3 messages2008-07-18 15:01 UTCthrough 2008-07-18 15:22 UTC
Re: [Cal_Boats] Need rubrail (Jeff)
Jeffrey owen2008-07-18 15:01 UTC
Hey, Charlie, thanks for your help. Indeed, it is a rubber rubrail that fits over the deck/hull joint. I removed it, and I want to gring the excess glass, which currentlyloops upward and downward, and holds water. I plan to remove the spread, to make it flat un the upper and lower surfaces, and install a narrower rubrail. I have seen rubrails that are narrow and have a trim on the outer face which looks pretty good.
Anyway, any info would be great!
Jeff Owen 72 CAL 33
Aguadilla, Puerto Rico
Sent: Friday, July 18, 2008 9:32:19 AM
Subject: RE: [Cal_Boats] Need rubrail (Jeff)
Jeff, is it a rubber/vinyl rail that goes over the deck-hull joint? I
know 3 or 4 sources depending on where you are.
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_Boats@yahoogrou ps.com] On
Behalf Of Jeffrey owen
Sent: Friday, July 18, 2008 9:28 AM
Subject: [Cal_Boats] Need rubrail
Good morning:
I need to replace the rub rail on a 72 CAL 33. Any suggestions on were
to look? Thanks!
Best regards
Jeff Owen
Yahoo! Groups Links
Jeffrey owen2008-07-18 15:19 UTC
Thanks, Al - I will be looking at all the option I can get before making a decision.
Best regards
Jeff Owen
72 CAL 33
From: "aw… [at] bellsouth.net" <aw… [at] bellsouth.net>
Sent: Friday, July 18, 2008 10:14:11 AM
Subject: Re: [Cal_Boats] Need rubrail (Jeff)
http://www.sealsspars.com/gunnelcatalog.html
Please be sitting down when you look at the price....
Al
-------------- Original message from Jeffrey owen <je… [at] yahoo.com>: --------------
Good morning:
I need to replace the rub rail on a 72 CAL 33. Any suggestions on were to look? Thanks!
Best regards
Jeff Owen
Husar, Charlie [USA]2008-07-18 15:22 UTC
Jeff, look at this (D&R Marine).
http://www.drmarine.com/categories.asp
In the search box type in "rub rail". Make sure you have the space.
About half way down is a CAL rail. Our CAL 25s use the 55' section.
That is long, but having a tail makes the stretching much better.
Hope this helps.
Sent: Friday, July 18, 2008 11:19 AM
a decision.
Best regards
Jeff Owen
72 CAL 33
Al
Good morning:
Best regards
Jeff Owen
