Continuing Transmission Woes...
2 messages2008-12-16 14:15 UTCthrough 2008-12-17 15:02 UTC
John2008-12-16 14:15 UTC
Hi All, I finally got the MSB Transmission out of my Cal 31 (Volvo Penta MD7A) and believe that the problem is a gear with the fiber insert worn away. At any rate, I am now muddling through the disassembly instructions and can't seem to remove the flange up front that hooks up with the engine, even with a gear puller (it does not budge). There appears to be a key in the flange, but no readily apparent way to remove. Of course, the instructions merely say "Remove the flange with the help of a puller". At any rate, a photo is posted to the group site as "MSB Flange.jpg". If anybody has any advice or suggestions, they would be much appreciated. Thanks, John Stacklyn Cal 31 #33 "Sol Survivor" Shell Point, FL
Re: [Cal_Boats] Continuing Transmission Woes...
Joe DeMers2008-12-17 15:02 UTC
Continuing Transmission Woes...Use a bigger / stronger gear puller, 3 legged type. Joe DeMers Sound Marine Diesel LLC www.soundmarinediesel.com ----- Original Message ----- From: John To: Ca… [at] yahoogroups.com Sent: Tuesday, December 16, 2008 9:15 AM Subject: [Cal_Boats] Continuing Transmission Woes... Hi All, I finally got the MSB Transmission out of my Cal 31 (Volvo Penta MD7A) and believe that the problem is a gear with the fiber insert worn away. At any rate, I am now muddling through the disassembly instructions and can't seem to remove the flange up front that hooks up with the engine, even with a gear puller (it does not budge). There appears to be a key in the flange, but no readily apparent way to remove. Of course, the instructions merely say "Remove the flange with the help of a puller". At any rate, a photo is posted to the group site as "MSB Flange.jpg". If anybody has any advice or suggestions, they would be much appreciated. Thanks, John Stacklyn Cal 31 #33 "Sol Survivor" Shell Point, FL ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG. Version: 7.5.552 / Virus Database: 270.9.18/1849 - Release Date: 12/15/2008 9:01 AM
