8 messages2008-11-19 21:29 through 2008-11-21 02:21 UTC
Newbie Question on Cal 33- Loose propeller shaft strut.
bayboat192008-11-19 21:29
Hello,
I'm new to the Cal List and am considering purchasing a Cal 33 II. The survey showed some
issues, but one of the main ones was a prop strut and misaligned prop which was allowing
more water to get past the stuffing box then is normal. The prop strut could be moved a bit
by hand and would (according to the surveyor) cause vibrations and probably wear on the
cutlass bearing.
Does anyone on the list have experience with this sort of issue? Is this likely to be a costly
repair at a yard. (I am located in the general area of Annapolis)
TIA for any thoughts on this problem.
Richard
RE: [Cal_Boats] Newbie Question on Cal 33- Loose propeller shaft strut.
Husar, Charlie [USA]2008-11-19 21:52 UTC
Richard, I forwarded your note to a couple guys I know in town who are
in the biz. We'll see what they have to say about repair complexity.
Where in the Annapolis area are you?
Charlie Husar
Annapolis
Behalf Of bayboat19
Sent: Wednesday, November 19, 2008 4:30 PM
Subject: [Cal_Boats] Newbie Question on Cal 33- Loose propeller shaft
strut.
Hello,
survey showed some issues, but one of the main ones was a prop strut and
misaligned prop which was allowing more water to get past the stuffing
box then is normal. The prop strut could be moved a bit by hand and
the cutlass bearing.
this likely to be a costly repair at a yard. (I am located in the
Richard
Yahoo! Groups Links
Re: [Cal_Boats] Newbie Question on Cal 33- Loose propeller shaft strut.
pw… [at] aol.com2008-11-19 22:07 UTC
Richard -
I am Dan Faulkner's friend who referred you to that other Cal 33.? I didn't realize you were in the Annapolis area which is where I am as well.? I had a similar issue on my old CS 30.? I ground away the fairing compound and was able to put about 1.5 to 2 turns on the 4 bolts holding it to the hull. I went ahead and removed them one at a time and put?Loctite on them and?re-faired the strut.?
I can't remember the sequence of events but I also replaced the cutlass bearing, engine mounts (big $$) and stern tube.? I think I did that the season after tightening the strut.
Paul West
Cal 39 Adventure Kwest
Sent: Wed, 19 Nov 2008 4:52 pm
Subject: RE: [Cal_Boats] Newbie Question on Cal 33- Loose propeller shaft strut.
Charlie Husar
Annapolis
Behalf Of bayboat19
strut.
Hello,
Richard
Yahoo! Groups Links
Randy Alcorn2008-11-20 03:21 UTC
Richard,
welcome to our site. The Cal 33 is a strong boat and sails very well.
I just replaced my strut and prop on my 1973 Cal 2-29. I do not know what your mechanical abilities are, however, it is a very easy job. We syaryed with the boay in the water then pulled it when we got the parts back. The boat had to be back in the water to align the the drive train.
Randy
CAL 2-29
Channel Island Ca
bayboat19 wrote:
> Hello,
> cutlass bearing.
> Richard
Re: Newbie Question on Cal 33- Loose propeller shaft strut.
bayboat192008-11-20 12:34
Hi Charlie,
I live in Fairfax,VA, about an hour from the Bay, but the boat will be kept on the Bay, most
likely off of West River.
Thank you very much for your help on this question.
Where are you on the Bay?
Richard
--- In Ca… [at] yahoogroups.com, pwestla@... wrote:
> Richard -
> Paul West
> -----Original Message-----
> From: Husar, Charlie [USA] <husar_charlie@...>
> Cheers
> Charlie Husar
> Annapolis
> Behalf Of bayboat19
> strut.
> Hello,
> Richard
> Yahoo! Groups Links
Mark Alan Stahnke (MAS Consulting)2008-11-20 22:40 UTC
Randy where did you buy your new strut? and did you need it to order the replacement?
Mark
To: ba… [at] yahoo.com
Cc: Ca… [at] yahoogroups.com
Sent: Wednesday, November 19, 2008 7:21 PM
Richard,
Randy
CAL 2-29
Channel Island Ca
bayboat19 wrote:
> Hello,
> cutlass bearing.
> Richard
__________ Information from ESET NOD32 Antivirus, version of virus signature database 3627 (20081120) __________
http://www.eset.com
RE: [Cal_Boats] Newbie Question on Cal 33-(Randy)
david dobbs2008-11-20 23:48 UTC
Guys,
Good Old Boat magazine did a how to do it replacement of a cutless bearing recently. It was very detailed, lots of pix. Check their website.
Regards,
David Dobbs, Cal 29 411
To: "ba… [at] yahoo.com" <ba… [at] yahoo.com>
Cc: "Ca… [at] yahoogroups.com" <Ca… [at] yahoogroups.com>
Date: Wednesday, November 19, 2008, 9:21 PM
Richard,
Randy
CAL 2-29
Channel Island Ca
bayboat19 wrote:
> Hello,
> cutlass bearing.
> Richard
Randy Alcorn2008-11-21 02:21 UTC
Hi Mark,
I used Martec in Long Beach,, http://www.martec-props.com/
I figured it lasted this long maybe it will last another 40 years.
I had to send in my strut for them to pour a new one. it was a little beefier and everything lined up.
Randy
CAL 2-29
Out Patient
Channel Islands Ca
--- On Thu, 11/20/08, Mark Alan Stahnke (MAS Consulting) <ma… [at] cox.net> wrote:
Subject: Re: [Cal_Boats] Newbie Question on Cal 33- Loose propeller shaft strut.
Date: Thursday, November 20, 2008, 4:40 PM
Mark
To: bayboat19@yahoo. com
Cc: Cal_Boats@yahoogrou ps.com
Richard,
Randy
CAL 2-29
Channel Island Ca
bayboat19 wrote:
> Hello,
> cutlass bearing.
> Richard
http://www.eset. com
