3 messages2008-07-27 17:05 through 2008-07-28 04:47 UTC
cal 29 purchase
bergsboat2008-07-27 17:05
Hello, my name is Eric and I just joined the group today. I'm looking
to buy a cal 29.I just read about the compression post beam and
wondered if anybody had any more tips/info that I should be aware
of/looking for.What are some of the good/bad points about these boats?
Are people taking these on coastal trips? I'll be sailing on S.F. bay
and mabey out the gate (on nice days). Any info would be greatly
appreciated, thanks...... Eric
Re: [Cal_Boats] cal 29 purchase
Randy Alcorn2008-07-28 03:49 UTC
Eric,
Welcome to the list.
The CAL 29 is a wonderful boat.
Yes it has the beam. It depends on the condition of it to have to replace it.
Hope you purchase it and join the list.
Randy
CAL 2-29
Out Patient
Channel Islands Ca
--- On Sun, 7/27/08, bergsboat <be… [at] yahoo.com> wrote:
Subject: [Cal_Boats] cal 29 purchase
Date: Sunday, July 27, 2008, 12:05 PM
David Wilkie Owen2008-07-28 04:47 UTC
Eric,
I love my 29. It sails very well for it¹s era will out sail most boats of
it¹s age in it¹s class.
I really enjoy the layout. Works well for my weekend Island trips around
the Santa Barbara Channel. I sailed Puget Sound quite a bit as well.
She is a little tender initially, but stiffens up nicely. She likes a #2
headsail when it gets up around 18 knots or so and a reef in the main
usually nets an increase in boat speed as she likes to sail fairly flat.
These boats have been sailed off-shore. I know guys that have taken them to
Hawaii and back and say they are very friendly off shore.
Like her big sister, the Cal 40, she loves to surf under spinnaker or even
on a deep reach with the genoa out. The truth is, I¹ve even surfed her
up-wind when the wind went light and shifted against an earlier established
swell.
The beam is a random source of concern. I¹ve seen 29s that were pretty
neglected that had perfect beams and, of course, just the opposite. It may
depend on how well the wiring pass inside the mast has been caulked over the
years, as well as chainplate leakage and in my case the ice box drain was
routed inside the web of the beam. I urge you to find a way to inspect it.
You can start by using an extending mirror (Kragen or Pep Boys sell these
cheap) and flashlight. Angle the flashlight onto the mirror near your
eye-sight path and the beam will be reflected into the interior in the same
direction that you are viewing. The opening around the head discharge
thru-hull will give you a little view. The most forward storage bin under
the port settee will get you a side view from the port end of the beam and
you can learn a lot by looking at the tab in the center (visible under the
transverse portion of the settee.)
Other concerns are similar to production boats of their age and chainplate
and through deck fittings can lead to core rot and delamination of the deck
glass to the plywood core. Check around those. Blisters seem to be a
reasonably mild concern most reports are gel-coat blisters with
occasionally more severe osmosis on older boats. The rudders blister easily
and if you put the boat into the yard you should cover the rudder with some
white plastic to defend it from the sun.
Flexing of the hull along the turn of the bilge into the keel was a topic of
concern, but usually not a problem on the 29. I have become pretty
conversant in these things, as I had some noticeably increased keel wobble
on my boat this last haul-out. It turned out that there wasn¹t significant
damage to the hull-layup, but internal tabbing had broken loose as a result
of the prior owner¹s mechanic cutting out part of the pan in the engine
room. I have taken the time to reinforce everything.
I haven¹t heard of any other real concerns along these lines on the 29, but
have seen 27s and 28s with fairly severe cracking along this area, which
could eventually lead to failure. I¹ve been told that this is pretty
obvious on your haul-outs, as the cracks weep sea water after the rest of
the hull has dried. Apparently, the 27 had a tendency to crack at the aft
edge of the keel where it met the hull, resulting in a need for fairly minor
repairs.
Hope this helps.
Wilkie
Reply-To: <Ca… [at] yahoogroups.com>
Date: Sun, 27 Jul 2008 17:05:28 -0000
