8 messages2008-03-13 00:38 UTCthrough 2008-03-13 21:47 UTC
Re: Beer Preferences (Jerry) [compass bubble and vodka
bill kusmik2008-03-13 00:38 UTC
In discussions with the service department of Richie in Massachusetts, I have learned that they use odorless paint thinner at the factory.
Bill Kusmik
"Alexa"
Annapolis
compass bubble and vodka (thinner)
john raxter2008-03-13 11:49 UTC
This is what I have been told as well. So when a bubble developed in my
compass over a winter, I bought a small bottle at the HD and used a epoxy
hypo to inject the fluid into the fill hole. You really need to be careful
on how you handle the compass upside down. I rotated mine off the spindle
and it took a little more effort to get the card to spin properly.
Chris, (I think if you use the flame test, paint thinner may burn also)
YMMV
John
Of bill kusmik
Sent: Wednesday, March 12, 2008 8:38 PM
Subject: [SPAM][Cal_Boats] Re: Beer Preferences (Jerry) [compass bubble and
vodka
Bill Kusmik
"Alexa"
Annapolis
Re: [Cal_Boats] Re: Beer Preferences (Jerry) [compass bubble and vodka
Chris Campbell2008-03-13 13:55 UTC
That's useful info for us Ritchie owners.
I was discussing alcohol behavior with somebody on this list and the
question was whether in a 50/50 alcohol/water mix the alcohol evaporates
faster than water or they go off together. I posed the question to a
friend who is a sailor and chemistry teacher. Here's what he said:
Chris, There is an attraction between ethyl alcohol and water and
the attraction is due to hydrogen bonding. However, the alcohol is
somewhat less strongly held as evidence from the fact that when you
start the distilling process you get mostly alcohol with just a
little water. As the process continues the amount of alcohol that
comes across decreases and the amount of water increases. You shut
down the still when you get the proof you want.
Now, when we use alcohol and water in a compass, we're not doing it at
the boiling point, so maybe the alcohol is more likely to stay bonded
and to evaporate with, and not before, the water.
Freezing Spirits - compass - rebuilds
Wilkie2008-03-13 18:10 UTC
I posted all of this earlier, but my post was rejected (apparently sent from
wrong email address on my notebook.) Sorry...
So Odorless Mineral Spirits is the bomb for sure, but an additional tip is
to keep the can in your freezer for 24 hours before you fill the compass and
replace all of the thinner instead of just topping it off. Then-- when you
discover that no matter how hard you try with your little syringe you just
can't fill it enough to avoid that last little bubble -- it's no problem.
As the freezing cold mineral spirits warm up, it assimilates the oxygen in
the bubble and it will disappear forever. It really works.
And by the way.... after cracking the globe on my Globemaster last year, it
ended up being cheaper to have Ritchie rebuild it than to buy the parts.
They have a "fixed repair rate" and what they do is upgrade every part of
the compass that has been improved over the years. Since my compass was 30
years old, it was a completely different unit when it came home. The tech
that called for my credit card number told me the only part not replaced was
the original Stainless Steel shell. So I got a new $550 compass for $225.
The card, lighting, damping, everything works better than ever...
Wilkie
Of john raxter
Sent: Thursday, March 13, 2008 4:49 AM
Subject: [Cal_Boats] compass bubble and vodka (thinner)
YMMV
John
Of bill kusmik
vodka
Bill Kusmik
"Alexa"
Annapolis
Husar, Charlie [USA]2008-03-13 18:20 UTC
Interesting, David. I like it.
The question I had throughout this discussion is how the compass started
leaking in the first place. If we are using oils and the like to
refill, then repairing any cracks would be quite difficult from an
adhesion point of view.
Behalf Of Wilkie
Sent: Thursday, March 13, 2008 2:10 PM
Subject: [Cal_Boats] Freezing Spirits - compass - rebuilds
from wrong email address on my notebook.) Sorry...
is to keep the can in your freezer for 24 hours before you fill the
compass and replace all of the thinner instead of just topping it off.
Then-- when you discover that no matter how hard you try with your
little syringe you just can't fill it enough to avoid that last little
in the bubble and it will disappear forever. It really works.
year, it ended up being cheaper to have Ritchie rebuild it than to buy
the parts.
of the compass that has been improved over the years. Since my compass
was 30 years old, it was a completely different unit when it came home.
The tech that called for my credit card number told me the only part not
replaced was the original Stainless Steel shell. So I got a new $550
compass for $225.
Wilkie
Behalf Of john raxter
epoxy hypo to inject the fluid into the fill hole. You really need to
be careful on how you handle the compass upside down. I rotated mine
off the spindle and it took a little more effort to get the card to spin
properly.
YMMV
John
Behalf Of bill kusmik
and vodka
Bill Kusmik
"Alexa"
Annapolis
Yahoo! Groups Links
RE: [Cal_Boats] Freezing Spirits - compass - rebuilds
Wilkie2008-03-13 19:00 UTC
The first bubble that appeared seemed to be an 0-ring between the two globe
halves or the one that sealed the fill screw. I replaced both rubber seals,
used the freezing mineral spirits and no bubble for 5 years.
I hit the globe hard enough to crack it with a winch handle during a 30 Knot
channel crossing. The globe was crazed around the perimeter and one good
knock was all it took. A large bubble appeared and kept growing rapidly...
Thus the rebuild.
Wilkie
Of Husar, Charlie [USA]
Sent: Thursday, March 13, 2008 11:20 AM
leaking in the first place. If we are using oils and the like to refill,
then repairing any cracks would be quite difficult from an adhesion point of
view.
From: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>
[mailto:Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com> ] On
Behalf Of Wilkie
To: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>
Then-- when you discover that no matter how hard you try with your little
syringe you just can't fill it enough to avoid that last little bubble --
it's no problem.
replaced was the original Stainless Steel shell. So I got a new $550 compass
for $225.
Wilkie
YMMV
John
vodka
Bill Kusmik
"Alexa"
Annapolis
Yahoo! Groups Links
Re: [Cal_Boats] Freezing Spirits - compass - rebuilds
Chris Campbell2008-03-13 19:02 UTC
> compass and
You guys keep challenging my very tenuous grasp of chemistry and physics
here, but it's my understanding that water, at least, holds more
dissolved oxygen when cold than when hot (what happens when you heat
water in a pan?--the oxygen comes out of solution and forms
bubbles--same with the bottle of pop or beer as it warms up).
I wonder if what's really going on is that the dissolved gas is under
higher pressure because the fluid is under higher pressure as it warms
up and expands. Higher pressure means it has less tendency to come out
of solution. Again, look at what happens when you pop the cap on pop or
beer containers--you get a puff of gas, pressure drops, bubbles form.
Mark Alan Stahnke (MAS Consulting)2008-03-13 21:47 UTC
I think the Vodka and Mineral Spirits will work together: 1) put both in the freezer, 2) down the Vodka while injecting the Spirits into the compass! 3) clean the compass lenses with the Spirits and any leftover Vodka.
Mark
Cal 2-29
San Pedro
-----Original Message-----
Behalf Of Wilkie
the parts.
compass for $225.
Wilkie
properly.
YMMV
John
and vodka
Bill Kusmik
"Alexa"
Annapolis
Yahoo! Groups Links
__________ Information from ESET NOD32 Antivirus, version of virus signature database 2945 (20080313) __________
http://www.eset.com
