12 messages2008-07-21 04:46 UTCthrough 2008-07-22 04:41 UTC
two blade folding
glen thorpe2008-07-21 04:46 UTC
Do all cal 29 sailboats back poorly? I have a 2 blade folding prop. and the boat has no control in reverse.My boat has an atomic 4 and tiller steering.Has any one tried the indigo marine 3 blade prop? HELP!!!
RE: [Cal_Boats] two blade folding
Downing, Thomas2008-07-21 12:05 UTC
Friend of mine put the Indigo 3-blade on his
Catalina 30. Made a big difference in backing
performance, better acceleration and less prop
walk. He has an Atomic 4 and tiller also.
td
From: Ca… [at] yahoogroups.com on behalf of glen thorpe
Sent: Mon 7/21/2008 12:46 AM
Subject: [Cal_Boats] two blade folding
DISCLAIMER:
Re: two blade folding
mtkennedy12008-07-21 14:10
--- In Ca… [at] yahoogroups.com, "Downing, Thomas"
> td
HELP!!!
Any fixed blade prop will back better than a folding prop. Maybe the
prop is not opening fully.
We went for a sunset sail Saturday evening. Because I had all
neophytes aboard, I put the main up in the slip. When we backed out of
the slip, which is normally an upwind slip at Cabrillo Marina, the
wind was coming down the channel and abeam of us. The main wasn't out
far enough to luff, because the boom had to clear the concrete post
the supports the dock. As a result, the bow swung the wrong way and I
had to back out of the channel about 200 yards before we could get to
a point where I had room to turn around. I was backing the Cal 40 with
a breeze about 5 to 7 knots pushing the main the wrong way. The two
blade Martec prop backed us out against the wind, and against the
main's push, with no trouble.
Mike Kennedy
Conquest Cal 40 # 96
Re: [Cal_Boats] Re: two blade folding
Joe DeMers2008-07-21 14:28 UTC
Mike Kennedy wrote -
SNIP -
Not true. The Gori props I sell are 2 and 3 blade folding, and out perform a
fixed prop in ahead AND astern, due to their large blade area.
The 3 blade Gori has a deeper pitch in astern than in ahead, resulting in
outstanding performance. They also can be operated in "overdive" in ahead,
with the boat at hull speed, and lowered engine rpm. This saves fuel, and
wear and tear on the engine and entire drive train.
Joe DeMers
Sound Marine Diesel LLC
www.soundmarinediesel.com
mtkennedy12008-07-21 15:01
> SNIP -
perform a
OK. The most common racing props are Martec and Gori and a couple of
others have been designed to avoid the Martec's problems. Still, I
think any fixed prop the same size will back better than a folding
prop. My point was that I have never had a problem with the Martec
backing. Besides, the last time I looked at a Gori prop it was
feathering and not folding. Am I misrememberng ?
Mike Kennedy
Conqest Cal 40 # 96
mtkennedy12008-07-21 15:05
> > SNIP -
> perform a
I looked at the Gori site and it is folding. I was thinking of another
prop.
Mike Kennedy
Conqest Cal 40 # 96
glen thorpe2008-07-21 15:07 UTC
Gori props cost more than my boat, they better back up!
--- On Mon, 7/21/08, mtkennedy1 <mt… [at] cox.net> wrote:
Subject: [Cal_Boats] Re: two blade folding
Date: Monday, July 21, 2008, 8:05 AM
> > SNIP -
> perform a
prop.
Mike Kennedy
Conqest Cal 40 # 96
Richard Anderson2008-07-21 15:18 UTC
I'll second Joe's opinion on the Gori....
We've had a 2 blade Gori on our Cal 29 for about a year now, it backs
extremely straight. We had crazy prop-walk with the fixed blade that
came on our boat. The Gori is slightly different diameter and pitch
than the old fixed (13x9 now vs 12x12). I saw a martec 2 blade on a
boat at the yard the other day and from what I can tell, the Gori is
also WAY better built, very solid. The blades swing with each other
using gear teeth at the pivot point. The Gori IS expensive, but in my
opinion you get what you pay for.
Richard Anderson
Cal 2-29
> > > SNIP -
> > perform a
> prop.
> Mike Kennedy
> Conqest Cal 40 # 96
David Wilkie Owen2008-07-21 15:26 UTC
The Gori¹s do fold, and are amazing. I have a Flex-O-Fold (geared folder)
that has wonderful thrust in reverse and significantly less prop walk than
my fixed prop did. I also re-sized to a 15X13 from a 12X12, so that
certainly helped. I believe that the mass of the blades makes a huge
difference.
Wilkie
Reply-To: <Ca… [at] yahoogroups.com>
Date: Mon, 21 Jul 2008 15:01:14 -0000
--- In Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com> , "Joe
> SNIP -
perform a
Mike Kennedy
Conqest Cal 40 # 96
Re: [Cal_Boats] two blade folding
Mark Alan Stahnke (MAS Consulting)2008-07-21 16:59 UTC
You just have to visualize the reverse as a thruster pushing the stern to port. Once you get the hang of it you can really navigate in and out of some really tight places providing you do not have to go straight back in the wind. Good luck PS get upwind slip!
Sent: Sunday, July 20, 2008 9:46 PM
__________ Information from ESET NOD32 Antivirus, version of virus signature database 3284 (20080721) __________
http://www.eset.com
Randy Alcorn2008-07-22 04:26 UTC
Glenn,
Welcome to the list and please tell us where you are located?
You are reffering to prop walk. All props walk the stern one way or the other.
I have a 2 bladed Martec and Atomic 4 as well.
I like to get the boat moving in reverse and then slip it into neutral to correct the walk. I have backed my boat down long fairways and the people always ask me how I can do it.
It really works and others have tried it and agree to it.
Randy
Cal 2-29
Out Patient
Channel Islands Ca
Date: Sunday, July 20, 2008, 11:46 PM
glen thorpe2008-07-22 04:41 UTC
I am from Marina del Rey California. This is my second Cal (my first was a Cal 25). I appreciate your advice on the prop walk issue, I will give your technique a try.
--- On Mon, 7/21/08, Randy Alcorn <sa… [at] yahoo.com> wrote:
Subject: Re: [Cal_Boats] two blade folding
Date: Monday, July 21, 2008, 9:26 PM
Glenn,
Randy
Cal 2-29
Out Patient
Channel Islands Ca
