Cal29 transmission
Cal29 transmission
2 messages2008-09-15 17:55 through 2008-09-16 18:14 UTC
Cal29 transmission
Scott2008-09-15 17:55
My transmission which is a Hurth. I think it is a 100 I will have to look at the boat to be sure. It doesn't shift into forward if it is reved at all or if it is in already in forward and hit the throttle it slips then shifts into gear. Is this a rebuild? If so do I have to haul the boat? Thanks, Scott Cal29 "Hatikvah"
Re: [Cal_Boats] Cal29 transmission
Fred Haas2008-09-16 18:14 UTC
Scott, Before you pill the tranny, not the boat; try changing out the fluid with a full synthetic. Hurth recommends regular fluid, but last fall when my hurth declined to engage or hold gears I tried synthetic with great success. Anyone on the list will tell you your Hurth is a POS, but a paid for, working POS is better than the alternative. Keep Smiling, Fred Haas 3-30 Nemesis Tacoma On Sep 15, 2008, at 10:55 AM, Scott wrote > My transmission which is a Hurth. I think it is a 100 I will have to > look at the boat to be sure. It doesn't shift into forward if it is > reved at all or if it is in already in forward and hit the throttle it > slips then shifts into gear. Is this a rebuild? If so do I have to > haul > the boat? > Thanks, Scott > Cal29 "Hatikvah" > >
