4 messages2008-08-25 03:31 UTCthrough 2008-08-26 15:37
cal 29 headliner
glen thorpe2008-08-25 03:31 UTC
Hi Folks,
I am going to take the headliner panels on my Cal 29 and put new material on them. Should I expect any surprises?? Any suggestions?
Thanks!
Glen
Re: cal 29 headliner
John Caldwell2008-08-25 17:59
Hi Glen,
Our 1977 had the vinyl headliner. This drops about 3/8" from the
cabin top. The original had plastic runners that another piece of
plastic would press into to make the seam. (The cabin top also
had "Santos was here" under the resin, which I thought kind of cool).
We moved from the 4-panel vinyl layout to a 3-panel vinyl and used
3/8" battens. Since we added 4 runs of rope lights the cabin
length, the sides were glued down and the runners screwed down on
top. The vinyl was wrapped on the outer battens butted against the
outer run of rope lights, and then pulled tight and stapled to the
battens near the inner run of rope lights and then topped of with
teak "crowns".
If I had to do it over again, I'd probably do it pretty much the
same way, however would have wrapped the vinyl over the inner
battens and used the crowns to hind the mounting screws. Doing so
would make pulling the headliner panels down for deck hardware a
little easier.
I'd suggest taking the ports out for the side panels. We replaced
the old plastic ports with smoked tempered glass from Mark Plastics
and did the headliner side panels at about the same time. Left over
vinyl will become snap-in "curtains" for the new ports.
Before and after photos may be found at
http://ph.groups.yahoo.com/group/Cal_Boats/photos/view/c90c?b=10
(before) and
http://ph.groups.yahoo.com/group/Cal_Boats/photos/view/c90c?b=11
If you are going the vinyl route, be sure to locate the handrail
screw holes....
Best,
John
--- In Ca… [at] yahoogroups.com, glen thorpe <glenhove2@...> wrote:
> Hi Folks,
> Thanks!
> Glen
Re: [Cal_Boats] Re: cal 29 headliner
David Wilkie Owen2008-08-25 19:50 UTC
John,
Your headliner looks great. Did your boat come with the headliner on the
side panels or was it something added later?
What year is your 29? Mine had the perf vinyl headliner, but never did have
any side treatments other than rolled on paint as near as I can tell. The
PO added teak batten ceilings, but actually ran the very tip of some of the
screws all the way through the furring strips and through the hull. I
removed all and have just paint on all of the ceilings.
So, I ended up copping out with a coat of flat paint on the overhead after
accidentally destroying my headliner. Later, I fared and glossed it up
after seeing Fin¹s 40, ³Radiant.² It looks great, but I think is workable
only in Southern California or other warm climate where condensation is not
usually an issue.
Wilkie
Reply-To: <Ca… [at] yahoogroups.com>
Date: Mon, 25 Aug 2008 17:59:16 -0000
Subject: [Cal_Boats] Re: cal 29 headliner
Hi Glen,
teak "crowns".
little easier.
(before) and
screw holes....
Best,
John
--- In Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com> , glen
> Hi Folks,
> Thanks!
> Glen
John Caldwell2008-08-26 15:37
Hi Wilkie,
Thanks for the encouraging words!
She's a 1977 2-29 (#966). The side panels were OEM and was of the
old-school perforated variety as was the top. We are fortunate with
the SoCal climate that condensation isn't much of a problem. We'd
kicked around adding some of those cool little button vents just to
be on the safe side, but at the last minute decided not to.
After 30 years the steel staples that held in the plastic runners
were almost non-existent, and the plastic was brittle and hard to
work with, and my wife wanted rope lights, so we just started over
from scratch.
One of the things that we wanted to do was to cover up any deck
hardware coming down from the top, but also leaving it in such a way
that we could drop a top panel on one side or another for access if
the need occurred.
If I were to do it again, I'd measure a little better on the top
battens to keep the mounting screws closer to the outer edge, pull
the vinyl tight to that edge, staple it up, slice a small opening
for the mounting screws, pull it down, and then wrap the vinyl over
the batten, staple it again, and then put it back up and cover the
mounting screws with the crown.
I'm really anxious to see how your teak/holly cabin sole comes out.
That's on our list after we complete our repower this year.
Are you planning on just doing the floor, or are you going to take
it up the sides under the cabinets and settee? We're leaning to
floor only and then carpet on the sides and around the table
pedestal with some 1/4 round teak trim. Have you given any thought
as to how you're going to work in the bilge cover?
Best,
John
> John,
on the
never did have
tell. The
some of the
hull. I
overhead after
it up
workable
condensation is not
> usually an issue.
> Wilkie
