Re: [Cal_Boats] Yanmar Fuel Pump
2 messages2008-10-20 18:41 UTCthrough 2008-10-20 18:53 UTC
Donald Dutton2008-10-20 18:41 UTC
Thanks! Darn. I'll order a new one -- won't be able to install it for two weeks. The manual didn't show any problems and, other than bleeding the system after installing, there don't seem to be any bumps. Anyone know of any, or is this replacement as clear as it sounds? Thanks again, Don Dutton, 1986 Cal 33-2, "Quantum Evolution" From: Wyatt Hendricks <wh… [at] avtechmed.com> To: Ca… [at] yahoogroups.com Sent: Monday, October 20, 2008 10:48:03 AM Subject: RE: [Cal_Boats] Yanmar Fuel Pump It is not rebuildable according to the Yanmar shop manual. Wyatt Hendricks ’75 CAL2-46 “Blythe Spirit” From:Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Donald Dutton Sent: Monday, October 20, 2008 1:13 PM To: Cal_Boats@yahoogrou ps.com Subject: [Cal_Boats] Yanmar Fuel Pump Joe DeMers and Group, The lift pump on my 3GM Yanmar is leaking fuel badly -- a steady stream. It appears to be leaking from the gasket that seals between the upper and lower halves of this pump. My SELOC Repair Manual only tells how to remove and install this pump and does not give instructions for re-building. Is this pump re-buildable and is there a kit that I can order or should I just order a new lift pump. Thanks in advance for your continued help in these engine matters! Don Dutton, 1986 Cal 33-2, "Quantum Evolution"
Joe DeMers2008-10-20 18:53 UTC
Yanmar upgraded the fuel connections to and from the pump. They originally used metal tubing, but vibration caused air to enter the system. The new arrangement uses hose. I would check for upgrades or service bulletins with your Yanmar supplier. You may need the engine serial number. Joe DeMers Sound Marine Diesel LLC www.soundmarinediesel.com ----- Original Message ----- From: Donald Dutton To: Ca… [at] yahoogroups.com Sent: Monday, October 20, 2008 2:41 PM Subject: Re: [Cal_Boats] Yanmar Fuel Pump Thanks! Darn. I'll order a new one -- won't be able to install it for two weeks. The manual didn't show any problems and, other than bleeding the system after installing, there don't seem to be any bumps. Anyone know of any, or is this replacement as clear as it sounds? Thanks again, Don Dutton, 1986 Cal 33-2, "Quantum Evolution" ----- Original Message ---- From: Wyatt Hendricks <wh… [at] avtechmed.com> To: Ca… [at] yahoogroups.com Sent: Monday, October 20, 2008 10:48:03 AM Subject: RE: [Cal_Boats] Yanmar Fuel Pump It is not rebuildable according to the Yanmar shop manual. Wyatt Hendricks ’75 CAL2-46 “Blythe Spirit” ------------------------------------------------------------------------------ From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Donald Dutton Sent: Monday, October 20, 2008 1:13 PM To: Cal_Boats@yahoogrou ps.com Subject: [Cal_Boats] Yanmar Fuel Pump Joe DeMers and Group, The lift pump on my 3GM Yanmar is leaking fuel badly -- a steady stream. It appears to be leaking from the gasket that seals between the upper and lower halves of this pump. My SELOC Repair Manual only tells how to remove and install this pump and does not give instructions for re-building. Is this pump re-buildable and is there a kit that I can order or should I just order a new lift pump. Thanks in advance for your continued help in these engine matters! Don Dutton, 1986 Cal 33-2, "Quantum Evolution" ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG. Version: 7.5.549 / Virus Database: 270.8.1/1732 - Release Date: 10/18/2008 6:01 PM
