5 messages2008-06-30 16:47 through 2008-07-01 16:40
bulkhead Progress questions
James Bibb2008-06-30 16:47
For David and others...I'm working my way through the demolition and following the photos I
see through David's and other's websites....questions before I plunge the rotozip in specific
areas....first the forward bulkhead and bathroom floor pan removal...you had to cut the
forward built-in around the water tank. Is this to access the screws holding the pan in
place? Was it necessary to remove the water tank to do this job?
Also, the ice-box. I've cut the cabin counter just to the right of the ice-box...as well as the
cabinet facing to access the ice-box. I'm pulling out the insulation and trying to remove the
ice-box itself in good condition to re-use. The counter seems to be tabbed into the hull on
the back-side where the sliding storage cabinets are located. I'm also in the area where the
lower chainplates are attached to the hull with a small bulhead tab. What direction could you
give to cut to the minimum here?
Wish I could post pictures of this mess, having fun, however!
Re: [Cal_Boats] bulkhead Progress
David Wilkie Owen2008-07-01 05:04 UTC
Oh boy.
Thought I¹d throw out some things to think about.....
Pan/bulkhead:
Be sure and make templates of the bulkheads before/as you remove them if
that is in your plans.
I did not replace the forward bulkhead, but I did scarf some new plywood
across the bottom where there was minor rot. The forward bulkhead has a
cleat across the bottom, which the forward edge of the pan is bolted to.
Since the stringers that support the water tank dead end into the forward
side of the forward bulkhead, you will end up removing the water tank if
the bulkhead is coming out. If the bulkhead is not coming out, you probably
could slide a sawzall blade through and cut the bolts that support the
forward pan lip, but you would need to engineer an alternative way to secure
the front end of the pan to the bulkhead when you put it back in. I can¹t
help but surmise that the easiest route in all cases is to just pull that
water tank out.
Ice box:
The back (or outer) flange of the ice box is bolted into the counter first
and then was tabbed into the hull as a unit. Unfortunately, the bolt heads
are hidden under the tabbing. Fortunately, a 4² angle grinder with a 36
grit disc will quickly skin enough tabbing to find the buried bolt-heads and
then just dig them out of the tabbing. You can add some additional tabbing
later if you feel any concern about what you cut away to expose the bolt
heads.
On re-assembly I used stainless construction screws (with properly sized
pilot holes) to suck the ice box back up to the counter (just to clamp while
the 5200 sets up.) I didn¹t find it necessary to cut too close to the
mini-bulkhead that the lower chainplate is mounted on. I can¹t recall
exactly, but probably an inch and a half away.... As long as you put it all
back with some doubled or sistered backing, I don¹t think it¹s a concern.
Keep having fun...
David Wilkie Owen
Reply-To: <Ca… [at] yahoogroups.com>
Date: Mon, 30 Jun 2008 16:47:33 -0000
Subject: [Cal_Boats] bulkhead Progress questions
rotozip in specific
to cut the
holding the pan in
into the hull on
the area where the
direction could you
Re: bulkhead Progress
James Bibb2008-07-01 16:32
Oh boy is right, thanks David! I wouldn't be doing this without those pioneers ahead of
me!
James
--- In Ca… [at] yahoogroups.com, David Wilkie Owen <wilkie@...> wrote:
> Oh boy.
> Pan/bulkhead:
> water tank out.
> Ice box:
> heads.
> Keep having fun...
> David Wilkie Owen
> From: James Bibb <jamesbibb84@...>
> rotozip in specific
> to cut the
> holding the pan in
> into the hull on
> the area where the
> direction could you
me!
James
> Oh boy.
> Pan/bulkhead:
> water tank out.
> Ice box:
> heads.
> Keep having fun...
> David Wilkie Owen
> rotozip in specific
> to cut the
> holding the pan in
> into the hull on
> the area where the
> direction could you
Re: bulkhead Progress questions
James Bibb2008-07-01 16:40
Oh, and thanks David regarding the front bulkhead....I was trying to dissect your photos
and thought that you cut the base of the forward bulkhead to access bolts...if I didn't stop
to itch some of the fiberglass from my arm and take a break, I'd be whaling away with the
sawsall....damn that's a destructive and great tool.
photos I
specific
the
the
hull on
the
could you
