6 messages2008-06-03 15:33 UTCthrough 2008-06-04 12:22 UTC
Re: [Cal_Boats] Handling spinnaker rolling (Fin, Paul)
Donald Dutton2008-06-03 15:33 UTC
I agree, heading up 10 degrees will have the same effect, with one small problem. I'm assuming you're in a tight race and have achieved a tactical position that suits you at the time. Heading up on the rolls has the possible affect of losing your position on your competition. Trimming the sheet at the same time as the mast is vertical will kill the roll without changing your position. It is harder work and usually requires at least two people, one to grind and one to trim with 3 to 4 wraps on the winch, but trimming saves your advantage on the other boats.
Sent: Tuesday, June 3, 2008 8:08:23 AM
Subject: Re: [Cal_Boats] Handling spinnaker rolling (Thomas)
Our experience with rolling come from sailing dead down in high winds. What we do is choke the chute down and get it as close to the deck as possible to reduce the leverage the wind has aloft. We tweaked it down hard, didn't play it, and put everyone on the stern with the exception of the guy holding onto the chute so he could blow it if necessary. The rolling will also stop if you head up a few degrees.
Paul
Sent: Tue, 3 Jun 2008 10:55 am
This is similar to the same effect that can crash motorcycles at speed where an oscillation begins and if it is not countered, it can build to a destructive level. I would try to control it with sheet tensioning and easing. If on port tack and the boat begins to roll to port, try sharply trimming the starboard sheet and flattening the spinnaker. This should overpower the chute and pull the boat back flat. As the boat tries to roll back to starboard, time the easing of the sheet with the roll so that the spinnaker stays in one position with the wind as the boat tries to roll. This should lower the leeward pull of the chute and ease the force on the roll. Since you said that the boats sail more like dinghies than keel boats this is the technique that I used in Flying Scots in high wind oscillations and I was also successful keeping an Olson 34 flat in a 4' D-chop and 28 knots of wind on Galveston Bay with this technique.
Let me know what you think.
Sent: Tuesday, June 3, 2008 4:50:48 AM
Subject: RE: [Cal_Boats] Handling spinnaker rolling
Thanks for the response.
By "spinnaker roll" I was referring to the situation where the
boat begins to roll, with the roll angle increasing with each
oscillation - something to do with apparent wind changes during
the roll accelerating the roll, as I understand it.
During these roll events, there is no marked tendency to round
up or down. We had the "beetle" quite high, with the shoulders
well filled out, no luffing. Hauling the tweekers brought the
beetle down, but it did not affect the rolling.
I'm not experienced with Atlantic 30's, but while keelboats, they
sail a lot more like dinghys. Some of the skippers in this
fleet are Nationals winners - so I figure they know something.
I notice that spin techniques are a bit different on these boats.
Nobody sails with the clews at the same height - the pole end is
always a bit higher. Also, the pole is kept forward of 90
to the apparent, and the outboard end is carried much higher than
the mast end. Lastly, the the edge of the spinnaker is set so
that it goes up slightly outside of the pole tip.
td
From: Cal_Boats@yahoogrou ps.com on behalf of timmothy.lessley@ ch2m.com
Sent: Mon 6/2/2008 8:51 AM
Subject: [Cal_Boats] Handling spinnaker rolling
I'm not sure what you mean by roll, but if you are not in severe winds
or seas, it should be possible to get the spinnaker in balance with the
boat.
For starters as the wind is lighter we tend to carry the pole higher,
making the "Beetle back" shape as High up the spinnaker as possible.
Sometimes sailors call this matching the clews, the spinnaker should be
flying squarely, ie matching clew heights with the center seam hanging
dickular, vertical.
In moderate conditions one trim note is to make sure the leading edge of
the spinnaker comes straight up off the tip of the spinnaker pole. If it
is beyond the pole, you are in round down position, and if it is inside
the pole you are in round up position. As wind increases, always avoid
the round down position.
Next try starting with the pole 90 degrees to the apparent wind and
keeping the boom in a straight line with the boom. You should notice
that if you over tighten the sheet, the boat tends to round up, and if
you loosen the sheet, the boat tends to wobble, and round down. This is
why when you start to round up, loosen the sheet, and if you start to
round down, tighten the sheet.
As the winds or seas start to perk up, we typically make sure to have
the outgrabber http://tinyurl. com/42kggasecure d
<http://tinyurl. com/42kggasecure d> to the sheet, and twingers to keep
the kite from oscillating. In more difficult conditions we keep the kite
slightly over sheeted, to make sure we round up. The trimmer mans the
sheet so he can feed out a foot or so of sheet, if the helmsman starts
to get into trouble. If you round down, the least of your worries is
breaking the spinnaker pole, often the mast goes too. If you have the
main prevented, the you will experience the famous "death roll" where
the prevented main drives the boat over farther maybe until 180
inverted. a death roll picture.
DEATH ROLL (My crew member Andy, under the GG Bridge)
OUTGRABBER ON STAN AND SALLY HONEY'S CAL 40 ILLUSION
With the sheet just a tad oversheeted, it is up to the driver to weave
the course using the waves to try and get surfs and vary the wind angle
just enough to sail either side of the optimum wind angle to maintain
control and keep the boat on it's feet.
Some boats tend to go bow down with the spinnaker up, if you notice the
bow dipping a fair amount, typically just before a surf, or in a puff,
you might consider moving the crew as far aft as possible. So like
skipping a stone, creating a better angle with the boat bow for the boat
to lift and accelerate, verses digging a hole, stalling the rudder, and
then crashing.
Cheers,
dEmO
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_Boats@yahoogrou ps.com
<mailto:Cal_Boats@yahoogrou ps.com> ] On Behalf Of Downing, Thomas
Sent: Monday, June 02, 2008 5:20 AM
Subject: Handling spinnaker rolling
I was out yesterday (on an Atlantic 30, not a Cal 2-27), we were running
about 15 degrees off a dead run with the chute up - and ran into a lot
of that nasty induced rolling. At one point we seemed headed for
disaster (the boom dug in last roll, and we were just coming up from a
roll that nearly had the spin pole in) when we were saved when the spin
halyard somehow popped out of the cleat.
We hauled it back up without it getting in the water, and it certainly
did stop the rolling; but there's got to be a better way! We had been
playing with tweekers and pole, but nothing seemed to help.
So, any suggestions as to how to control roll without giving up boat
speed?
thanks
td
DISCLAIMER:
Important Notice ************ ********* ********* ********* ********* *
Stay informed, get connected and more
pw… [at] aol.com2008-06-03 15:49 UTC
We had an overnight race blowing 20-25 and we had to sail as close to ?dead down as we could for 2 hours at night to avoid a shoal (we didn't have boats around us but didn't want to gybe at night in those conditions because we'd have to gybe back too) so we just choked the chute down, put everyone but the trimmer on the stern and dealt with it.? We'd head up a few degrees if it got crazy but we managed to miss the shoal and make it thru the night w/o incident.
Paul
Sent: Tue, 3 Jun 2008 11:33 am
Subject: Re: [Cal_Boats] Handling spinnaker rolling (Fin, Paul)
I agree, heading up 10 degrees will have the same effect, with one small problem.? I'm assuming you're in a tight race and have achieved a tactical position that suits you at the time.? Heading up on the rolls has the possible affect of losing your position on your competition.? Trimming the sheet at the same time as the mast is vertical will kill the roll without changing your position.? It is harder work and usually requires at least two people, one to grind and one to trim with 3 to 4 wraps on the winch, but trimming saves your advantage on the other boats.
Our experience with rolling come from sailing dead down in high winds.? What we do is choke the chute down and get it as close to the deck as possible to reduce the leverage the wind has aloft.? We tweaked it down hard, didn't play it, and put everyone on the stern with the exception of the guy holding onto the chute so he could blow it if necessary.? The rolling will also stop if you head up a few degrees.
Paul
This is similar to the same effect that can crash motorcycles at speed where an oscillation begins and if it is not countered, it can build to a destructive level.? I would try to control it with sheet tensioning and easing.? If on port tack and the boat begins to roll to port, try sharply trimming the starboard sheet and flattening the spinnaker.? This should overpower the chute and pull the boat back flat.? As the boat tries to roll back to starboard, time the easing of the sheet with the roll so that the spinnaker stays in one position with the wind as the boat tries to roll.? This should lower the leeward pull of the chute and ease the force on the roll.? Since you said that the boats sail more like dinghies than keel boats this is the technique that I used in Flying Scots in high wind oscillations and I was also successful keeping an Olson 34 flat in a 4' D-chop and 28 knots of wind on Galveston Bay with this technique.?
td
boat.
dickular, vertical.
then crashing.
Cheers,
dEmO
speed?
thanks
td
DISCLAIMER:
RE: [Cal_Boats] Handling spinnaker rolling (Fin, Paul)
ti… [at] ch2m.com2008-06-03 17:06 UTC
On Freewind, which is an old IOR type 1/2 tonner, we set up the kite so
that it is in slight round-up condition. I do not want a trimmer to
adjust the sails, as I can drive better, without the change, and
"slingshot" more on waves. The trimmer is there in case of emergency, to
give me a second chance. Our call is "gimmee room" or "ROOM!" Usually
this is a payout of @ 12" and then a quick crank back. We have a
sheeting system where anyone in the cockpit can kick a release, and the
sheet automatically pays out 12-18", then the line must be reeled back
in to avoid flogging or round down.
When driving this squirrelly boat downwind, I must always keep the
following in mind:
1. never let the boat go where it wants to, the boat will always want to
round up or down. BE IN CHARGE of the boat.
2. anticipate the boat motion, after sailing a while, you know when the
boat will head up or down, or oscillate up or down. Make the correction
before the motion starts.
3. use a mental picture that helps, I use two scenarios, my hand always
travels the the high side to push it down, so if the starboard deck
starts to rise, I move the tiller to that side, to push it back down.
the second is to imagine the mast as a pencil balanced on end, at the
end of your finger. Try this, it matches the boat action, if it moves to
the right, you must move your finger to the right, to maintain balance,
if you anticipate, before the pencil moves, you can maintain balance.
The more you correct late and the greater your correction, the more the
pencil will swing, until you are out of control. Keep the boat under the
mast.
4. Crew balance greatly affects the way the boat handles, even on our
7,000 pound boat, I can change the attitude of the boat just by moving
the helmsman to the other side of the cockpit. Experiment with crew
locations that set the boat up correctly.
5. once you master some of these techniques, you can set the boat up, by
purposely starting an oscillation, to power up the boat, then correct it
immediately to get the boat flat to slingshot a surf. On Freewind, in
moderate air, I can get her to surf over her bow wave using this
technique, and pick up a quick 2-3 knot increase. We call it swing or
bow surfing.
Behalf Of Donald Dutton
Sent: Tuesday, June 03, 2008 9:34 AM
boats.
Paul
td
From: Cal_Boats@yahoogrou ps.com <mailto:Cal_Boats%40yahoogroups.com>
<mailto:timmothy.lessley%40ch2m.com>
To: Cal_Boats@yahoogrou ps.com <mailto:Cal_Boats%40yahoogroups.com>
boat.
dickular, vertical.
<http://tinyurl.com/42kggasecured>
<http://tinyurl. com/42kggasecure d <http://tinyurl.com/42kggasecured> >
then crashing.
Cheers,
dEmO
[mailto:Cal_Boats@yahoogrou ps.com <mailto:Cal_Boats%40yahoogroups.com>
<mailto:Cal_Boats@yahoogrou ps.com <mailto:Cal_Boats%40yahoogroups.com>
speed?
thanks
td
DISCLAIMER:
ti… [at] ch2m.com2008-06-03 17:30 UTC
.... continued.
Once all the prior advise is absorbed and it works for you, consider
this final note. As the boat slows after a surf, do not just wait for
the next event by keeping the helm straight. Initiate the next round by
immediately powering the boat back up, swing the bow back to weather to
load her up, and then back to the next bow or sea wave to start the next
surf cycle. If you let the boat slow down, and then power up, while the
rudder is stalled or inefficient, the oscillation cycle will tend to be
more intense. Pre action, builds the power while the rudder is attached,
and the boat is elevated out of the water in surfing condition. We have
chained together dozens of surfs using this technique, out performing
our short boat problem of flotation verses waterline.
Behalf Of ti… [at] ch2m.com
Sent: Tuesday, June 03, 2008 11:07 AM
Subject: RE: [Cal_Boats] Handling spinnaker rolling (Fin, Paul)
following in mind:
mast.
bow surfing.
boats.
Paul
td
boat.
dickular, vertical.
then crashing.
Cheers,
dEmO
speed?
thanks
td
DISCLAIMER:
RE: [Cal_Boats] Handling spinnaker rolling. Wow!
Bob Connell2008-06-03 21:02 UTC
The knowledge that you people impart is absolutely incredible. It is actually exciting to read some of these emails (I know - get a life Connell). I only wish I had started sailing years ago and had been on this list since it's inception so that I could better grasp the lessons you are all providing. The technical know-how I would have picked up and the chance to know and interact with people like Roger would have made me a better sailor. I am priveledged to have found this list and will look forward to sharing time with you all over the coming years....
To Roger, though I only recently became aware of you, I am in humble respect of the reverence with which members of this list have honored your passing. You were a tribute to your community and have left a pay-it-forward legacy among these your friends. Fair winds.
Bob Connell
ti… [at] ch2m.com wrote:
On Freewind, which is an old IOR type 1/2 tonner, we set up the kite so that it is in slight round-up condition. I do not want a trimmer to adjust the sails, as I can drive better, without the change, and "slingshot" more on waves. The trimmer is there in case of emergency, to give me a second chance. Our call is "gimmee room" or "ROOM!" Usually this is a payout of @ 12" and then a quick crank back. We have a sheeting system where anyone in the cockpit can kick a release, and the sheet automatically pays out 12-18", then the line must be reeled back in to avoid flogging or round down.
When driving this squirrelly boat downwind, I must always keep the following in mind:
1. never let the boat go where it wants to, the boat will always want to round up or down. BE IN CHARGE of the boat.
2. anticipate the boat motion, after sailing a while, you know when the boat will head up or down, or oscillate up or down. Make the correction before the motion starts.
3. use a mental picture that helps, I use two scenarios, my hand always travels the the high side to push it down, so if the starboard deck starts to rise, I move the tiller to that side, to push it back down. the second is to imagine the mast as a pencil balanced on end, at the end of your finger. Try this, it matches the boat action, if it moves to the right, you must move your finger to the right, to maintain balance, if you anticipate, before the pencil moves, you can maintain balance. The more you correct late and the greater your correction, the more the pencil will swing, until you are out of control. Keep the boat under the mast.
4. Crew balance greatly affects the way the boat handles, even on our 7,000 pound boat, I can change the attitude of the boat just by moving the helmsman to the other side of the cockpit. Experiment with crew locations that set the boat up correctly.
5. once you master some of these techniques, you can set the boat up, by purposely starting an oscillation, to power up the boat, then correct it immediately to get the boat flat to slingshot a surf. On Freewind, in moderate air, I can get her to surf over her bow wave using this technique, and pick up a quick 2-3 knot increase. We call it swing or bow surfing.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Donald Dutton
----- Original Message ----
Paul
td
boat.
dickular, vertical.
then crashing.
Cheers,
dEmO
speed?
thanks
td
DISCLAIMER:
Downing, Thomas2008-06-04 12:22 UTC
Wow, I'll print this one out and run it by the skipper.
Thanks
td
From: Ca… [at] yahoogroups.com on behalf of ti… [at] ch2m.com
Sent: Tue 6/3/2008 1:06 PM
following in mind:
mast.
bow surfing.
boats.
Paul
td
boat.
dickular, vertical.
then crashing.
Cheers,
dEmO
speed?
thanks
td
DISCLAIMER:
DISCLAIMER:
