Re: Port Lights, aka windows
6 messages2008-06-16 14:26 UTCthrough 2008-06-17 16:06 UTC
Dan B.2008-06-16 14:26 UTC
Thanks Everyone:   I'm planning the four opening port lights on the forward part of the cabin top. I am leaning toward the stainless product at New Found Metals. They have one that looks like a perfect fit for my 34. I like the idea of not cutting more out of the cabin.   I called the Mark Plastics  in Corona, CA Tel: (909) 735-7705  and it's disconnected. They were my first call.   The info on the big windowss is good for the files. I'm sure that someday those too will demand attention. Fair winds & calm seas,   Dan   S/V Sound Discovery, a classic Cal-34 sailboat   "Twenty Years from now, you will be more disappointed by the things you didn't do than by the things you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover." ........Mark Twain
Re: [Cal_Boats] Re: Port Lights, aka windows
Carl2008-06-16 15:34 UTC
Dan, One more thing. The NFM ports will need the wood trim unless they have changed the design. I made my own, they didn't supply them back then. Also, the spigot is bigger, you will need to notch the cabin side a little. I used a sanding drum on a drill, get one the right diameter and it is a 10 second job. As for terminology, I think port "lights" don't open?? That may be where the confusion was :<) Carl Cal 34III On 6/16/08, Dan B. <sa… [at] yahoo.com> wrote: > > Thanks Everyone: > > > > I'm planning the four *opening port lights* on the forward part of the > cabin top. I am leaning toward the stainless product at New Found Metals. > They have one that looks like a perfect fit for my 34. I like the idea of > not cutting more out of the cabin. > > > > I called the Mark Plastics in Corona, CA Tel: (909) 735-7705 and it's > disconnected. They were my first call. > > > > The info on the big windowss is good for the files. I'm sure that someday > those too will demand attention. > > Fair winds & calm seas, > > Dan > > S/V Sound Discovery, a classic Cal-34 sailboat > > *"Twenty Years from now, you will be more disappointed by the things you > didn't do than by the things you did do. So throw off the bowlines. Sail > away from the safe harbor. Catch the trade winds in your sails. Explore. > Dream. Discover." **........Mark Twain * > > > -- Carl
Sail Man2008-06-16 17:46 UTC
new area code (951)&nbsp;.&nbsp; i just called information and was connected, &nbsp; Larry --- On Mon, 6/16/08, Dan B. &lt;sa… [at] yahoo.com&gt; wrote: From: Dan B. &lt;sa… [at] yahoo.com&gt; Subject: [Cal_Boats] Re: Port Lights, aka windows To: Ca… [at] yahoogroups.com Date: Monday, June 16, 2008, 7:26 AM Thanks Everyone: &nbsp; I'm planning the four opening port lights on the forward part of the cabin top. I am leaning toward the stainless product at New Found Metals. They have one that looks like a perfect fit for my 34. I like the idea of not cutting more out of the cabin. &nbsp; I called the Mark Plastics&nbsp; in Corona, CA Tel: (909) 735-7705&nbsp; and it's disconnected. They were my first call. &nbsp; The info on the big windowss is good for the files. I'm sure that someday those too will demand attention. Fair winds &amp; calm seas, &nbsp; Dan &nbsp; S/V Sound Discovery, a classic Cal-34 sailboat &nbsp; "Twenty Years from now, you will be more disappointed by the things you didn't do than by the things you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."&nbsp;........Mark Twain
Michael Kennedy2008-06-17 02:17 UTC
On Jun 16, 2008, at 7:26 AM, Dan B. wrote: > > Thanks Everyone: > > > I'm planning the four opening port lights on the forward part of the > cabin top. I am leaning toward the stainless product at New Found > Metals. They have one that looks like a perfect fit for my 34. I > like the idea of not cutting more out of the cabin. > > > I called the Mark Plastics in Corona, CA Tel: (909) 735-7705 and > it's disconnected. They were my first call. > That phone number is an old area code and persists in some of the listings. If I was in business, I would check my listings once in a while but I recall I had the same problem three years ago. Mark Plastics 369 E Harrison St # G Corona, CA 92879 (951) 735-7705 Mike Kennedy Conquest Cal 40 # 96 PS I solved one of my troubles from the trip back from Catalina. We had found ourselves suddenly unable to shift gears. The cable has a bracket that mounts it to the engine block before it turns down to the shifting lever. The bracket is held b two machine screws. Both had fallen out and both were pretty short with only three turns of thread holding them in. One had fallen out some time ago as it was lying below the V drive and had some corrosion on the threads. I replaced them but get longer screws and add lock-tite. >
Pat Semenuk2008-06-17 15:34 UTC
C. R. Laurence Co., Los Angeles, CA (800) 262-3299 Marine Windshield Company, Costa Mesa, CA (949) 645-1011 Mark Plastics, Corona, CA (909) 735-7705 Ocean Corner, Zeewolde, Flevoland, The Netherlands +31 628633859 Plastic & Metal Center, Laguna Hills, CA (714) 770-8230 Plasto Tech Int'L, Inc., Irvine, CA (949) 458-1880 The Boat Place, Ensenada, Baja California 646-174-6800 Yacht Services, San Diego, CA (619) 701-5738 "Dan B." <sa… [at] yahoo.com> wrote: Thanks Everyone: I'm planning the four opening port lights on the forward part of the cabin top. I am leaning toward the stainless product at New Found Metals. They have one that looks like a perfect fit for my 34. I like the idea of not cutting more out of the cabin. I called the Mark Plastics in Corona, CA Tel: (909) 735-7705 and it's disconnected. They were my first call. The info on the big windowss is good for the files. I'm sure that someday those too will demand attention. Fair winds & calm seas, Dan S/V Sound Discovery, a classic Cal-34 sailboat "Twenty Years from now, you will be more disappointed by the things you didn't do than by the things you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover." ........Mark Twain
RE: [Cal_Boats] Re: Port Lights, aka windows
Husar, Charlie [USA]2008-06-17 16:06 UTC
Hi, All. Remember that the area code for Mark Plastics is 951, NOT 909. Cheers Charlie From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Pat Semenuk Sent: Tuesday, June 17, 2008 11:35 AM To: Ca… [at] yahoogroups.com Subject: Re: [Cal_Boats] Re: Port Lights, aka windows * C. R. Laurence Co. <http://www.socalsail.com/bg/co/c-r-laurence-co/> , Los Angeles, CA (800) 262-3299 * Marine Windshield Company <http://www.socalsail.com/bg/co/marine-windshield-company/> , Costa Mesa, CA (949) 645-1011 * Mark Plastics <http://www.socalsail.com/bg/co/mark-plastics/> , Corona, CA (909) 735-7705 * Ocean Corner <http://www.socalsail.com/bg/co/ocean-corner/> , Zeewolde, Flevoland, The Netherlands +31 628633859 * Plastic & Metal Center <http://www.socalsail.com/bg/co/plastic-metal-center/> , Laguna Hills, CA (714) 770-8230 * Plasto Tech Int'L, Inc. <http://www.socalsail.com/bg/co/plasto-tech-int-l-inc/> , Irvine, CA (949) 458-1880 * The Boat Place <http://www.socalsail.com/bg/co/the-boat-place/> , Ensenada, Baja California 646-174-6800 * Yacht Services <http://www.socalsail.com/bg/co/yacht-services/> , San Diego, CA (619) 701-5738 "Dan B." <sa… [at] yahoo.com> wrote: Thanks Everyone: I'm planning the four opening port lights on the forward part of the cabin top. I am leaning toward the stainless product at New Found Metals. They have one that looks like a perfect fit for my 34. I like the idea of not cutting more out of the cabin. I called the Mark Plastics in Corona, CA Tel: (909) 735-7705 and it's disconnected. They were my first call. The info on the big windowss is good for the files. I'm sure that someday those too will demand attention. Fair winds & calm seas, Dan S/V Sound Discovery, a classic Cal-34 sailboat "Twenty Years from now, you will be more disappointed by the things you didn't do than by the things you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover." ........Mark Twain
