9 messages2008-09-08 17:04 UTCthrough 2008-09-16 16:29 UTC
Re: [Cal_Boats] Bulkheads
Jeffrey owen2008-09-08 17:04 UTC
Chris:
Thanks for the feedback, I actually know very little about what woods are good for interior boat work - my main concern lies in the materials for the bulkheads, because of structural integrity. What is recommendable? I'd like light wood, as I plan to change to a clearer interior. Again, feedback is appreciated!
All the best
Jeff
Sent: Monday, September 8, 2008 11:03:31 AM
Subject: Re: [Cal_Boats] Bulkheads
Jeffrey owen wrote:
Good morning
Hope all is well, I have been enjoying the posts and printing some for future reference.
Anyway, to the point. I have been replacing sections of deck core with marine plywood. I am almost done with that, and now will begin bulkhead replacement. I plan to use red oak laminated plywood, but would like to know if that is recommendable.
Jeff:
As you probably know, red oak was disfavored traditionally as a boatbuilding material because of its pore structure, which favored movement of moisture and rot spores in the wood, leading to early failure. There's also an issue of the effect of oak's tannins on the cure and strength of epoxy.
My guess is that the plywood has oak veneers only, with some other core plies. In that case, you could seal the edges with epoxy successfully. If the red oak veneers didn't interfere substantially with epoxy bonding (go look at the Gougeon Bros. web site and see what they have to say), then it's probably not a problem.
RE: [Cal_Boats] Bulkheads - OKUME
ti… [at] ch2m.com2008-09-08 17:15 UTC
I have used OKUME Plywood in the past. It is Lloyds of London A1 rated, very strong with nicely finished covers.
Husar, Charlie [USA]2008-09-08 17:56 UTC
That's the word! That's the word! Couldn't remember for the life of
me. Wudda spelt it wrong anyway.
Behalf Of ti… [at] ch2m.com
Sent: Monday, September 08, 2008 1:15 PM
Subject: RE: [Cal_Boats] Bulkheads - OKUME
RE: [Cal_Boats] Bulkheads - OKOUME
ti… [at] ch2m.com2008-09-08 17:58 UTC
(I spell it worng too) :)
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Husar, Charlie [USA]
Sent: Monday, September 08, 2008 10:57 AM
Subject: RE: [Cal_Boats] Bulkheads - OK O UME
That's the word! That's the word! Couldn't remember for the life of me. Wudda spelt it wrong anyway.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of ti… [at] ch2m.com
Chris Campbell2008-09-08 19:31 UTC
Jeffrey owen wrote:
> Chris:
Jeff:
WoodenBoat magazine has had a long-running column on the characteristics
and uses of various woods. If you know somebody with the back issues on
CD, you can find a lot.
Some woods are strong and bendable (e.g., white oak, used for wooden
boat frames (ribs)) and others are more easily worked and reasonably rot
resistant (e.g., mahogany), while others can combine strength and
lightness (Sitka spruce, used in boat masts and airplane parts), and
others are light and easly worked and rot-resistant (like white cedar,
used to plank boats intended to be light). Teak is used extensively now
for exterior joinery because the wood is dense, tough, and highly rot
resistant. But its oils make it difficult to glue.
Red oak has long been avoided because it rots easily and stains easily
from exposure to iron. I've seen arguments that it can be used in
boatbuilding but that's a minority view. Oak generally does not epoxy
up very well, which means it would be harder to secure to the boat by
the usual fiberglass tabbing. Bulkheads are often structural members,
not just visual breaks, so strength matters. Do get the boatbuilding
book or online info from the Gougeon Brothers company. They know all
there is to know about epoxy applications in boatbuilding.
gene ulmer2008-09-10 12:33 UTC
hi my 2 cents worth
okoume ply is great stuff we used it when plywood was called for on all of thecatamarrans that we built however it has gotten extremely expensive. for this reason i might would use fir plywood, a bit heavier and maybe not quite as strong but is ok for bulkheads. also its usually in stock at a good coastal lumber yard i have actually seen it in some home depots. at 1/3 the cost its not a bad deal and it takes paint really well
gene
ramblin rose cc46
Date: Monday, September 8, 2008, 1:15 PM
ti… [at] ch2m.com2008-09-10 17:42 UTC
Good to know there are choices. For a rebuild, of such an important structure, I know that I was willing to spend the few extra bucks for "bulletproof" material. For me the many hours of labor to install wash away the cost, and long term, for me, the Okoume is really beautiful.
now we're up to 4 cents?
dEmO
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of gene ulmer
Sent: Wednesday, September 10, 2008 5:33 AM
hi my 2 cents worth
gene
ramblin rose cc46
Re: [Cal_Boats] Bulkheads - OKUME
Chris Campbell2008-09-10 19:16 UTC
I built my wood/epoxy sea kayak of okoume plywood over 11 years ago, and
it has been afloat in the Great Lakes every month since I launched.
Mind you, I maintain it carefully, and the wood is entirely
epoxy-encapsulated, so I could have built the boat of birch and it would
still be rot free. Okoume is not greatly rot-resistant. I think it
falls in the "somewhat" range. The key is to protect it from moisture
intrusion by making sure that all edges, surfaces, and penetrations are
thoroughly sealed with epoxy.
One advantage of okoume is that it's available in marine grades, which
means fewer voids in the inner plies. Long ago, "interior plywood" was
stuff with water-soluble glues. I understand that all plywoods use
waterproof glues now so that's less of an issue. But specs for
non-marine grades do allow larger voids.
Downing, Thomas2008-09-16 16:29 UTC
How about Aquatech and Marinetech (I believe I've got
that right.) Also mahogany, but not Okoume, and I
understand, cheaper. One has no internal voids, the
other does.
From: Ca… [at] yahoogroups.com on behalf of ti… [at] ch2m.com
Sent: Wed 9/10/2008 1:42 PM
dEmO
hi my 2 cents worth
gene
ramblin rose cc46
