3 messages2008-03-04 14:55 through 2008-03-04 23:31
Farymann dry-run/new fuel tank
wnancy362008-03-04 14:55
Greetings all,
We recently aquired a new-to-us Farymann A30 engine (my Valentine's
Day gift actually!) to replace our failed Farymann. The new-to-us
engine appears to be in MUCH better condition than the one we removed
and due to cost constraints appears to be our best option for a
temporary re-power until we win the lottery. The previous owner had
it rebuilt twice over its 30 year life (including replacing the
cooling sleeve) and though it was running great when he pulled it,
decided to repower with something newer.
The question for the list is: I wonder about the feasability of
firing it up and running the engine briefly before we install it.
And if we do run the engine - how does one ensure a good clean fuel
source? Do I need to go to the lengths of temporarily rigging up the
primary fuel filter? Just concerned since everything I read about
diesels goes on at great lengthsabout the neccesity of maintaining a
clean fuel line etc.
And while the engine is out I am considering pulling/replacing or
cleaning the old black metal fuel tank - even though we have never
had any problems in the 6 years we have had the boat.
Any help much appreciated on this rather daunting project! Thanks!!!
Nancy Lewis-Williams
2-27 Windancer
Vashon Island
Re: [Cal_Boats] Farymann dry-run/new fuel tank
Joe DeMers2008-03-04 15:38 UTC
We test run engines all the time Nancy, and do it this way - [ in order ! ]
First, put on safety glasses and wear latex gloves. [ this keeps your hands
kissably soft ]
Secure the engine to the bench, shipping pallet, etc, as this engine wants
to jump around a lot while running!
Change the secondary fuel filter [ on the engine ]
Check the oil level in engine and trans.
Put the fuel intake hose into a container of fresh [ NOT OLD ! ] and CLEAN
fuel! [ you may need to install a fuel return hose to tank, although I think
I remember this engine does not use one ]
Open the fuel filter bleed screw.
Engage the compression release. Remove the air filter housing, and spray
fogging oil into the air intake while cranking the engine with the hand
crank. This prelubes the cylinder so you don't break a piston ring. It also
bleeds the low pressure side of the fuel system.
Put the water intake hose into a bucket of water.
Place a long length of hose onto the exhaust elbow, and direct it away from
your work area.
Get an assistant to standby [ upwind ! ] with a fire extinguisher.
Set the fuel control to maximum speed.
Finish bleeding the fuel system, using the fuel lift pump, then close the
bleed screw.
Connect the control panel and battery cables.
Crank the engine with the ignition key, and while cranking, disengage the
compression release. The engine should now fire.
It will smoke quite a bit, as the fogging oil is burned, but should clear in
a while.
Slow the engine using the fuel control.
Check that water is being discharged from the exhaust, and maintain the
bucket's water level, using a garden hose.
Check for correct operation of the transmission, and that you can actually
control the engine speed.
That's about it!
Contact me if you have a problem.
Joe DeMers
Sound Marine Diesel LLC
www.soundmarinediesel.com
Sent: Tuesday, March 04, 2008 9:55 AM
Subject: [Cal_Boats] Farymann dry-run/new fuel tank
> Greetings all,
> 2-27 Windancer
> Vashon Island
> Yahoo! Groups Links
> Checked by AVG Free Edition.
> Version: 7.5.516 / Virus Database: 269.21.3/1306 - Release Date: 3/1/2008
> 5:41 PM
Re: Farymann dry-run/new fuel tank
wnancy362008-03-04 23:31
--- In Ca… [at] yahoogroups.com, "Joe DeMers" <jedsail@...> wrote:
Joe,
Many thanks for the comprehensive information, this looks like
exactly what I need!
Nancy>
order ! ]
your hands
> kissably soft ]
engine wants
and CLEAN
although I think
spray
hand
It also
away from
> your work area.
close the
> bleed screw.
disengage the
clear in
> a while.
the
actually
> That's about it!
> Joe DeMers
> ----- Original Message -----
> From: "wnancy36" <jnnwill2@...>
> > Greetings all,
Valentine's
removed
had
fuel
the
maintaining a
Thanks!!!
> > 2-27 Windancer
> > Vashon Island
> > Yahoo! Groups Links
3/1/2008
> > 5:41 PM
