5 messages2008-10-15 18:19 through 2008-10-15 20:15 UTC
Yanmar 3GM30F--Changing Coolant
Travis2008-10-15 18:19
Hi all,
I have a '86 cal 33-2 bought two years ago. It has the "green stuff"
as the coolant. I don't know when it was last changed, but I need to do
this and have been dreading it. I've read that we need to use
the "orange stuff" (with low silicates) in these engines(true?) I've
bought it, but have read that it is not compatable with green. So, I
need to drain, flush, and refil with the orange. I do have a water
heater, and it looks to be above the engine. So, I've heard that it is
easy to get air in the system and cause overheating. Has anyone dealt
with this and do you have suggestions?
Travis
'86 33-2 "Vital"
RE: [Cal_Boats] Yanmar 3GM30F--Changing Coolant
Harleigh Ewell2008-10-15 18:34 UTC
I used to have an air-lock problem due to the high water heater in my 31. I
installed a small tank inside the cockpit locker higher than the water
heater, which solved the problem. The tank has fittings for a hose from the
water heater and a hose to the heat exchanger, along with its own "radiator"
cap. Google for "overflow tank." If that doesn't turn up something, let me
know, as I may still have the paperwork.
Harleigh Ewell
Cal 31
Of Travis
Sent: Wednesday, October 15, 2008 2:20 PM
Subject: [Cal_Boats] Yanmar 3GM30F--Changing Coolant
Hi all,
Travis
'86 33-2 "Vital"
darr lafon2008-10-15 19:08 UTC
Fear not!
This is not that hard. My engine has had the green stuff for years and
seems to do fine. I replace it every year.
On the starboard side of the engine is a drain for the heat exchanger where
all the green stuff can be drained, although this still leaves a lot in the
engine block. You can flush with serial washes of distilled water which is
fine while you are sitting at the dock.
When I fill it, I fill as far as it will go, then let it sit for a while so
the bubbles can come up, then fill some more. Finally I run the engine for
a few minutes and then stop, let it sit, then fill it again. The overflow
tank sounds like a great idea, but not sure where I would put it in the
engine compartment.
Not sure about the orange stuff. I have never used it and this is the first
I have ever heard about it. If I am doing something wrong, please, someone
let me know.
Hope this helps.
Darr LaFon
Of Harleigh Ewell
Sent: Wednesday, October 15, 2008 2:35 PM
Subject: RE: [Cal_Boats] Yanmar 3GM30F--Changing Coolant
Harleigh Ewell
Cal 31
Of Travis
Hi all,
Travis
'86 33-2 "Vital"
RE: [Cal_Boats] Yanmar 3GM30F--Coolant tank: Was Changing Coolant (Travis and Darr)
Harleigh Ewell2008-10-15 19:49 UTC
My tank is installed in the starboard cockpit locker and bolted as high as
possible on the side of the cockpit well. It is mounted so that the cap is
exposed when the locker is opened, so the coolant level can be seen and
coolant added if necessary..
Harleigh
Of darr lafon
Sent: Wednesday, October 15, 2008 3:08 PM
. . . The overflow tank sounds like a great idea, but not sure where I
would put it in the engine compartment. . . .
Of Harleigh Ewell
Harleigh Ewell
Cal 31
Of Travis
. . .. I do have a water
Re: [Cal_Boats] Yanmar 3GM30F--Coolant tank: Was Changing Coolant (Travis and Darr)
svadas2008-10-15 20:15 UTC
Yanmar recommends the orange stuff....
good luck
Sent: Wednesday, October 15, 2008 3:49 PM
Subject: RE: [Cal_Boats] Yanmar 3GM30F--Coolant tank: Was Changing Coolant (Travis and Darr)
My tank is installed in the starboard cockpit locker and bolted as high as possible on the side of the cockpit well. It is mounted so that the cap is exposed when the locker is opened, so the coolant level can be seen and coolant added if necessary..
Harleigh
-----Original Message-----
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of darr lafon
. . . The overflow tank sounds like a great idea, but not sure where I would put it in the engine compartment. . . .
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Harleigh Ewell
I used to have an air-lock problem due to the high water heater in my 31. I installed a small tank inside the cockpit locker higher than the water heater, which solved the problem. The tank has fittings for a hose from the water heater and a hose to the heat exchanger, along with its own "radiator" cap. Google for "overflow tank." If that doesn't turn up something, let me know, as I may still have the paperwork.
Harleigh Ewell
Cal 31
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Travis
Checked by AVG.
Version: 7.5.524 / Virus Database: 270.8.0/1725 - Release Date: 10/14/2008 9:25 PM
