at] mariposasailing.comDate: Fri, 8 Feb 2008 08:25:47 -0800Subject: RE: [Cal_Boats] no-thru hull transducerPut me in the epoxy camp. I have a cheapo Horizon DF with the thruhullpuck. Horizon's puck has an angle on the bottom so that you can spinitaround until it sits level on a somewhat sloped surface. I actuallyepoxiedit in place under the aft portion of my interior floor pan where itcan'tget bumped or have stuff fall on it. Another TIP: Mix the epoxy veryslowly to avoid bubbles and let it sit a while before deployment.As for it's effectiveness, it reads perfectly to around 450' depthand thengets spotty over 500'. Like many sailors, my interest starts towanderafter about 30'. Even contour navigation shouldn't require over400'.Wilkie -----Original Message-----From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>[mailto:Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> ] OnBehalfOf Downing, ThomasSent: Friday, February 08, 2008 7:43 AMTo: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> Subject: RE: [Cal_Boats] no-thru hull transducerThis is a good way I believe. Get an end cap sized for the pipe youuse, oreven a threaded joint adapter and a threaded end cap. Cut a hole inthe endcap to fit the transducer. This will keep the mineral oil fromsloshingaround while offering a secure mount for the xducer.td-----Original Message-----From: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>[mailto:Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> ]OnBehalf Of carlos SolanillaSent: Friday, February 08, 2008 9:29 AMTo: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> Subject: [Cal_Boats] no-thru hull transducerI purchased a while back a Charlie Morgan sailboat that had a thruhull transducer but it was mounted inside a pvc pipe that was cut atanangle and sealed with what I think is 5200 glue. The previous ownertold mehe use mineral oil as the conductive medium between the hull and thetransducer crystals. .<http://portal.mxlogic.com/images/transparent.gif<http://portal.mxlogic.com/images/transparent.gif> > DISCLAIMER:Important Notice *************************************************This e-mail may contain information that is confidential, privilegedorotherwise protected from disclosure. If you are not an intendedrecipient ofthis e-mail, do not duplicate or redistribute it by any means.Please deleteit and any attachments and notify the sender that you have receivedit inerror. Unintended recipients are prohibited from taking action onthe basisof information in this e-mail.E-mail messages may contain computervirusesor other defects, may not be accurately replicated on other systems,or maybe intercepted, deleted or interfered with without the knowledge ofthesender or the intended recipient. If you are not comfortable withthe risksassociated with e-mail messages, you may decide not to use e-mail tocommunicate with IPC. IPC reserves the right, to the extent andundercircumstances permitted by applicable law, to retain, monitor andintercepte-mail messages to and from its systems. It
