29 messages2008-07-16 14:04 through 2008-07-22 14:07 UTC
Farymann Prop Size
franssell2008-07-16 14:04
I'm curious if anyone has tried a prop larger than a 12 x 12 on a
Farymann A30? I'm thinking about switching mine to a 12 x 14 to see if
I can get an extra knot of speed.
Re: [Cal_Boats] Farymann Prop Size
Joe DeMers2008-07-16 14:11 UTC
More information is needed, such as the boat's waterline length,
transmission reduction gear ratio, What HP @ what rpm, and max diameter prop
that will fit the boat.
Joe DeMers
Sound Marine Diesel LLC
www.soundmarinediesel.com
Sent: Wednesday, July 16, 2008 10:04 AM
Subject: [Cal_Boats] Farymann Prop Size
> Yahoo! Groups Links
> Checked by AVG.
> Version: 7.5.524 / Virus Database: 270.5.0/1555 - Release Date: 7/16/2008
> 6:43 AM
RE: [Cal_Boats] Farymann Prop Size
Harleigh Ewell2008-07-16 14:27 UTC
Find out what the maximum rated rpm is for your engine. Then run it full
throttle and see if it will exceed that rpm. If so, you can gain a little
speed at rated rpm with a prop with more pitch. If not, a higher pitch will
probably slow you down. All assuming you keep the diameter the same.
Harleigh Ewell
Of franssell
Frans Sell2008-07-16 14:27 UTC
Thanks for the reply,
It's a Cal 29, LOA 29 feet, the HP is 12hp and I'm not sure the transmission gear ratio. The max diameter is probably 12' so I was thinking about pitching up to 12 x 14 if the engine can handle it.
Thanks for the help,
Frans Sell
--- On Wed, 7/16/08, Joe DeMers <je… [at] mindspring.com> wrote:
Subject: Re: [Cal_Boats] Farymann Prop Size
Date: Wednesday, July 16, 2008, 7:11 AM
Joe DeMers
www.soundmarinedies el.com
To: <Cal_Boats@yahoogrou ps.com>
> Yahoo! Groups Links
> Checked by AVG.
> 6:43 AM
Frans Sell2008-07-16 14:42 UTC
Thanks for the info, one of the problems with the Farymanns is that they don't have a rpm gauge at all so it a matter of seat-of-your-pants engineering. I think she can handle it but maybe you're right it might slow the boat down.
Frans Sell
--- On Wed, 7/16/08, Harleigh Ewell <he… [at] comcast.net> wrote:
Subject: RE: [Cal_Boats] Farymann Prop Size
Date: Wednesday, July 16, 2008, 7:27 AM
Find out what the maximum rated rpm is for your engine. Then run it full throttle and see if it will exceed that rpm. If so, you can gain a little speed at rated rpm with a prop with more pitch. If not, a higher pitch will probably slow you down. All assuming you keep the diameter the same.
Harleigh Ewell
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of franssell
Husar, Charlie [USA]2008-07-16 14:54 UTC
Frans, for a 24 foot LWL (I believe that is accurate) on the CAL 29,
your flat water hull speed should be about 6.5 KN. How close to that do
you come now?
Annapolis
Behalf Of Frans Sell
Sent: Wednesday, July 16, 2008 10:28 AM
Frans Sell
diameter prop
Joe DeMers
<mailto:franssell%40yahoo.com> >
<mailto:Cal_Boats%40yahoogroups.com> >
on a
to see if
> Yahoo! Groups Links
> Checked by AVG.
Date: 7/16/2008
> 6:43 AM
Frans Sell2008-07-16 15:01 UTC
I think you're right. Hull should be 6.5 and I my current top speed is 4.5 knots using the Farymann.
Date: Wednesday, July 16, 2008, 7:54 AM
Frans, for a 24 foot LWL (I believe that is accurate) on the CAL 29, your flat water hull speed should be about 6.5 KN. How close to that do you come now?
Annapolis
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Frans Sell
Frans Sell
Joe DeMers
> Yahoo! Groups Links
> Checked by AVG.
> 6:43 AM
Husar, Charlie [USA]2008-07-16 15:17 UTC
Wow. I think my Nissan 8 outboard would push the boat as fast as that
if there was a way to mount it. A couple obvious things. How is the
bottom? Are you usually in sloppy water? Is the knotmeter accurate?
If you GPS, is there a lot of current?
Sent: Wednesday, July 16, 2008 11:02 AM
Annapolis
Frans Sell
diameter prop
Joe DeMers
on a
to see if
> Yahoo! Groups Links
> Checked by AVG.
Date: 7/16/2008
> 6:43 AM
Frans Sell2008-07-16 15:27 UTC
The bottom is ok and I have both a knot meter and GPS. These are both accurate. I actually have an outboard which can push the boat up to almost 7 knots. Its a 15 hp Mecury. But I like using the Farymann more because its much better on fuel. The outboard drinks over a gallon an hour.
Date: Wednesday, July 16, 2008, 8:17 AM
Wow. I think my Nissan 8 outboard would push the boat as fast as that if there was a way to mount it. A couple obvious things. How is the bottom? Are you usually in sloppy water? Is the knotmeter accurate? If you GPS, is there a lot of current?
--- On Wed, 7/16/08, Husar, Charlie [USA] <husar_charlie@ bah.com> wrote:
From: Husar, Charlie [USA] <husar_charlie@ bah.com>
Annapolis
Frans Sell
Joe DeMers
> Yahoo! Groups Links
> Checked by AVG.
> 6:43 AM
r good2008-07-16 15:55 UTC
gear ratio of the transmission and max rpms of the engine will be factors you'll need to know.
You could be "over propped" already and need to reduce the pitch instead of increasing it.
To: Ca… [at] yahoogroups.comFrom: hu… [at] bah.comDate: Wed, 16 Jul 2008 11:17:17 -0400Subject: RE: [Cal_Boats] Farymann Prop Size
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Frans SellSent: Wednesday, July 16, 2008 11:02 AMTo: Ca… [at] yahoogroups.comSubject: RE: [Cal_Boats] Farymann Prop Size
I think you're right. Hull should be 6.5 and I my current top speed is 4.5 knots using the Farymann. --- On Wed, 7/16/08, Husar, Charlie [USA] <hu… [at] bah.com> wrote:
From: Husar, Charlie [USA] <hu… [at] bah.com>Subject: RE: [Cal_Boats] Farymann Prop SizeTo: Ca… [at] yahoogroups.comDate: Wednesday, July 16, 2008, 7:54 AM
Annapolis
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Frans SellSent: Wednesday, July 16, 2008 10:28 AMTo: Cal_Boats@yahoogrou ps.comSubject: Re: [Cal_Boats] Farymann Prop Size
Frans Sell--- On Wed, 7/16/08, Joe DeMers <jedsail@mindspring. com> wrote:
From: Joe DeMers <jedsail@mindspring. com>Subject: Re: [Cal_Boats] Farymann Prop SizeTo: Cal_Boats@yahoogrou ps.comDate: Wednesday, July 16, 2008, 7:11 AM
More information is needed, such as the boat's waterline length, transmission reduction gear ratio, What HP @ what rpm, and max diameter prop that will fit the boat.Joe DeMersSound Marine Diesel LLCwww.soundmarinedies el.com----- Original Message ----- From: "franssell" <franssell@yahoo. com>To: <Cal_Boats@yahoogrou ps.com>Sent: Wednesday, July 16, 2008 10:04 AMSubject: [Cal_Boats] Farymann Prop Size> I'm curious if anyone has tried a prop larger than a 12 x 12 on a> Farymann A30? I'm thinking about switching mine to a 12 x 14 to see if> I can get an extra knot of speed.>>> ------------ --------- --------- ------>> Yahoo! Groups Links>>>>>> -- > No virus found in this incoming message.> Checked by AVG.> Version: 7.5.524 / Virus Database: 270.5.0/1555 - Release Date: 7/16/2008 > 6:43 AM>>
Harleigh Ewell2008-07-16 16:35 UTC
You can get adjustable timing lights that will tell you the rpm of the
flywheel pulley.
HE
Of Frans Sell
Sent: Wednesday, July 16, 2008 10:43 AM
the boat down.
Frans Sell
Harleigh Ewell
Behalf Of franssell
Richard Anderson2008-07-17 15:28 UTC
On our Cal 29 with the same farymann A30, we had the 12x12 also...
We've changed to a 13"x 9p. Gained about a knot on that and the
engine doesn't run as hard anymore.
Our boat DOES have a Tech attached to the farymann, we cruise about
2200 RPM at 6 knots. Towing a heavy dinghy and loaded for week long
trips with 4 people we get about 5.5 knots. Unloaded and out for just
a day, no dinghy, we've been seeing about 6.5 knots.
> the flywheel pulley.
> HE
> -----Original Message-----
> Frans Sell
> From: Harleigh Ewell <he… [at] comcast.net>
> Harleigh Ewell
> s.com] On Behalf Offranssell
Frans Sell2008-07-17 19:31 UTC
Richard,
Thank you so much for your info. I'm going to try the 13 x 9 size prop at our next haul out. It sounds like you've solved the notorious underpowered Farymann issue.
I'll let you know how it turns out.
Frans
Date: Thursday, July 17, 2008, 8:28 AM
On our Cal 29 with the same farymann A30, we had the 12x12 also... We've changed to a 13"x 9p. Gained about a knot on that and the engine doesn't run as hard anymore.
Our boat DOES have a Tech attached to the farymann, we cruise about 2200 RPM at 6 knots. Towing a heavy dinghy and loaded for week long trips with 4 people we get about 5.5 knots. Unloaded and out for just a day, no dinghy, we've been seeing about 6.5 knots.
You can get adjustable timing lights that will tell you the rpm of the flywheel pulley.
HE
Thanks for the info, one of the problems with the Farymanns is that they don't have a rpm gauge at all so it a matter of seat-of-your- pants engineering. I think she can handle it but maybe you're right it might slow the boat down.
Frans Sell
Harleigh Ewell
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Offranssell
r good2008-07-17 20:38 UTC
do you have access to multiple prop sizes or unlimited funds? if not, you should get all the information about your drive system including max engine RPMs and transmission ratio, prop tip clearance to the hull,etc. then, send it via internet to the Michigan Wheel people or a major prop manufacturer and get recommendations on the correct prop for your application. It won't cost you anything and could save a lot of time and potential expense versus the trial-and-error method.
To: Ca… [at] yahoogroups.comFrom: fr… [at] yahoo.comDate: Thu, 17 Jul 2008 12:31:27 -0700Subject: Re: [Cal_Boats] Farymann Prop Size
Richard,
Frans--- On Thu, 7/17/08, Richard Anderson <ri… [at] ctyl.org> wrote:
From: Richard Anderson <ri… [at] ctyl.org>Subject: Re: [Cal_Boats] Farymann Prop SizeTo: Ca… [at] yahoogroups.comDate: Thursday, July 17, 2008, 8:28 AM
HE
-----Original Message-----From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Frans SellSent: Wednesday, July 16, 2008 10:43 AMTo: Cal_Boats@yahoogrou ps.comSubject: RE: [Cal_Boats] Farymann Prop Size
Frans Sell
From: Harleigh Ewell <hewell@comcast. net>Subject: RE: [Cal_Boats] Farymann Prop SizeTo: Cal_Boats@yahoogrou ps.comDate: Wednesday, July 16, 2008, 7:27 AM
Harleigh Ewell
-----Original Message-----From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf OffranssellSent: Wednesday, July 16, 2008 10:04 AMTo: Cal_Boats@yahoogrou ps.comSubject: [Cal_Boats] Farymann Prop Size
I'm curious if anyone has tried a prop larger than a 12 x 12 on a Farymann A30? I'm thinking about switching mine to a 12 x 14 to see if I can get an extra knot of speed.
Re: Farymann Prop Size
wnancy362008-07-18 04:11
--- In Ca… [at] yahoogroups.com, "Harleigh Ewell" <hewell@...> wrote:
> Frans,
Windancer (Cal 2-27) has a A30 Farymann also and I have often
wondered about our prop which is a 3 blade 12 rh7. It pushes us
about 5.5 knots usually, a little more if we really wind up the
engine. Imagine our excitement when we discovered that we could do
close to 7 knots with our new Honda 9.9 outboard (discovered when we
were almost run down by one of Washington State Ferry systems
finest). The down side is that the Honda gobbles over twice as much
fuel per hour at cruising rpms as the inboard - like your Mercury.
So we are working hard to get the new-to-us A30 fully running and
tested before we leave for a couple of weeks in the San Juans. The
old A30 with the same prop gave us about a 1/2 knot less speed. Let
us know if you do change prop size how it goes.
The shop manuals for the A30 tell me that cruising rpms is 2500 but
as you say it's a guess without a tachometer...
Nancy Lewis-Williams
Windancer 2-27
Vashon Washington
the
> flywheel pulley.
> HE
On Behalf
> Of Frans Sell
they
might slow
> the boat down.
> Frans Sell
> --- On Wed, 7/16/08, Harleigh Ewell <hewell@...> wrote:
> From: Harleigh Ewell <hewell@...>
it full
little
pitch will
same.
> Harleigh Ewell
s.com] On
> Behalf Of franssell
if
Re: [Cal_Boats] Re: Farymann Prop Size
Frans Sell2008-07-18 05:08 UTC
Nancy,
I feel your pain, we had to start the outboard because the Farymann wouldn't even push us through Agate Pass a couple of weeks ago. We stood still at the red buoy with Farymann running at near max rpm. I was glad to hear that Richard Anderson was able to get his Cal 29 up to 5.5 knots with a 13 x 9 prop. After hearing all this positive feedback I'm convinced there's hope. I'm going to check my manual and talk to the prop shop in Fremont about the different sizes and I'll let you know how this all works out. I think there's more speed to be had for sure. However, I don't think I'll have any data for you prior to your trip. I have some other pressing issues with the Farymann that need tending to first. But when I do, I'll let you know.
I'm really liking the results Richard has had with his boat. I will say this, I've heard that you lose at least a half a knot or more sailing with a non-folding three bladed prop. I was told this by a fellow Cal 29 owner in Everett.
Frans Sell
Laissez-Faire 2-29
Seattle, WA
--- On Thu, 7/17/08, wnancy36 <jn… [at] juno.com> wrote:
Subject: [Cal_Boats] Re: Farymann Prop Size
Date: Thursday, July 17, 2008, 9:11 PM
--- In Cal_Boats@yahoogrou ps.com, "Harleigh Ewell" <hewell@...> wrote:
> Frans,
as you say it's a guess without a tachometer.. .
Windancer 2-27
Vashon Washington
the
> flywheel pulley.
> HE
> From: Cal_Boats@yahoogrou ps.com [mailto:Cal_Boats@yahoogrou ps.com]
On Behalf
> Of Frans Sell
they
might slow
> the boat down.
> Frans Sell
it full
little
pitch will
same.
> Harleigh Ewell
s.com] On
> Behalf Of franssell
if
Bert Pesak2008-07-18 13:32 UTC
I have a 1989 CAL 28-2 with a 18 HP Yanmar. I purchased the boat in Charleston, SC and ran it up the ICW to Cape May , NJ. The GPS showed 711 nm. I averaged 5.6 knots. Most of the time I ran the engine at 2600/2700 rpm and the speed was 5.8 /6.0 knots thru the water. The boat came with a Martec 2 blade folder that did not have good response in reverse. I replaced it with a 3 blade Campbell Sailor 13x9. I am very happy with the Campbell Sailor prop. If you call or email Campbell they may have some experience with your boat/engine combination and be able to recommend a prop to suit your boat.
Bert Pesak
bj… [at] gmail.com
Sent: Friday, July 18, 2008 1:08 AM
Subject: Re: [Cal_Boats] Re: Farymann Prop Size
Nancy,
Frans Sell
Laissez-Faire 2-29
Seattle, WA
> Frans,
Windancer 2-27
Vashon Washington
the
> flywheel pulley.
> HE
On Behalf
> Of Frans Sell
they
might slow
> the boat down.
> Frans Sell
it full
little
pitch will
same.
> Harleigh Ewell
s.com] On
> Behalf Of franssell
if
John Caldwell2008-07-18 13:37
We found that an electric fuel pump and fresh fuel did the trick for
our Farymann with a 12x12 prop.
When we still had the A30, she'd run in the 4-5 knot range - maybe
3.5 against a light current.
Changed the fuel pump to an electric, and with fresh fuel (how many
years does it take a Farymann to burn 25 gallons?) it didn't take too
much to be motoring with wet feet.
Best,
John Caldwell
1977 2-29 #966
--- In Ca… [at] yahoogroups.com, Frans Sell <franssell@...> wrote:
> Nancy,
> Frans Sell
> Laissez-Faire 2-29
> Seattle, WA
> --- On Thu, 7/17/08, wnancy36 <jnnwill2@...> wrote:
> From: wnancy36 <jnnwill2@...>
> --- In Cal_Boats@yahoogrou ps.com, "Harleigh Ewell" <hewell@> wrote:
> > Frans,
we
> Windancer 2-27
> Vashon Washington
Frans Sell2008-07-18 13:58 UTC
John,
That's really interesting, do you remember what type of electric pump you used?
Frans
Date: Friday, July 18, 2008, 6:37 AM
Best,
John Caldwell
1977 2-29 #966
--- In Cal_Boats@yahoogrou ps.com, Frans Sell <franssell@. ..> wrote:
> Nancy,
> Frans Sell
> Laissez-Faire 2-29
> Seattle, WA
> --- On Thu, 7/17/08, wnancy36 <jnnwill2@.. .> wrote:
> From: wnancy36 <jnnwill2@.. .>
> > Frans,
we
> Windancer 2-27
> Vashon Washington
Mark Alan Stahnke (MAS Consulting)2008-07-18 16:26 UTC
Do you still have the martec? I would'nt mind replacing my 12x12 fixed with a folding if the price is right.
Sent: Friday, July 18, 2008 6:32 AM
Bert Pesak
bj… [at] gmail.com
Nancy,
Frans Sell
Laissez-Faire 2-29
Seattle, WA
> Frans,
Windancer 2-27
Vashon Washington
the
> flywheel pulley.
> HE
On Behalf
> Of Frans Sell
they
might slow
> the boat down.
> Frans Sell
it full
little
pitch will
same.
> Harleigh Ewell
s.com] On
> Behalf Of franssell
if
__________ Information from ESET NOD32 Antivirus, version of virus signature database 3280 (20080718) __________
http://www.eset.com
Bert Pesak2008-07-18 17:02 UTC
Yes, I have the Martec. I don't know the Dia. or Pitch. I have not thought about selling it. Give me some time to think about it.
Bert
Sent: Friday, July 18, 2008 12:26 PM
Bert Pesak
bj… [at] gmail.com
Nancy,
Frans Sell
Laissez-Faire 2-29
Seattle, WA
> Frans,
Windancer 2-27
Vashon Washington
the
> flywheel pulley.
> HE
On Behalf
> Of Frans Sell
they
might slow
> the boat down.
> Frans Sell
it full
little
pitch will
same.
> Harleigh Ewell
s.com] On
> Behalf Of franssell
if
http://www.eset.com
Richard Anderson2008-07-18 20:33 UTC
Frans,
I left out some of the details in my previous email.. The new 13x9 is
a 2blade folding prop from Gori. We actually talked with Gori before
ordering so they could help us pick a proper size and pitch. As I
mentioned before our boat does have a tachometer so it's not to hard
to see what that A30 is doing. We are extremely pleased with the Gori
folding prop especially with the reduced drag under sail.
Richard
On Jul 17, 2008, at 10:08 PM, Frans Sell wrote:
> Nancy,
> Frans Sell
> Laissez-Faire 2-29
> Seattle, WA
> From: wnancy36 <jn… [at] juno.com>
> wrote:
> > Frans,
> Windancer 2-27
> Vashon Washington
> the
> > flywheel pulley.
> > HE
> On Behalf
> > Of Frans Sell
> they
> might slow
> > the boat down.
> > Frans Sell
> it full
> little
> pitch will
> same.
> > Harleigh Ewell
> s.com] On
> > Behalf Of franssell
> if
Electric Fuel Pump ( Was Farymann Prop Size)
John Caldwell2008-07-19 02:55
It's just a basic 12v UL Approved fuel pump. I'll take a look on
Saturday - I still have it laying around the boat.
If the Farymann feels kind of slow or sluggish, and maybe you see some
dark exhast, if you switch to an electric pump I'd also suggest that
you check the fuel and tank.
If the fuel in the tank is old and it looks like root beer after being
polished then it's time for new fuel, and if you have the black steel
tank be sure to have it cleaned before replacing old fuel if you
haven't already. You might also want to see if the stock fuel filter
has been removed or should be in favor of an in-line.
Best,
John
> John,
you used?
> Frans
Re: [Cal_Boats] Electric Fuel Pump ( Was Farymann Prop Size)
Mark Alan Stahnke (MAS Consulting)2008-07-19 22:36 UTC
I have a racor separator just before the Farymann, is this a fuel filter as well? and if so can the filter on the engine be removed to improve flow?
Sent: Friday, July 18, 2008 7:55 PM
Subject: [Cal_Boats] Electric Fuel Pump ( Was Farymann Prop Size)
Best,
John
> John,
you used?
> Frans
__________ Information from ESET NOD32 Antivirus, version of virus signature database 3282 (20080719) __________
http://www.eset.com
Chuck Lennox2008-07-19 23:47 UTC
Gang
I have been reading this thread on and off for a while. I would like to make a few comments.
I had a R-30 for too many years in my Cal 2-34.
1. The fuel pump between the tank is used for 'lifting" the fuel to the engine's injector pump. There should be no performance gain with a electric pump. If fuel level (tank) was above the engine injector pump the lift pump wouldn't be needed. The injector pump is the power component not the lift pump.
2. Dirty fuel is the worst enemy to a Diesel engine. At one time I had three filters. A 35 micron,20 micron and a finish filter of 5 micron. After tank replacement I dropped the 35. Don't overlook dirty filter during trouble shooting. I use a vacuum gage to keep track of my filter condition. If vacuum increases, on the suction side of lift pump. I change the filter.
3. I preferred using only the engine driven lift pump for normal operations. I did have an electric pump for back up and for priming the system. One advantage to using the mechanical only is the engine will run without any electrical power. On a good day you hand crank a engine with dead batteries and run without any electrical power.
4. The correct way to check your engine output you must be able to determine engine RPM. As it has already been discussed you may have too much prop already.
Just my .02
Chuck
--- On Sat, 7/19/08, Mark Alan Stahnke (MAS Consulting) <ma… [at] cox.net> wrote:
Subject: Re: [Cal_Boats] Electric Fuel Pump ( Was Farymann Prop Size)
Date: Saturday, July 19, 2008, 3:36 PM
Best,
John
> John,
you used?
> Frans
http://www.eset. com
scott2008-07-20 02:27 UTC
Hello
Everyone
I agree with Chuck
My boat hs the A30 Farryman with stock pumps and the stock filter plus a Racor
The tank has been replaced with a Tempo, The farryman is running great.
The prop is a Martec 15x10 I plan to go to a 14x10 next haul I can get 6 knots
the Farryman is low in power for our 2-29 it has no reserve power when against tide
and chop.
But the yellow demon just wont quit. When it does a 20hp at least will be in my boat
Scott
2-29 Coyote Pt CA
Date: Saturday, July 19, 2008, 4:47 PM
Gang
Just my .02
Chuck
--- On Sat, 7/19/08, Mark Alan Stahnke (MAS Consulting) <masconsult@cox. net> wrote:
From: Mark Alan Stahnke (MAS Consulting) <masconsult@cox. net>
Best,
John
> John,
you used?
> Frans
Re: Electric Fuel Pump ( Was Farymann Prop Size)
John Caldwell2008-07-21 04:33
My old fuel pump was tired and not supplying enough fuel. Since I
couldn't find a rebuild kit for the pump, I went electric. With the
12x12 prop I didn't have any problems running against the tide or
moderate currents.
Best,
John
--- In Ca… [at] yahoogroups.com, scott <sscot12@...> wrote:
> Hello
> Everyone
> I agree with Chuck
plus a Racor
great.
get 6 knots
when against tide
> and chop.
will be in my boat
> Scott
> 2-29 Coyote Pt CA
> --- On Sat, 7/19/08, Chuck Lennox <lennoxchuck@...> wrote:
> From: Chuck Lennox <lennoxchuck@...>
Size)
Fred Haas2008-07-22 02:29 UTC
Frans,
Bag Fremont Call Seattle Propellor in Ballard. They are the Michigan
dealer (distributor?) They were super at helping me get the right prop
on Nemesis. They are also Tacoma Propellor , with whom I do a fair
amount of business in my day job. I have never had a bad experience
with them. I am running a Michigan "sailor" 16 X 13, I think, on
Nemesis with a Universal 35 XPB. I can push 6.5 if I need to into any
sea, but rarely do.
Fred Haas
3-30 Nemesis
x
> Nancy,
> Frans Sell
> Laissez-Faire 2-29
> Seattle, WA
>> wrote:
>> > Frans,
>> Windancer 2-27
>> Vashon Washington
>> the
>> > flywheel pulley.
>> > HE
>> On Behalf
>> > Of Frans Sell
>> they
>> might slow
>> > the boat down.
>> > Frans Sell
>> it full
>> little
>> pitch will
>> same.
>> > Harleigh Ewell
>> s.com] On
>> > Behalf Of franssell
>> if
Frans Sell2008-07-22 14:07 UTC
Fred,
Thanks for the heads up. I will check with them once I get this process started. I appreciate the help.
Frans
Date: Monday, July 21, 2008, 7:29 PM
Frans,
sea, but rarely do.
Fred Haas
3-30 Nemesis
x
> Nancy,
manual and
prior
> Frans Sell
> Laissez-Faire 2-29
> Seattle, WA
<hewell@...>
>> wrote:
>> > Frans,
>> Windancer 2-27
>> Vashon Washington
>> the
>> > flywheel pulley.
>> > HE
ps.com]
>> On Behalf
>> > Of Frans Sell
that
>> they
pants
it
>> might slow
>> > the boat down.
>> > Frans Sell
>> it full
a
>> little
>> pitch will
>> same.
>> > Harleigh Ewell
>> s.com] On
>> > Behalf Of franssell
on a
to see
>> if
