6 messages2008-12-28 14:23 UTCthrough 2008-12-30 04:52 UTC
The Best Stuff for...
Husar, Charlie [USA]2008-12-28 14:23 UTC
Hi, All. Was looking at the Sunday paper. Everybody is doing "Best of"
and "Worst of" 2008 (emphasis on the latter these days). Got a thought
that such a pair of lists would be a good thing for our group since we
do many repair/rehab jobs on our boats. Lately, we had items on
interior woods, oil filters, and the like. Not that I want a flood of
stuff, but over time I (as a volunteer) or we could compile the lists
for future reference. Would be like the Guinness Book in that anything
for the boat is fair game. Would probably concentrate on "Bests" since
trashing things is not really fun (unless the lack of quality is truly
notable), and would be too much like other places on the Web. Figure I
would ask periodic questions on items, and pull off others that come up
in group discussions.
That said, the following statement is germane:
Two CAL 25 owners is a discussion; three CAL 25 owners is an argument;
four CAL 25 owners is a brawl. We never agree on anything. I'm sure
similar things would occur here.
Rambling further (please stick with me), I am rebuilding my (other) CAL
25 in scenic Deale, MD. Replacing some interior wood facings (using
Okume ply), redoing the bottom after a "chippy" soda blasting job left a
lot of dings (using primarily 3M premium filler), and refilling all deck
hardware holes (Maas epoxy), reseating all deck wood coamings (3M 4200
UV fast), repainting non-skid areas (no sand primer and Interlux one
part with grains) and other deck areas, among others. You get the idea.
NOW FINALLY FOR MY REAL QUESTION!! Ta-da. After I fill the deck holes,
there is always a negative meniscus (indent) because the liquid soaks
in. Many, Many holes due to different hardware layouts over 35 years.
I have tried different compositions for the final fill and sand of the
holes prior to painting (typically West or other epoxy with low density
thickener). Invariably after a while, no matter how smooth the surface
job was prior to painting, the outline of the holes reappears through
the paint. Does the fill shrink a bit?
What is the "best" stuff to use for the surface fill-in of the holes in
the deck? Needs to be sandable, and to smooth well, and not end up
showing the hole outlines.
Sure was a long way to ask a short question. 65 degrees today! Need to
get off to the boat yard before the rain starts this PM.
Annapolis
toe rails
r good2008-12-28 17:48 UTC
speaking of toe rails>>>>>>>>>>
thinking of removing the wooden toe rails on the CC36 to chase a leak or two. At the risk of committiong a travesty, anyone have knowledge of replacing the wood with more modern toe rail? suggestions? castigations?
To: Ca… [at] yahoogroups.comFrom: hu… [at] bah.comDate: Sun, 28 Dec 2008 09:23:05 -0500Subject: [Cal_Boats] The Best Stuff for...
Hi, All. Was looking at the Sunday paper. Everybody is doing "Best of"and "Worst of" 2008 (emphasis on the latter these days). Got a thoughtthat such a pair of lists would be a good thing for our group since wedo many repair/rehab jobs on our boats. Lately, we had items oninterior woods, oil filters, and the like. Not that I want a flood ofstuff, but over time I (as a volunteer) or we could compile the listsfor future reference. Would be like the Guinness Book in that anythingfor the boat is fair game. Would probably concentrate on "Bests" sincetrashing things is not really fun (unless the lack of quality is trulynotable), and would be too much like other places on the Web. Figure Iwould ask periodic questions on items, and pull off others that come upin group discussions. That said, the following statement is germane:Two CAL 25 owners is a discussion; three CAL 25 owners is an argument;four CAL 25 owners is a brawl. We never agree on anything. I'm suresimilar things would occur here.Rambling further (please stick with me), I am rebuilding my (other) CAL25 in scenic Deale, MD. Replacing some interior wood facings (usingOkume ply), redoing the bottom after a "chippy" soda blasting job left alot of dings (using primarily 3M premium filler), and refilling all deckhardware holes (Maas epoxy), reseating all deck wood coamings (3M 4200UV fast), repainting non-skid areas (no sand primer and Interlux onepart with grains) and other deck areas, among others. You get the idea.NOW FINALLY FOR MY REAL QUESTION!! Ta-da. After I fill the deck holes,there is always a negative meniscus (indent) because the liquid soaksin. Many, Many holes due to different hardware layouts over 35 years.I have tried different compositions for the final fill and sand of theholes prior to painting (typically West or other epoxy with low densitythickener). Invariably after a while, no matter how smooth the surfacejob was prior to painting, the outline of the holes reappears throughthe paint. Does the fill shrink a bit? What is the "best" stuff to use for the surface fill-in of the holes inthe deck? Needs to be sandable, and to smooth well, and not end upshowing the hole outlines.Sure was a long way to ask a short question. 65 degrees today! Need toget off to the boat yard before the rain starts this PM.CheersCharlieAnnapolis
Re: The Best Stuff for...
xhpspd2008-12-29 15:51
My L-36 is wood so take my advice with a large grain of salt. I use
Formula 27 for the final fills and don't have the problem you are
talking about. If I had the problem you have and a fiberglass boat, I
would counter sink the fiberglass prior to filling so that there would
be more surface area for the filler to stick to. Obviously you want
to sand the dimple first so that the wax stuff goes away and there is
a good surface for the final filler to stick to.
Hope this helps,
--- In Ca… [at] yahoogroups.com, "Husar, Charlie [USA]"
of"
thought
we
lists
anything
since
truly
Figure I
up
argument;
sure
CAL
left a
deck
4200
idea.
holes,
soaks
years.
the
density
surface
through
in
Need to
> Cheers
> Charlie
> Annapolis
RE: [Cal_Boats] Re: The Best Stuff for...
Husar, Charlie [USA]2008-12-29 17:14 UTC
Thanks, Allen. I do countersink and sand and chemically treat prior to
surface filling. It takes a while for the effect to show up. That is
why I suspect shrinkage. Formula 27, eh? Can't hurt to try.
Behalf Of xhpspd
Sent: Monday, December 29, 2008 10:51 AM
Subject: [Cal_Boats] Re: The Best Stuff for...
be more surface area for the filler to stick to. Obviously you want to
sand the dimple first so that the wax stuff goes away and there is a
Hope this helps,
of"
thought
we
lists
anything
since
truly
Figure I
up
argument;
sure
CAL
left a
deck
4200
idea.
holes,
soaks
years.
the
density
surface
through
in
Need to
> Cheers
> Charlie
> Annapolis
Yahoo! Groups Links
Re: [Cal_Boats] The Best Stuff for...
Chris Campbell2008-12-29 18:11 UTC
The Gougeon Brothers' technical folks are always good at answering
questions like this, especially since most of them are active and
creative users of their products. Give 'em a call or e-mail and see
what they say.
Michael McElhaney2008-12-30 04:52 UTC
Charlie,
I've been working on filling holes on boats for a bit now and have
found that the West Systems works well for me. I use the low density
filler (407) and make sure I do all the surface prep. Sand, clean,
acetone wash, fresh water rinse and dry thoroughly. The cleaner the
better. Shortcuts have worked, but not with the best results. If you
chamfer the hole then it is harder for the filler to pull away from the
sides. If you don't chamfer the edges the filler will pull away from the
sides and leave the hairline crack around the hole. Someone else
mentioned using a countersink bit and that works. Also, if you overfill
a little bit, it will alleviate the issue of leaving a dimple in the
middle. Just sand smooth the excess.
If you have a hole in your antiskid, that's a different story... The gel
coat and antiskid are polyester resin and gel coat doesn't stick to
epoxy properly (if you happened to fill the hole with epoxy). The best
thing to do is to fill the hole with a mixture of gel coat and colloidal
silica thickened to peanut butter consistency after chamfering, sanding,
cleaning etc. To duplicate your anti skid pattern, get a can of mold
release spray, spray on a section of your anti skid and then smear a 1
by 1 area with silicone RTV. When this cures, peel it up and you will
have a piece of antiskid pattern. Take a needle and poke through the
indentations. This is to allow air to escape. Spray with mold release,
align it (!) and press it over your gel coat application before it
cures. When it is cured, the pattern piece will peel right off and you
should have an uninterrupted antiskid pattern. The silicone piece will
be reusable.
Hope this helps.
Mike
> Cheers
> Charlie
> Annapolis
> Messages in this topic
> <http://groups.yahoo.com/group/Cal_Boats/message/13782;_ylc=X3oDMTM3Mm9oMDY0BF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRtc2dJZAMxMzc4MgRzZWMDZnRyBHNsawN2dHBjBHN0aW1lAzEyMzA0NzQxOTAEdHBjSWQDMTM3ODI->
> (1) Reply (via web post)
> <http://groups.yahoo.com/group/Cal_Boats/post;_ylc=X3oDMTJycG5wNmVtBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRtc2dJZAMxMzc4MgRzZWMDZnRyBHNsawNycGx5BHN0aW1lAzEyMzA0NzQxOTA-?act=reply&messageNum=13782>
> | Start a new topic
> <http://groups.yahoo.com/group/Cal_Boats/post;_ylc=X3oDMTJmYmVzcGdzBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNudHBjBHN0aW1lAzEyMzA0NzQxOTA->
> Messages
> <http://groups.yahoo.com/group/Cal_Boats/messages;_ylc=X3oDMTJmMGM5dnZvBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNtc2dzBHN0aW1lAzEyMzA0NzQxOTA->
> | Files
> <http://groups.yahoo.com/group/Cal_Boats/files;_ylc=X3oDMTJnNjYzYWU3BF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNmaWxlcwRzdGltZQMxMjMwNDc0MTkw>
> | Photos
> <http://groups.yahoo.com/group/Cal_Boats/photos;_ylc=X3oDMTJmbW1zaWZsBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNwaG90BHN0aW1lAzEyMzA0NzQxOTA->
> | Links
> <http://groups.yahoo.com/group/Cal_Boats/links;_ylc=X3oDMTJnaWswOW1uBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNsaW5rcwRzdGltZQMxMjMwNDc0MTkw>
> | Database
> <http://groups.yahoo.com/group/Cal_Boats/database;_ylc=X3oDMTJkNTNwczR1BF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNkYgRzdGltZQMxMjMwNDc0MTkw>
> | Polls
> <http://groups.yahoo.com/group/Cal_Boats/polls;_ylc=X3oDMTJnNGFxcmN1BF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNwb2xscwRzdGltZQMxMjMwNDc0MTkw>
> | Members
> <http://groups.yahoo.com/group/Cal_Boats/members;_ylc=X3oDMTJmcjJoZjVzBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNtYnJzBHN0aW1lAzEyMzA0NzQxOTA->
> | Calendar
> <http://groups.yahoo.com/group/Cal_Boats/calendar;_ylc=X3oDMTJlZ2twNW9nBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNjYWwEc3RpbWUDMTIzMDQ3NDE5MA-->
> MARKETPLACE
> From kitchen basics to easy recipes - join the Group from Kraft Foods
> <http://us.ard.yahoo.com/SIG=13rqk4mpt/M=493064.12016295.13271503.10835568/D=groups/S=1705065792:MKP1/Y=YAHOO/EXP=1230481390/L=/B=AkmnXULaX9A-/J=1230474190886408/A=5530388/R=0/SIG=11nuutlas/*http://explore.yahoo.com/groups/kraftmealsmadesimple/>
> Yahoo! Groups
> <http://groups.yahoo.com/;_ylc=X3oDMTJlODlqdHNkBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNnZnAEc3RpbWUDMTIzMDQ3NDE5MA-->
> Change settings via the Web
> <http://groups.yahoo.com/group/Cal_Boats/join;_ylc=X3oDMTJnM2hpZDAyBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNzdG5ncwRzdGltZQMxMjMwNDc0MTkw>
> (Yahoo! ID required)
> Change settings via email: Switch delivery to Daily Digest
> <mailto:Ca… [at] yahoogroups.com?subject=Email%20Delivery:%20Digest>
> | Switch format to Traditional
> <mailto:Ca… [at] yahoogroups.com?subject=Change%20Delivery%20Format:%20Traditional>
> Visit Your Group
> <http://groups.yahoo.com/group/Cal_Boats;_ylc=X3oDMTJlZ3F2NmdzBF9TAzk3MzU5NzE0BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRzZWMDZnRyBHNsawNocGYEc3RpbWUDMTIzMDQ3NDE5MA-->
> | Yahoo! Groups Terms of Use <http://docs.yahoo.com/info/terms/> |
> Unsubscribe <mailto:Ca… [at] yahoogroups.com?subject=>
