Re: [Cal_Boats] removing green stains from lines and sheets
1 messages2008-05-23 15:15 UTCthrough 2008-05-23 15:15 UTC
Rodney G Johnson2008-05-23 15:15 UTC
OxyClean uses oxalic acid as a cleaning/bleaching ingredient. OxyClean is the name-brand cleaning powder that Billy Mays is (or was?) always hawking on TV infermercials. It should be safe for use on lines. Chlorine Bleach can due harm to lines, although a very weak solution might be OK. Rod Johnson, "NODROG" 1970 CAL 21 #285 On Fri, 23 May 2008 10:59:54 -0400 Chris Campbell <cl… [at] charterinternet.com> writes: Husar, Charlie [USA] wrote: How about a soaking in an OxyClean solution? Should be able to get rid of organic stains. I'm not sure what Oxyclean is, but I have some sort of vague recollection that nylon and bleach weren't very compatible. Chris Campbell
