2 messages2008-02-08 18:19 UTCthrough 2008-02-09 15:45 UTC
Re: [Cal_Boats] no-thru hull transducer
ti… [at] ch2m.com2008-02-08 18:19 UTC
Nexus_Silva use to make an inside transducer mount - looked like a top hat. These may still be available. Mount glued inside hull, filled with oil, then xducer mounted. I had my depth xducer silicone to the hull, inside the hanging closet.
Timmo
Sent: Fri Feb 08 08:42:56 2008
Subject: RE: [Cal_Boats] no-thru hull transducer
This is a good way I believe. Get an end cap sized for the pipe you use,
or even a threaded joint adapter and a threaded end cap. Cut a hole in
the end cap to fit the transducer. This will keep the mineral oil from
sloshing around while offering a secure mount for the xducer.
td
-----Original Message-----
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of carlos Solanilla
Sent: Friday, February 08, 2008 9:29 AM
Subject: [Cal_Boats] no-thru hull transducer
I purchased a while back a Charlie Morgan sailboat that had a thru hull transducer but it was mounted inside a pvc pipe that was cut at an angle and sealed with what I think is 5200 glue. The previous owner told me he use mineral oil as the conductive medium between the hull and the transducer crystals.
<http://portal.mxlogic.com/images/transparent.gif>
DISCLAIMER:
Randy Alcorn2008-02-09 15:45 UTC
I have a Garmin fish finder I purchased for 1000 ft salt water. I troll the Sea Mounts off SoCal. I sent a email to Garmin asking about silicone and they recommend something like West Marine two part epoxy to mount the transducer inside the hull.
Randy
CAL 2-29
Out Patient
Channel Islands Ca
Timmo
td
DISCLAIMER:
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
