16 messages2008-10-20 19:04 UTCthrough 2008-12-28 19:15 UTC
Re: [Cal_Boats] Yanmar Fuel Pump (Joe)
Donald Dutton2008-10-20 19:04 UTC
Thank you for the reply. I found a pump at Golden State Diesel in Alameda just a half mile from my marina! Beats the 6 hour round trip to LA that I had to make for the seawater pump last spring. Since it is under a hundred dollars to replace that seems to be the best option.
It is very re-assuring to have your replies for us "do-it-yourselfers" who have some experience, but know the traps that ignorance can lead us to!
Sent: Monday, October 20, 2008 11:05:05 AM
Subject: Re: [Cal_Boats] Yanmar Fuel Pump
Your pump is rebuildable, however, I suggest you
replace the entire pump. That is also Yanmar's recommendation.
Joe DeMers
Sound Marine Diesel LLC
www.soundmarinedies el.com
Sent: Monday, October 20, 2008 1:48 PM
Subject: RE: [Cal_Boats] Yanmar Fuel Pump
It is not rebuildable according to the Yanmar shop manual.
Wyatt Hendricks
’75 CAL2-46
“Blythe Spirit”
From:Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Donald Dutton
Sent: Monday, October 20, 2008 1:13 PM
Subject: [Cal_Boats] Yanmar Fuel Pump
Joe DeMers and Group,
The lift pump on my 3GM Yanmar is leaking fuel badly -- a steady stream. It appears to be leaking from the gasket that seals between the upper and lower halves of this pump. My SELOC Repair Manual only tells how to remove and install this pump and does not give instructions for re-building. Is this pump re-buildable and is there a kit that I can order or should I just order a new lift pump.
Thanks in advance for your continued help in these engine matters!
Checked by AVG.
Version: 7.5.549 / Virus Database: 270.8.1/1732 - Release Date: 10/18/2008 6:01 PM
Donald Dutton2008-10-20 19:19 UTC
Thanks again for the updates. My engine has the hose attachments and the new pump that I am getting is for hose attachments and she is including new gaskets and new crush washers for the hoses. The oil change idea hadn't crossed my mind, but since the pump is powered off the cam than any leakage inside would go into the oil sump and dilute the engine oil. I think I will replace both the pre-filter, the engine fuel filter, and the oil and filter all at the same time. Since I only know the Fram filter number and we had the discussion earlier about that idea, I was wondering if you could recommend a specific filter to replace the oil filter. It is a 1986 Yanmar 3GMF and the Fram filter number is PH3593A. I will buy the Yanmar fuel filter for the secondary filter and the Racor filter for the primary fuel filter.
Sent: Monday, October 20, 2008 11:55:02 AM
You may want to perform an oil and filter change,
as it is possible that the engine lube oil has been diluted with diesel, fuel,
due to the leaking pump.
Joe DeMers
Checked by AVG.
Joe DeMers2008-10-20 20:25 UTC
Don't use Fram filters on any engine you care about. Use real Yanmar or Wix filters.
Joe DeMers
www.soundmarinediesel.com
Sent: Monday, October 20, 2008 3:19 PM
Subject: Re: [Cal_Boats] Yanmar Fuel Pump (Joe)
You may want to perform an oil and filter change, as it is possible that the engine lube oil has been diluted with diesel, fuel, due to the leaking pump.
Joe DeMers
Checked by AVG.
Checked by AVG.
Re: [Cal_Boats] Yanmar 3GM30F Oil Filter Part #
tr… [at] sbcglobal.net2008-10-21 03:05 UTC
Don,
I have an '86 3GM30F engine as well, and just ordered a genuine Yanmar oil filter. I am looking at it now, and the part # on the filter is: 119305-35151
Travis
Sent: Monday, October 20, 2008 2:19 PM
Joe DeMers
Checked by AVG.
RE: [Cal_Boats] Yanmar 3GM30F Oil Filter Part #
john raxter2008-10-21 22:06 UTC
It seems like yanmar changes the part number annually. The current filter
seems too small, IMHO! I doubt it holds a pint of oil in the filter.
I guess this means they need to be changed more often. Does the Yanmar have
a relief valve in their oil system to by-pass the filter when it gets
clogged? I know the automotive system had a similar by-pass system. Would a
pressure gauge in the oil line system warn of possible problems?
Just thinking out loud,
John
Of tr… [at] sbcglobal.net
Sent: Monday, October 20, 2008 11:06 PM
Subject: Re: [Cal_Boats] Yanmar 3GM30F Oil Filter Part #
Don,
119305-35151
Travis
From: Donald Dutton <mailto:dn… [at] sbcglobal.net>
filter.
Joe DeMers
www.soundmarinedies <http://www.soundmarinediesel.com> el.com
To: Cal_Boats@yahoogrou ps.com <mailto:Ca… [at] yahoogroups.com>
a new lift pump.
Checked by AVG.
6:01 PM
RE: [Cal_Boats]Diesel Issues
david dobbs2008-10-22 03:50 UTC
Guys,
I hear you guys talking about filters, and bleeding and the list goes on. Tell me again about how a diesel is an easier engine to maintain. I have an A4 and I change the impeller every other year, change the spark plugs when they get a little rusty, and we're good to go. It's a simple, flathead 4 cylinder engine that will run almost forever with minimal care. In all fairness I must say that I replaced the fuel pump and carb last year, but that's required maintenance, it's a 1972 engine. I fully expect it to run another 20 years or so, and I never bleed anything.
Regards,
David Dobbs
Cal29 411
--- On Tue, 10/21/08, john raxter <jr… [at] triad.rr.com> wrote:
> From: john raxter <jr… [at] triad.rr.com>
> Subject: RE: [Cal_Boats] Yanmar 3GM30F Oil Filter Part #
> Date: Tuesday, October 21, 2008, 5:06 PM
> current filter
> the filter.
> when it gets
> problems?
> John
> Don,
> genuine Yanmar oil
> filter is:
> 119305-35151
> Travis
> attachments and the
> is including new
> change idea hadn't
> than any leakage
> oil. I think I will
> the oil and filter
> number and we had
> you could
> is a 1986 Yanmar
> Yanmar fuel
> the primary fuel
> filter.
> From: Joe DeMers <je… [at] mindspring.com>
> possible that the
> the leaking pump.
> Joe DeMers
> www.soundmarinedies
> steady stream. It
> the upper and lower
> to remove and
> should I just order
> a new lift pump.
> matters!
> _____
> Checked by AVG.
> Date: 10/18/2008
> 6:01 PM
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Re: [Cal_Boats]Diesel Issues
Chris Campbell2008-10-22 13:34 UTC
david dobbs wrote:
> Guys,
> minimal care.
Gee David, you didn't even get into the subject of the invasive
diesel-fuel smell that persists forever after you've done all that
filter-changing and bleeding and swearing at the @#$%&**!!! thing.
I'll confess that diesels have their place and advantages. We have a
big Detroit Diesel in the schooner, and since that boat runs on a
schedule in the summer ("gotta be in Wisconsin by Friday") the engine
gets lots of use. It has pushed that boat without fail for a huge
number of hours in the last 18 years. Diesels do extract more energy
from their fuel. So there are things to be said.
But most of our boats use the engine to get from the mooring spot to the
sailing spot, and use their sails for primary propulsion. For those of
us who mostly sail our boats, a good gas engine actually serves well.
My boats use outboards, devices that used to provoke love-hate
relationships until I started reading about diesel woes and the joys of
hanging upside-down in a cockpit locker to reach an oil drain plug.
Outboards do a good enough job of getting me to the open water so I can
sail, and getting me home again on those days when the wind drops to
zero.
Gas engines do deprive us of those world-cruising daydreams, the
reassuring notion in the back of our heads during bad days at work that
yes, we could step aboard our well-found vessels and set sail for
anywhere in the world. For that, you'd probably chose a diesel. Then
you could charge the batteries and do all that stuff. I've always
figured that it's the fantasy element, the "I could sail around the
world" dream, that prompts many boat-equipment buying decisions.
So I've learned to be happy with my outboards. The 1967 Evinrude 6 hp
on the Cal 20 actually ran properly all summer. Maybe we've just become
better acquainted and tolerant of each other's eccentricities. The 1994
Merc 8 hp on my other boat purred happily all summer with a new
high-thrust workboat prop thanks to a comment from a list participant.
And there's no diesel smell to put up with (or is it up with which to put?).
Wyatt Hendricks2008-10-22 15:54 UTC
Here in St. Pete in the last 2 weeks we've had 3 fires on boats.
1. Almost brand new SeaRay 30 something gasoline power, total loss
in minutes.
2. 20 year old Irwin 40 something, diesel power, electrical fire
started at cockpit electric winch, $2,000 loss.
3. Older wooden harbor launch gas powered, presumed to be a total
loss.
Each fire occurred in the slip. If you were out for a day sail which
type of fire accelerant would you prefer to be sharing your vessel with?
Wyatt
CAL2-46
"Blythe Spirit"
Behalf Of Chris Campbell
Sent: Wednesday, October 22, 2008 9:35 AM
Subject: Re: [Cal_Boats]Diesel Issues
david dobbs wrote:
Guys,
zero.
put?).
Harleigh Ewell2008-10-22 16:11 UTC
X2. Diesel fuel is extremely hard to ignite, even with an open flame. The
fuel needs to heated up before it will burn.
Harleigh Ewell
Cal 31
Of Wyatt Hendricks
Sent: Wednesday, October 22, 2008 11:55 AM
Subject: RE: [Cal_Boats]Diesel Issues
1. Almost brand new SeaRay 30 something gasoline power, total loss in
minutes.
3. Older wooden harbor launch gas powered, presumed to be a total loss.
Each fire occurred in the slip. If you were out for a day sail which type of
Wyatt
CAL2-46
"Blythe Spirit"
Of Chris Campbell
david dobbs wrote:
Guys,
Gee David, you didn't even get into the subject of the invasive diesel-fuel
smell that persists forever after you've done all that filter-changing and
I'll confess that diesels have their place and advantages. We have a big
Detroit Diesel in the schooner, and since that boat runs on a schedule in
the summer ("gotta be in Wisconsin by Friday") the engine gets lots of use.
It has pushed that boat without fail for a huge number of hours in the last
18 years. Diesels do extract more energy from their fuel. So there are
things to be said.
sailing spot, and use their sails for primary propulsion. For those of us
who mostly sail our boats, a good gas engine actually serves well. My boats
use outboards, devices that used to provoke love-hate relationships until I
started reading about diesel woes and the joys of hanging upside-down in a
cockpit locker to reach an oil drain plug. Outboards do a good enough job
of getting me to the open water so I can sail, and getting me home again on
those days when the wind drops to zero.
Gas engines do deprive us of those world-cruising daydreams, the reassuring
notion in the back of our heads during bad days at work that yes, we could
step aboard our well-found vessels and set sail for anywhere in the world.
For that, you'd probably chose a diesel. Then you could charge the
batteries and do all that stuff. I've always figured that it's the fantasy
element, the "I could sail around the world" dream, that prompts many
So I've learned to be happy with my outboards. The 1967 Evinrude 6 hp on
the Cal 20 actually ran properly all summer. Maybe we've just become better
acquainted and tolerant of each other's eccentricities. The 1994 Merc 8 hp
on my other boat purred happily all summer with a new high-thrust workboat
prop thanks to a comment from a list participant. And there's no diesel
Chris Campbell2008-10-22 16:24 UTC
Wyatt Hendricks wrote:
> 1.
Wooden oars, preferably.
Re: [Cal_Boats]Diesel Issues, Outboards
david dobbs2008-10-26 03:14 UTC
Chris,
On my previous boat, an O'Day 22, I had 3 outboards, a British Seagull, an Evenrude, and a Merc, and I hated them all. They would fail me when I needed them most. When it didn't matter they would purr like a lapcat. My club owns a Boston Whaler with a big Yamaha outboard, and I drive sometimes, and so far it has not found out about my outboard doubt, but ...... But I love my A4!!
Regards,
David Dobbs
--- On Wed, 10/22/08, Chris Campbell <cl… [at] charterinternet.com> wrote:
> From: Chris Campbell <cl… [at] charterinternet.com>
> Date: Wednesday, October 22, 2008, 8:34 AM
> david dobbs wrote:
> > Guys,
> and the list goes
> engine to maintain.
> year, change the
> almost forever with
> > minimal care.
> invasive
> done all that
> @#$%&**!!! thing.
> runs on a
> Friday") the engine
> a huge
> more energy
> mooring spot to the
> For those of
> serves well.
> love-hate
> the joys of
> drain plug.
> water so I can
> drops to
> zero.
> daydreams, the
> at work that
> sail for
> a diesel. Then
> I've always
> decisions.
> 1967 Evinrude 6 hp
> we've just become
> new
> participant.
> Chris Campbell
Outboards
Gerald Sobel2008-10-26 04:24 UTC
I have a Suzuki 4 right now, it's been totally reliable except for, before i knew what to do when it refused to start, it was because I'd flooded it; I needed to open the choke and throttle wide and pull the starter cord till it caught. Yessss!!!!
One thing that helps very much to keep you out of trouble, is to run the outboard with the tank disconnected so it empties the carburetor. My Evinrude 6 would have to go to the mechanic once a year for gummed up carb repair.
I finally blew my Evinrude in a rush to get to the starting line, I suspect it was insufficient oil in the gas, but the mechanic didn't think so, he said the motor's bearing siezed. All I know is I gave the gas a quick shot of oil, a wild guess, while in a hurry, and I don't think it had the recommended 50:1 ratio. Maybe less than 100:1, and then I was running the engine wide open.
Of course, I always rinse the motor in fresh water by running it with a vynil flush bag attached to a dock hose, while I run the carb dry.
The other dumb thing I've done is run the motor without servicing it for years, until the water pump impeller thru a vane which blocked the water intake, causing the engine to overheat and die. Thankfully, before it did any damage to the engine. Rebuilding/replacing the impeller is no big deal except a little tricky to hook the bottom and top up with the gear shifter in the right position, if you forget to check it still has F-N-R. I also don't recommend waiting five years to get around to finding that old grease gun, loading it with marine grease, and shooting up the old xerks fittings, like I did.
Let's hear it for good old two cycle outboards, lightweight, mostly reliable, and...yes, lightweight, especially good if you're still fanatic and taking the motor off the transom to get that last little bit of speed. And let's hear it for our slick sailboat hulls, easily driven with very little HP and not much throttle.
--- On Sat, 10/25/08, david dobbs <tm… [at] yahoo.com> wrote:
Subject: Re: [Cal_Boats]Diesel Issues, Outboards
Date: Saturday, October 25, 2008, 8:14 PM
Chris,
Regards,
David Dobbs
--- On Wed, 10/22/08, Chris Campbell <clcampbell@charteri nternet.com> wrote:
> From: Chris Campbell <clcampbell@charteri nternet.com>
> david dobbs wrote:
> > Guys,
> and the list goes
> engine to maintain.
> year, change the
> almost forever with
> > minimal care.
> invasive
> done all that
> @#$%&**!!! thing.
> runs on a
> Friday") the engine
> a huge
> more energy
> mooring spot to the
> For those of
> serves well.
> love-hate
> the joys of
> drain plug.
> water so I can
> drops to
> zero.
> daydreams, the
> at work that
> sail for
> a diesel. Then
> I've always
> decisions.
> 1967 Evinrude 6 hp
> we've just become
> new
> participant.
> Chris Campbell
Re: [Cal_Boats] Outboards
Chris Campbell2008-10-27 14:31 UTC
> up carb repair.
Good advice! During the sailing season, I start my outboards at least
every two weeks and let them run just a bit, to get some fresh fuel in
the carburetor. And then when I haul out, I disconnect the fuel line
and run the gas out (it takes longer than you would expect).
Right on, both with regard to the useful little outboards and the
wonders of an efficient hull form. In Bay City, MI, where one of my
boats lives, a local guy has built a 40 foot displacement hull
powerboat, one that can be driven easily by a low-hp engine. It was
written up in the Gougeon Bros.' publication, /Epoxyworks/, and I have
seen it gliding along, quietly and inexpensively, while the high-hp
planing powerboats roar by at multiple gallons per mile. The builder
wanted to be able to cruise at low fuel cost, something he wasn't able
to do in his former powerboat with a planing hull. As I recall, he used
a hull design from the '20s, updated a bit.
Re: [Cal_Boats] Outboards(Chris)
Gerald Sobel2008-10-28 02:06 UTC
Chris,
I run my carburetor dry every time I use the outboard. You never know how long it will be between times you use the motor. Sometimes, tho I sail the boat once or twice a week, I may not start and run it for over a month. Our last series featured a start and finish inside the marina, so most of us were sailing to the start and sailing back to our docks.
I don't know how long it will take for the gas in the carb to evaporate and get gummy, and I don't know whether the 10% ethanol gas we all use now is making the situation better or worse. All I can say is I've yet to need to have my Suzuki professionally serviced, and I've had it seven years. The Evinrude needed to see the doctor at least twice a year.
On the otherhand, I still have my dad's 1960 "Golden Aniversery" 5.5 HP Fisherman, which I'd be using except it's a short shaft. It was also totally trouble free. The Evenrude 6 long shaft I'd bought from the ourboard mechanic had sat for well over ten years unused on the back of a Catalina Capri; apparently when the former owner was told what the bill would be for overhauling the motor, he abandoned it with the mechanic.
This next year I hope I'll do more fishing and cruising. But I have to admit, entering races, and pre-paying for race series kinda forces you to use your boat. And, maybe I'm an adreniline junkie. If sailing is fun, racing is fun times ten.
Subject: Re: [Cal_Boats] Outboards
Date: Monday, October 27, 2008, 7:31 AM
up carb repair.
written up in the Gougeon Bros.' publication, Epoxyworks, and I
have seen it gliding along, quietly and inexpensively, while the
high-hp planing powerboats roar by at multiple gallons per mile. The
builder wanted to be able to cruise at low fuel cost, something he
wasn't able to do in his former powerboat with a planing hull. As I
recall, he used a hull design from the '20s, updated a bit.
Chris Campbell2008-10-28 13:27 UTC
Gerald Sobel wrote:
> Chris,
About 20 years ago, my brother was visiting and made an idle inquiry,
"do you know how much it costs you per trip to own this boat?" Well, I
did a quick mental calculation and the answer was so unfavorable that I
pretended I didn't know.
But I also realized there are two ways to alter the cost per sailing
event: pay less or sail more. The marina doesn't bargain on dockage,
hauling, or winter storage, so I resolved to sail more. As a result,
the outboard doesn't sit idle too long.
Me too, so that's why I started running the motor when I got back onto
my mooring, just to keep the gas moving a bit. The gas tank sits in the
cockpit, in the sun, so I made a cover for it from foil-faced foam
insulation to keep it cool. That reduces the losses of the most
volatile components of the gasoline through the tank vent.
Everything I've read says "worse."
Chris
> Checked by AVG.
> Version: 7.5.549 / Virus Database: 270.8.4/1751 - Release Date: 10/27/2008 10:44 PM
RE: [Cal_Boats] Outboards(Chris)
Scott Sauvageot2008-12-28 19:15 UTC
Jerry,
I have an Evenrude 6hp 2 stroke longshaft that I use to push my Cal 25.
With the exception of a tune up and carb job when I first purchased the boat
(engine had been stored aboard for 5 years and never used) I've only had it
checked and tuned once every 3 years. It's basically a bulletproof motor.
I guess I'm lucky that I take the boat out sailing probably 30 weekends per
year or more, so the engine sees about 30 minutes of use every week or so. I
also add fuel stabilizer with every fill-up when I add the oil.
BTW, I have to agree with your comment that racing is fun x 10. I also
believe that I've learned a great deal from racing that I would never have
picked up just cruising around the bay.
Have a Happy New Year!
Scott Sauvageot
Cal 25 #1651 Indefatigable
Annapolis, MD
Of Gerald Sobel
Sent: Monday, October 27, 2008 10:06 PM
Subject: Re: [Cal_Boats] Outboards(Chris)
Chris,
repair.
Good advice! During the sailing season, I start my outboards at least every
two weeks and let them run just a bit, to get some fresh fuel in the
carburetor. And then when I haul out, I disconnect the fuel line and run
Right on, both with regard to the useful little outboards and the wonders of
an efficient hull form. In Bay City, MI, where one of my boats lives, a
local guy has built a 40 foot displacement hull powerboat, one that can be
driven easily by a low-hp engine. It was written up in the Gougeon Bros.'
publication, Epoxyworks, and I have seen it gliding along, quietly and
inexpensively, while the high-hp planing powerboats roar by at multiple
gallons per mile. The builder wanted to be able to cruise at low fuel cost,
something he wasn't able to do in his former powerboat with a planing hull.
As I recall, he used a hull design from the '20s, updated a bit.
