Cal 39 Mast Step
Sorry that last post slipped out . . .
As I started to say . . . I am prepping the boat to do the Annapolis to
Bermuda race so the mast will actually be bolted to the step per the race
instructions so that won't be an issue. In addition, my rigger is doubling the
thickness of the plate that the mast step is bolted to. So as long as the plate
doesn't snap the 6 bolts holding it to the grid I'll be okay.
I'd still like to find out what the grid is constructed of.
Paul
In a message dated 4/25/2008 5:30:25 P.M. Eastern Daylight Time,
im… [at] yahoo.com writes:
Paul,
There are plenty of Cal 39'rs on the list. Jim Williams through a great get
together last year for local Cals called Caltopia. On Saturday morning of
that weekend, one gent with a Cal 39 gave a great presentation on his South
Pacific trip and lessons learned. His mast came loose during that trip due to
problem at the step and he described the fix. Unfortunately I can't
remember his name.
If you get in touch with Jim through the list, I bet he can give the contact
info for that Cal 39 owner. You also might be able to contact Jim through
the Encinal YC in Alameda Ca
_http://www.encinal.http_ (http://www.encinal.org/)
Dave
80 Cal 35 Runnin Late
Coyote Pt, SF Bay
To: Cal_Boats@yahoogrouTo: Ca
Sent: Friday, April 25, 2008 9:18:29 AM
Subject: Re: [Cal_Boats] Any Cal 39 owners on this list?
Bob -
Thanks for responding. I posted the following question(s) the other day and
didn't hear a peep from anyone so I was just curious and a little concerned
actually. I realize not everyone has an answer for everything but it just
seemed odd that no one had a comment at all. Anyway, glad to know you're out
there and even on the same coast!
Paul West
Cal 39
Adventure Kwest
Cambridge, MD
<I have the mast removed from my recently purchased Cal 39 and found that
the stainless steel plate that the mast step sits on has bent to conform to
whatever material it is that it sits on. I have removed the plate but cannot
determine from tapping on it, what the ultimate "mast step" is made of . It is
all covered in fiberglass and there appears to be 3 beams running side to
side with some other material in between and it is this material that appears to
have settled approximately 1/8".
Unless someone has a better idea, my plan was to mix up a slurry mixture of
some West System Epoxy mixed with #403 silica for its bonding and hardness
properties and pour this onto the step, letting it fill all the voids and then
seek its own level. The only problem I can see with this process is that the
boat is not likely to be sitting level on the hard and is probably bow up
to make sure the water drains to the scuppers. I don't know if it is severe
enough that it would create a surface on the mast step that is pitched far
enough forward so as to screw up the angle of the mast but I suppose I could put
a level on it and see what I'm dealing with.
Also the base of the mast was corroded so my rigger is going to cut some
material off the base and cut a plate the same thickness as what he takes off
the bottom to put under the mast step so I don't lose any height. He is also
going to weld another plate to the existing bent plate to strengthen it.
Speaking of mast angle, anyone know that the optimum rake is for the Cal 39?>
To: Cal_Boats@yahoogrou _ps.com_ (http://ps.com/)
Sent: Fri, 25 Apr 2008 12:06 pm
I have a 39 - there are a lot of 39 owners on the list I believe.
Bob Andrew
Cal 39 Nereid
Norwalk, CT
On 4/25/08, _pwestla@aol. com_ (mailto:pw… [at] aol.com) <_pwestla@aol. com_
(mailto:pw… [at] aol.com) > wrote:
Just curious if anyone has any experience with these boats at all, sailing,
racing repairing . . . anything at all or am I on my own with this boat?
Thanks -
Paul West
Cal 39
Adventure Kwest
Cambridge, MD
Plan your next roadtrip with _MapQuest.com_
(http://www.mapquest.com/?ncid=mpqmap00030000000004) : America's #1 Mapping Site.
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. _Try it
now._
(http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ)
**************Need a new ride? Check out the largest site for U.S. used car
listings at AOL Autos.
(http://autos.aol.com/used?NCID=aolcmp00300000002851)
