9 messages2008-06-09 13:56 UTCthrough 2008-06-09 18:59 UTC
battery problem
Michael Kennedy2008-06-09 13:56 UTC
Mike Jr and I spent a nice weekend at Catalina thinking about Roger,
who should have been with us. We had a battery problem that I would
like to ask the group for ideas on. I put one of those "smart
chargers" in the boat when I rewired it. We have three batteries, two
in parallel for "house" and one for starting. When we started the
engine Friday, I was a bit concerned that the #1 battery seemed low.
When we were at Catalina, I discovered that all three batteries were
dry. I've never seen this before. I hadn't checked the water in a long
time because I've not seen a modern battery go dry.
I'm wondering if that smart charger has been cooking them. I'm going
to have to replace them all. I'm also thinking I had better replace
the charger, too. The batteries were new from the PO and looked in
good shape. This is the third season and we had no trouble at all last
summer.
Suggestions ?
Mike Kennedy
Conquest Cal 40 # 96
Re: [Cal_Boats] battery problem
Robert Andrew2008-06-09 14:10 UTC
Very unusual for the batteries to go dry I agree. I've had several
varieties of smart chargers over the years and never had a problem with
them.
There are probably others more knowledgeable on this list, but it sounds
like a "not smart" charger. These things are supposed to monitor battery
voltage and temperature and adjust the charge rate accordingly, but if that
circuitry is faulty then the whole concept goes out the window. If you have
some kind of amp hour meter you could monitor the charge rate and see if it
drops once the batteries are about 80-90% charged. Older chargers didn't
monitor anything and frequently did cook batteries. On some of these
chargers there are settings for different types of batteries, but even if
that were wrong, cooking the batteries dry is pretty extreme. What variety
of charger was this?
Bob Andrew CAL 39 Nereid
> summer.
> Suggestions ?
> Mike Kennedy
RE: [Cal_Boats] battery problem
ti… [at] ch2m.com2008-06-09 14:24 UTC
I have had this issue on Freewind. Smart Chargers, depending on the
brand will boil out batteries.
The best one I've tried to date, is the 70amp Xantrex Inverter with a
Link 2000 panel, which is superior. This is on the Cal 40.
I do not have room for this on the Cal 9.2 so have selected:
PROTECH 4 1220 20 AMP CHARGER
I have also had extremely poor luck with Rolls batteries, which are
supposed to be the best. They had a quality issue, with the shop foreman
or welder craftsman being a crack head. there was a run of batteries,
that I had three sets of, where a bad weld caused the batteries to fail
with months of installation. The poor charger tried to keep up with the
line loss, and eventually fried all battery sets. To Rolls credit, the
batteries have been replaced free of charge, I am on my 4th set.
The Guest Smart Chargers and maybe all small smart chargers; will
destroy batteries if they are undersized: To Guests credit, they sent
me "free of charge" the larger unit, which I sold on EBAY to get the
PROTECH 4.
From: Lessley, Timm/IDC/PDX [mailto:Ti… [at] idc-ch2m.com
<mailto:Ti… [at] idc-ch2m.com> ]
Sent: Tuesday, January 25, 2005 3:35 PM
To: Te… [at] guestco.com <mailto:Te… [at] guestco.com>
Subject: Contact Us Form Submission
The unit I have is the Guest 2608, the single battery bank
6amp waterproof charger with hardwire connections.
The boat had no DC draw (except the milliamps of the battery
Meter) during the "boil-out". The boat was unused, at the dock,
of my house. I was in Taiwan on Business and am the only user.
The Battery Charger was installed New in April 2004.
The charger failed in October or November of 2004.
I discovered the event, upon my return from Taiwan
late November.
Timm
Hi Timm,
I have been going over your situation with the charger with my
supervisor.
Now that I have all of your information regarding your application and
the
charger, I have the following conclusion:
The 2608 charger is rated for a maximum battery size of 150 amp hours
for
charging and 300 amp hours for maintenance only. Your combined battery
bank
of 395 amp hours far exceeds this maximum rating.
The self discharge rate of the four batteries alone would probably
result in
enough current draw to keep the charger in absorption, which is a higher
voltage output. If left in this state for prolonged periods of time
without
monitoring or maintaining the batteries, this combination could result
in
overcharging.
You stated "Looking at the West Marine Website, under Reviews, I have
now
discovered
this Is a "common" problem with these units." The chargers mentioned on
the
West Advisor are 2611 chargers, not the 2608 which you currently have.
Guest
sells approximately 15,000 2611 chargers a year. Reports of 4 failures
to
the Advisor over a 2 year timeframe is not surprising or alarming.
I would recommend that you upgrade your charger from a model 2608 to a
model 2633 The 2633 is a 2 bank charger which would provide 20 amps to
your
house bank and 10 amps to your start bank. If you would like to make the
upgrade I will credit you for the purchase of the 2608. The cost to
upgrade
to the 2633 would then be $224.00 and there would be no charge for
shipping.
If you wish to purchase the charger or if you have any questions, you
may
call me at Guest toll free at 1-888-483-7865 ext 135 Monday through
Friday
between 8 AM and 4:30 PM EST.
Regards,
Sue DeLelys
Technical Support Manager
Behalf Of Michael Kennedy
Sent: Monday, June 09, 2008 7:57 AM
Subject: [Cal_Boats] battery problem
summer.
Suggestions ?
Mike Kennedy
pw… [at] aol.com2008-06-09 14:37 UTC
The Cal 39 I just bought has 2- 6 volt batteries I assume?for the house and 2 -12 volt (I assume again) starting batteries.? I have no idea how long they've been on the boat but is there a way to tell if you have the bad batch?before frying them?
I am just getting into "big boat" systems and am frustratingly ignorant of charging systems, batteries etc.? Are you saying your inverter and Link 2000 panel are used to charge your batteries or am I missing something?
Thanks -
Paul
Sent: Mon, 9 Jun 2008 10:24 am
Subject: RE: [Cal_Boats] battery problem
I have had this issue on Freewind. Smart Chargers, depending on the brand will boil out batteries.
The best one I've tried to date, is the 70amp Xantrex Inverter with a?Link 2000 panel,?which is superior. This is on the Cal 40.
I have also had extremely poor luck with Rolls batteries, which are supposed to be the best. They had a quality issue, with the shop foreman or welder craftsman being a crack head. there was a run of batteries, that I had?three sets of, where a bad weld caused the batteries to fail with months of installation. The poor charger tried to keep up with the line loss, and eventually fried all battery sets. To Rolls credit, the batteries have been replaced free of charge, I am on my 4th set.
The Guest Smart Chargers and maybe all small smart chargers; will destroy batteries if they are undersized:? To Guests credit, they sent me "free of charge" the larger unit, which I sold on EBAY to get the PROTECH 4.
From: Lessley, Timm/IDC/PDX [mailto:Ti… [at] idc-ch2m.com]
late November.
Timm
Hi Timm,
I have been going over your situation with the charger with my supervisor.
Now that I have all of your information regarding your application and the
The 2608 charger is rated for a maximum battery size of 150 amp hours for
charging and 300 amp hours for maintenance only. Your combined battery bank
The self discharge rate of the four batteries alone would probably result in
voltage output. If left in this state for prolonged periods of time without
monitoring or maintaining the batteries, this combination could result in
overcharging.
You stated "Looking at the West Marine Website, under Reviews, I have now
discovered
this Is a "common" problem with these units." The chargers mentioned on the
West Advisor are 2611 chargers, not the 2608 which you currently have. Guest
sells approximately 15,000 2611 chargers a year. Reports of 4 failures to
model 2633 The 2633 is a 2 bank charger which would provide 20 amps to your
upgrade I will credit you for the purchase of the 2608. The cost to upgrade
to the 2633 would then be $224.00 and there would be no charge for shipping.
If you wish to purchase the charger or if you have any questions, you may
call me at Guest toll free at 1-888-483-7865 ext 135 Monday through Friday
Regards,
Sue DeLelys
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Michael Kennedy
summer.
Suggestions ?
Mike Kennedy
ti… [at] ch2m.com2008-06-09 15:00 UTC
If you have Rolls batteries, then call their office or a local
distributor to see if you have the bad series.. if everything fails,
then call my electrician at southwest Marine, in Oregon.
The Xantrex 12 or 1500 amp Inverter has a built in 70 amp charger, that
keeps batteries up to snuff, while plugged into shore power. Off the
engine we have a Balmar 110 amphour tied into a Max 12 regulator into a
westmarine combiner.
Timm
Behalf Of pw… [at] aol.com
Sent: Monday, June 09, 2008 8:37 AM
Subject: Re: [Cal_Boats] battery problem
The Cal 39 I just bought has 2- 6 volt batteries I assume for the house
and 2 -12 volt (I assume again) starting batteries. I have no idea how
bad batch before frying them?
of charging systems, batteries etc. Are you saying your inverter and
something?
Thanks -
Paul
PROTECH 4.
late November.
Timm
Hi Timm,
supervisor.
the
for
bank
result in
without
in
overcharging.
now
discovered
the
Guest
to
your
upgrade
shipping.
may
Friday
Regards,
Sue DeLelys
From: Ca… [at] yahoogroups.com [mailto:Cal_ <mailto:Cal_?>
Bo… [at] yahoogroups.com] On Behalf Of Michael Kennedy
summer.
Suggestions ?
Mike Kennedy
Stay informed, get connected and more with AOL on your phone
<http://mobile.aol.com/productOverview.jsp?productOverview=aol-mobile-ov
erview&?&ncid=aolmbd00030000000139> .
Michael Kennedy2008-06-09 15:08 UTC
> a Link 2000 panel, which is superior. This is on the Cal 40.
I'm using the smart charger only on shore power. I think Practical
Sailor had an article on the smart chargers recently and I'm going to
look. This one is Guest from West Marine and I'm going to ask them
although most of the people there don't know much.
Is this run by shore power ?
> batteries, that I had three sets of, where a bad weld caused the
> get the PROTECH 4.
Interesting. That has to be the culprit.
We had another adventure coming home. We had turned into the last
channel at Cabrillo and were slowing down for the slip. Mike was
driving and I was on the bow ready to jump on the dock. He suddenly
called to me that he could not get it into reverse. I ran back and
couldn't either. The linkage was gone, disconnected or broken cable.
We were headed down the channel at about 4 knots with an idiot woman
screaming "Slow Down !" The sea wall was about 8 boat lengths in front
of us.
This is the point that the kid says "What happened next ?" and the
grandpa says "I was killed, you idiot !"
Anyway we survived. Mike skimmed the sterns along our starboard side
and did a tight turn in a channel that is only about five feet wider
than the boat is long. We broke off our flag staff from the stern
turning. We did get slowed down because we were into the wind which
was pretty strong just then. It was one reason we were going so fast
the other way. One scratch on the hull seems to be the damage. We had
no warning of the shift problem until we were 200 feet from the slip
and going too fast.
It will be a busy weekend coming up. The shift linkage is inside the
engine box and not very accessible in a hurry. The throttle cable
broke once and I wonder if this is what happened. Only shifting cable
this time.
Mike Kennedy
> -----Original Message-----
> late November.
> Timm
> Hi Timm,
> supervisor.
> and the
> hours for
> battery bank
> result in
> higher
> without
> result in
> overcharging.
> have now
> discovered
> on the
> have. Guest
> failures to
> to your
> the
> upgrade
> shipping.
> you may
> Friday
> Regards,
> Sue DeLelys
> summer.
> Suggestions ?
> Mike Kennedy
Shift cables was battery problem
pw… [at] aol.com2008-06-09 15:22 UTC
I just had the engine surveyed on my Cal 39 and the kill cable had frozen.? The surveyor taught me a trick worth repeating.? He told me that when I replace the cable to take it apart before I install it and coat it with "Never Seize".? He said that will make it last 10 years and run freely as opposed to the normal 2-3 years.
Paul
Sent: Mon, 9 Jun 2008 11:08 am
> get the PROTECH 4.
of us.
and going too fast.
this time.
Mike Kennedy
> late November.
> Timm
> Hi Timm,
> supervisor.
> and the
> hours for
> battery bank
> result in
> higher
> without
> result in
> overcharging.
> have now
> discovered
> on the
> have. Guest
> failures to
> to your
> the
> upgrade
> shipping.
> you may
> Friday
> Regards,
> Sue DeLelys
> summer.
> Suggestions ?
> Mike Kennedy
Yahoo! Groups Links
Marsh Wise2008-06-09 15:22 UTC
Don't ya just love it? :-0
Marsh Wise
Webmaster:
-reenactor.Net: <http://www.reenactor.net/>
Read my Blog (bore yourself): <http://www.reenactor.net/rnet_admin/marsh/marshblog.html>
-Foresthill.US: <http://www.foresthill.us/>
-1./Infanterie-Regiment 23 <http://www.ir23.org>
-Legio IX Hispana Penna: http://www.reenactor.net/units/legio_ix_penna/
- 17. Luftwaffe Feld-Division <http://www.reenactor.net/units/17lwfd/>
Assistant Webmaster:
-VAQ-33 Squadron site: <http://www.reenactor.net/vaq-33/>
*Last: Hey Dammit! Have you visited the reenactor.Net FORvMS? If not, WHY NOT?
Gett your butt over to: <http://www.reenactor.net/forums/index.php> right now!
Chris Campbell2008-06-09 18:59 UTC
> He suddenly
> We had
> and going too fast.
You're lucky. The weakest link between my transmission and my brain
falls somewhere between the brain and my hand. Last summer I had
slightly misjudged my speed in reverse, so I shifted from neutral to
forward to slow me down. That didn't have much effect so I goosed it.
Unfortunately, it was in reverse, which is why it had no useful effect.
Now I was proceeding with considerable velocity toward the boats behind
me. The picture was not pretty. And the boats behind are all power
boats, naturally, and those that weren't targets of my stern are all
snickering. My only defense was that this was outboard power with one
of those combined throttle/shift arms, and remembering which way to
twist it while looking ahead can be a challenge. Or so I will contend
until I think of another excuse. It's one reason to prefer sailing to
motoring.
