10 messages2008-08-13 00:57 UTCthrough 2008-08-14 03:28 UTC
Boot Stripe Water Line
Chris Bowen2008-08-13 00:57 UTC
Hi Cal List,
I have a question. I normally keep my boat on a trailer and just drop it in,
raise the mast and rig it and all, which lets me keep the bottom paint free,
and fast. However, I have finally been able to acquire a slip, and now have
to consider bottom paint.
My question is how does one determine the boot stripe, or water line to
paint to?
My boat has never had one. Always clean from the rail to the keel.
I am in the Pacific Northwest - Puget Sound - Salt
Lurking on the List
Thanks
Chris
Re: Boot Stripe Water Line
mtkennedy12008-08-13 01:47
--- In Ca… [at] yahoogroups.com, "Chris Bowen" <ckbow@...> wrote:
> Hi Cal List,
drop it in,
paint free,
now have
> paint to?
You'll probably have to launch it and mark the existing waterline.
I would allow a couple of inches of bottom paint above that and then
do a bootstripe.
Mike Kennedy
Conquest Cal 0 # 96
> Lurking on the List
> Thanks
> Chris
RE: [Cal_Boats] Boot Stripe Water Line
Husar, Charlie [USA]2008-08-13 01:58 UTC
Chris, what model of boat do you have? You might be able to work it by
scaling from a photo of another boat.
Annapolis
Behalf Of Chris Bowen
Sent: Tuesday, August 12, 2008 8:57 PM
To: ca… [at] yahoogroups.com
Subject: [Cal_Boats] Boot Stripe Water Line
Hi Cal List,
in, raise the mast and rig it and all, which lets me keep the bottom
paint free, and fast. However, I have finally been able to acquire a
slip, and now have to consider bottom paint.
paint to?
Lurking on the List
Thanks
Chris
RE: [Cal_Boats] Re: Boot Stripe Water Line (Mike)
Chris Bowen2008-08-13 03:21 UTC
I thought I would probably do that. It was just that I seem to remember some
type of conversation about a special process to find the water line, but
dropping it in the water like you suggest and marking it would seem to be
pretty straight forward.
Thanks Again
Chris
Ex-Cal 2-29
Now Pacific Seacraft 20 Flicka
+ Vagabond 17
-----Original Message-----
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On
Behalf Of mtkennedy1
Sent: Tuesday, August 12, 2008 6:48 PM
Subject: [Cal_Boats] Re: Boot Stripe Water Line
> Hi Cal List,
drop it in,
paint free,
now have
> paint to?
do a bootstripe.
Mike Kennedy
Conquest Cal 0 # 96
> Lurking on the List
> Thanks
> Chris
glen thorpe2008-08-13 04:22 UTC
If you launch at a boat yard they will put sawdust in the water and dip your boat in and out and the sawdust sticking to the hull will show you the true waterline. Kool huh?
--- On Tue, 8/12/08, Chris Bowen <ck… [at] wavecable.com> wrote:
Subject: RE: [Cal_Boats] Re: Boot Stripe Water Line (Mike)
Date: Tuesday, August 12, 2008, 8:21 PM
I thought I would probably do that. It was just that I seem to remember some type of conversation about a special process to find the water line, but dropping it in the water like you suggest and marking it would seem to be pretty straight forward.
Thanks Again
Chris
Ex-Cal 2-29
+ Vagabond 17
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com]On Behalf Of mtkennedy1
--- In Cal_Boats@yahoogrou ps.com, "Chris Bowen" <ckbow@...> wrote:
> Hi Cal List,
drop it in,
paint free,
now have
> paint to?
do a bootstripe.
Mike Kennedy
Conquest Cal 0 # 96
> Lurking on the List
> Thanks
> Chris
Re: [Cal_Boats] Re: Boot Stripe Water Line (Mike)
Michael Kennedy2008-08-13 05:40 UTC
On Aug 12, 2008, at 8:21 PM, Chris Bowen wrote:
> Thanks,
There is a way to paint the boot top by using a long piece of plastic
tubing (clear) filled with water to mark it and keep it level but
first you have to find how it floats. Once you mark the line, you can
haul it and paint the waterline as long as the boat is level in the
cradle.
Mike Kennedy
Conquest Cal 40 # 96
> Thanks Again
> Chris
> Ex-Cal 2-29
> + Vagabond 17
> > Hi Cal List,
> drop it in,
> paint free,
> now have
> line to
> > paint to?
> do a bootstripe.
> Mike Kennedy
> Conquest Cal 0 # 96
> > Lurking on the List
> > Thanks
> > Chris
Downing, Thomas2008-08-13 11:21 UTC
If you can mark a point near the bow and one near the stern,
you can use a laser rule to mark the whole line. This is
a nifty little tool that a contractor friend may have, or
you may be able to rent from a big box. It just rotates
an led laser so that a straight line can be marked. With
the boat in cradles, the bow and stern marks won't be
level, so just tilt the laser till it crosses the marks,
walk up to the boat and mark the line and tape.
Only requirement is that the boat is level as to roll,
and that the laser rule is at the height that is half
way between the heights of the bow and stern, and is
amidships.
td
From: Ca… [at] yahoogroups.com on behalf of Michael Kennedy
Sent: Wed 8/13/2008 1:40 AM
Subject: Re: [Cal_Boats] Re: Boot Stripe Water Line (Mike)
> Thanks,
cradle.
Mike Kennedy
> Thanks Again
> Chris
> Ex-Cal 2-29
> + Vagabond 17
> > Hi Cal List,
> drop it in,
> paint free,
> now have
> line to
> > paint to?
> do a bootstripe.
> Mike Kennedy
> Conquest Cal 0 # 96
> > Lurking on the List
> > Thanks
> > Chris
Yahoo! Groups Links
DISCLAIMER:
Downing, Thomas2008-08-13 11:26 UTC
Of course, if you want it to be REALLY pretty, you
can add a bit of shear to the boot stripe. It should
be proportional to the shear of your hull. It's not
enough to see unless you look for it, and if you don't
do it, you won't miss it, but it's one of the things that
make a difference in the overall visual appeal of the boat.
td
From: Ca… [at] yahoogroups.com on behalf of Chris Bowen
Sent: Tue 8/12/2008 8:57 PM
Hi Cal List,
paint to?
Lurking on the List
Thanks
Chris
DISCLAIMER:
Chris Campbell2008-08-13 16:09 UTC
mtkennedy1 wrote:
> --- In Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>,
> > paint to?
> do a bootstripe.
This is probably the best plan, because your boat's actual waterline
will depend on how much equipment and miscellaneous stuff you carry.
One of my boats floats a bit off her lines because of inside ballast
that wasn't artfully placed. I've been moving the ballast (need to
recast some lead to do it properly) because she's faster when I move
crew forward. And she tends to list a bit in the slip, another sign of
need to move weight around.
So my point here is that putting the boat in the water long enough to
let the natural waterline get marked by staining or a bit of plant
growth is a good plan, but you may want to measure some to make sure
it's symmetrical (boat's not listing or squatting or whatever). If the
revealed waterline is not symmetrical, you may want to move stuff around
before marking and painting a line.
Of course, the suggestion of allowing a couple inches of bottom paint to
show before adding the boottop is a good one; it allows a bit of wiggle
room. I'd add that you can separate the boottop stripe from the bottom
paint by 1/2" or so if you do that, making it easier to paint, repair,
and maintain each of those separate paint systems.
RE: [Cal_Boats] Re: Boot Stripe Water Line (All),
Chris Bowen2008-08-14 03:28 UTC
All
Thanks for all the responses to my question. After selling my 2-29 a couple
of years ago, I have kept lurking on the list for just this reason. A lot of
good sailing stories and maintenance tips. I am launching this week-end and
will keep her in her slip for a few days keeping track of the weight
distribution, mark the water line, then pull her out and take in to account
all the suggestions I have received and paint. The main thing is to get her
back in the water and sail as much as I can while the weather is good.
Thanks Again
Chris Bowen
Behalf Of Chris Campbell
Sent: Wednesday, August 13, 2008 9:10 AM
to
> paint to?
do a bootstripe.
This is probably the best plan, because your boat's actual waterline will
depend on how much equipment and miscellaneous stuff you carry. One of my
boats floats a bit off her lines because of inside ballast that wasn't
artfully placed. I've been moving the ballast (need to recast some lead to
do it properly) because she's faster when I move crew forward. And she
tends to list a bit in the slip, another sign of need to move weight around.
So my point here is that putting the boat in the water long enough to let
the natural waterline get marked by staining or a bit of plant growth is a
good plan, but you may want to measure some to make sure it's symmetrical
(boat's not listing or squatting or whatever). If the revealed waterline is
not symmetrical, you may want to move stuff around before marking and
painting a line.
paint by 1/2" or so if you do that, making it easier to paint, repair, and
