17 messages2009-01-08 21:44 UTCthrough 2009-01-14 17:51 UTC
Asymetrical Cruising Spinnaker
Rogers, Christopher C.2009-01-08 21:44 UTC
Thinking about getting downwind sails for a Cal 2-29. I like the idea
of the asym chute, particularly when shorthanded.
since my budget requires I shop used, any idea on what size I should be
looking for? Any info/experience on rigigng a boat for this?
Happy New Year
Chris Rogers
Re: [Cal_Boats] Asymetrical Cruising Spinnaker (Chris)
Michael D2009-01-08 22:08 UTC
Chris,
According to thesailstore.com, the 2-29 uses off the shelf size 6,
* Luff Measurement: 38 feet
* Leech Measurement: 34.5 feet
* Foot Measurement: 20 feet
* Square Footage: 640 feetPerhaps you can use the above measurements while searching for a used asymmetrical headsail.
We bought a custom cut/sewn APC with a sock for Magic last year. Keep in mind that an A-sail will not go as deep as a full symmetrical, but at the same time you can reach with it when the symmetrical would be useless. All in all, we find the A-sail & spinnaker pole combo quite versatile. A friend has given me the end of an old whisker pole to rig as a bowsprit, but I haven't had time to get that done yet.
We only use the sock when my wife and I are out alone. For racing, we hoist from the bag on the foredeck. Right now, I use a snatch block on the bow for the tack line.
Michael
s/v Magic, Cal 2-27
Pompano Beach, FL
From: "Rogers, Christopher C." <ch… [at] jhuapl.edu>
Sent: Thursday, January 8, 2009 4:44:15 PM
Subject: [Cal_Boats] Asymetrical Cruising Spinnaker
Thinking about getting downwind sails for a Cal 2-29. I like the idea of the asym chute, particularly when shorthanded.
since my budget requires I shop used, any idea on what size I should be looking for? Any info/experience on rigigng a boat for this?
Happy New Year
Chris Rogers
RE: [Cal_Boats] Asymetrical Cruising Spinnaker (Chris)
Rogers, Christopher C.2009-01-08 22:12 UTC
Mike
Thanks for that input. I have an old whisker pole that might help pole
it out.
I have a rollerfurler Genoa to contend with, if that makes any
difference
You race PHRF with the Asym? Do they give you a time allowance for
that?
Chris Rogers
[mailto:Ca… [at] yahoogroups.com] On Behalf Of Michael D
Sent: Thursday, January 08, 2009 5:08 PM
Subject: Re: [Cal_Boats] Asymetrical Cruising Spinnaker (Chris)
Chris,
6,
Michael
s/v Magic, Cal 2-27
Pompano Beach, FL
Happy New Year
Chris Rogers
Michael D2009-01-09 15:48 UTC
Chris,
We sometimes use our spinnaker pole on the asymmetrical's tack; rigged just like a normal symmetrical spinnaker would be. That allows us to bring the pole back to windward and sail deeper than we normally can with the asymmetrical. For "real" windward/leeward buoy racing, I would only use a full symmetrical. The real advantage with the asymmetrical for us is on coastal races when the winds are right to fly it instead of the 155% genoa.
We also have a furled genoa on Magic. We have found that the best way to hoist the asymmetrical is raise it behind the genoa, then drop the genoa to the foredeck instead of trying to furl it on the headstay. Once the genoa is down, we secure it on the foredeck with elastic cords/clips.
We discovered that trying to furl the genoa with the asymmetrical up is too prone to getting it wrapped up in the furling. The reason for this is 1) the tack of the asymmetrcial needs to be further ahead of the forestay, and 2) I need a crane installed on the masthead to keep the spinnaker head/halyard a few more inches away from the forestay.
With our full symmetrical spinnaker, since its shoulders are so much bigger and flies further ahead of the forestay than the asymmetrical spinnaker does, it is not as prone to getting caught up in the furling.
YMMV,
Michael
Sent: Thursday, January 8, 2009 5:12:57 PM
Subject: RE: [Cal_Boats] Asymetrical Cruising Spinnaker (Chris)
Mike
that might help pole it out.
that makes any difference
time allowance for that?
Chris Rogers
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of Michael D
Chris,
According to thesailstore. com, the 2-29 uses off the shelf size 6,
Michael
s/v Magic, Cal 2-27
Pompano Beach, FL
From: "Rogers, Christopher C." <chris.rogers@ jhuapl.edu>
Happy New Year
Chris Rogers
Randy Alcorn2009-01-09 16:19 UTC
Hi Chris,
I race on boats with an AYSO. Most are sprit boats and jibing is easy, to say the least. It takes manpower to get the chute thru the triangle.
I also race on an Olson 30 with an AYSO Code 1. We use the spinnaker pole to get it out in front of the boat, when we Tack, we have to drop the chute, rerig the pole and pop the chute. So all intentions are to use this on the longest reaching legs.
The biggest problem is experiencing a wrap. It ruins your whole day or worse, night.
I sail Out Patient, single handed most of the time.I plan to add an AYSO to my CAL 2-29 . I will use a Facnor furler to roll it in and out. I have not considered adding a sprit. Most just use a tacker attached to the stem head.
I have had the fortune of starting up front with the Maxi fleet in the Newport to Ensenada Race. Seeing the big boats OEX, Taxi Dancer, Magnitude 80 and others positioning themselves for the start. They use furlers for their Code zeros and Code ones. When they jibe they roll them in and then roll them back out. Granted they may have as many as 10 people on deck to pull it off, it is amazingly coordinated. I hope I have a video camers this year to post what i am talking about.
Randy
CAL 2-29
Out Patient
Channel Islands Ca
Date: Thursday, January 8, 2009, 3:44 PM
Happy New Year
Chris Rogers
Re: Asymetrical Cruising Spinnaker
mtkennedy12009-01-10 23:05
--- In Ca… [at] yahoogroups.com, "Rogers, Christopher C."
There are several ways to do this. In reading about Peter Rebovich's
Bermuda wins with the Cal 40 I was struck by a comment that they used
asymmetrical spinnakers and tacked them to the bow. They did not use a
pole at all, if I read that right. I think the piece I saw was in
Scuttlebutt.
Mike Kennedy
Conquest Cal 40 # 96
> Happy New Year
> Chris Rogers
Downing, Thomas2009-01-12 14:26 UTC
I had an asym on my 2-27, which I sailed almost exclusively
single-hand. It was definitely worth it for longer downwind
legs. I flew and recovered it from a sock (ATN).
On long legs where I did not expect to gybe or tack I just
had one sheet attached. When expecting to gybe or tack,
there are two ways to rig the sheets: outside of the luff,
or between the luff and the forestay. The latter is a bit
tricker to work, but is much easier to single-hand overall.
You don't need to worry about running over the lazy sheet.
Timing is more critical as the leech is pulled through the
gap. I didn't experience wrapping problems with the asym,
unlike single-handing a symmetric! The lack of a broad
shoulder means that the top of the sail just twists off
to leeward as the clew is pulled through.
I used a 'tacker' around the furled genoa, and lead the
tack line aft so I could keep the upper half filled on
a run without leaving the cockpit. The tack line was turned
by a block fastened ahead of the furler, and just ran along
the deck - no blocks or fairleads at all. Not a good
idea if you need to go forward in rougher weather and
the line is on the high side. In that case I would get it
of the deck. I had an added crane on the mast head, the
block was about 3-4 inches ahead of the forestay.
From: Ca… [at] yahoogroups.com on behalf of Randy Alcorn
Sent: Fri 1/9/2009 11:19 AM
Hi Chris,
Randy
CAL 2-29
Out Patient
Channel Islands Ca
Happy New Year
Chris Rogers
DISCLAIMER:
dwilkieo2009-01-13 07:55
Randy and Thomas have described the delights and perils of running an
Asymmetrical with good detail, but I'll add some testimony. I bought
one with a sock and the ATN kevlar scoop and it works very well.
I tried a few single-handed gybes allowing the chute to stream forward
while feeding the sheet and lazy sheet around the outside of the
forestay and spin. Really a dicey thing with crew, and almost
impossible single-handed. I tried it a couple of times single-handed
and mangled it up pretty good. The last attempt, I managed to drag a
sheet under the fin and into the rudder post crevise. A real mess.
RE: [Cal_Boats] Re: Asymetrical Cruising Spinnaker
Downing, Thomas2009-01-13 13:14 UTC
That's a good write up. I agree that dowsing with the sock
for gybe is easy and not time consuming. Also, as I had
mentioned as well, gybing with the sheet between sail and
forestay is tricky. What I didn't say was that I could not
do it single hand if the wind was much above 20 knots.
On western LIS we don't see much above 15 knots during the
summer.
Still, the way that I did gybe when rigged this fashion is
partly dependent upon the fact that I had a tiller boat,
leaving both hands free: Straddle the tiller so you steer
with your knees. Haul the mainsheet home first. Here's the
trick I used. Take both sheets one hand, with the working
sheet tucked far back between thumb and hand in the hand on
the same side as the sheet; and the lazy sheet out at the
fingers. As you gybe, control the veer of the out-going
sheet while hauling the incoming (new working) sheet. Between
this and the gyrations of steering with your knees, you may
look like someone completely graceless attempting the hula
doing this, but hey, your single handed, who's to see?
The fact that the sheets are above the tack line will keep
the bow from running over them. Keeping a watching tension
on the out-going sheet will prevent it from taking charge
and going under the boat into the rudder. Timing is every
thing. Start hauling as soon as you can make any line, and
once the clew is through and the foot starts drawing, resist
the temptation to let it take anything. You will sill need
to keep hauling to ensure that the loop of sail ahead of the
boat does not twist or take charge. Don't try to gybe to
quickly.
I _really_ dislike going forward when single-handed in chop.
For the next installment - how to gybe a symmetric spin
single handed - followed by a bridge sale.
td
From: Ca… [at] yahoogroups.com on behalf of dwilkieo
Sent: Tue 1/13/2009 2:55 AM
Subject: [Cal_Boats] Re: Asymetrical Cruising Spinnaker
[snip]
Re: [Cal_Boats] Re: Asymmetrical Cruising Spinnaker
DavidOwen2009-01-13 17:41 UTC
Thomas
Thanks for your additional post. If you had been here to coach me, I would
have had a better experience trying to single hand the asym. But the only
appendage that I could control the wheel with and keep both hands free would
get pretty cold on that stainless wheel. I¹m talking about my knee, of
course.
You point out yet another reason that a tiller is superior to a wheel. I
really mean it. Mariposa¹s wheel is a source of angst for me and always has
been. Other than the ease of rigging a wheel-pilot, I prefer a tiller in
every way. I continue to threaten to convert her to a tiller, but always
get talked out of it.
Pulling the chute through that gap is definitely the way to go short-handed
or not.
In my post I forgot to mention that I abandoned my atn tacker (anybody want
it cheap?) because I race enough that I just can¹t make myself furl the
genoa before I hoist the chute. Even single-handed cruising I hoist the
chute and then drop or furl the genoa and the reverse prior to douse.
A very proficient sailor-buddy and I flew the full symmetrical chute
double-handed one day-sail. We did several gybes flawlessly and dropped it
at the last minute as we passed the head of the pier with a crowd watching
us. Felt pretty good. I can¹t imagine flying it solo....
Wilkie
> summer.
> quickly.
> td
> -----Original Message-----
> From: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com> on
> behalf of dwilkieo
> To: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>
> [snip]
> From that point on I would just douse the chute into the sock, gybe
> over and re-hoist on the new tack. Less time consuming than you might
> think.
> [snip]
> This inside-the-spinnaker outside the forestay gybe takes a crew to
> haul the lazy sheet and spin through that slot, and another crew
> (standing at the windward shrouds) to feed the newly innactive sheet
> forward so it doesn't drop into the water. With a crew to gybe the
> main and a crew to take up the trim on the new tack it works really
> well. The helmsman has to carve a smooth turn with an eye to
> blanketing the spin with the main until its been pulled far enough
> through that slot to continue as the gybe progresses.
> DISCLAIMER:
> from its systems.
Fred Haas2009-01-13 19:21 UTC
Wilke,
What's your definition of cheap? I sail Nemesis almost exclusively
single-handed, and would like to try one of those with my conventional
spinnakers.
Fred Haas
3-30 Nemesis
Tacoma
ol… [at] seatnet.com
> (anybody want it cheap?) because I race enough that I just can’t make
> myself furl the genoa before I hoist the chute. Even single-handed
> cruising I hoist the chute and then drop or furl the genoa — and the
> Messages | Files | Photos | Links | Database | Polls | Members
> | Calendar
> MARKETPLACE
> From kitchen basics to easy recipes - join the Group from Kraft Foods
> <ma_grp_160.gif>
> Change settings via the Web (Yahoo! ID required)
> Change settings via email: Switch delivery to Daily Digest | Switch
> format to Traditional
> Visit Your Group | Yahoo! Groups Terms of Use | Unsubscribe
> Recent Activity
> 5
> New Members
> 36
> New Photos
> 1
> New Links
> Visit Your Group
> Yahoo! News
> Fashion News
> What's the word on
> fashion and style?
> Yahoo! Finance
> It's Now Personal
> Guides, news,
> advice & more.
> Group Charity
> Loans that
> change lives
> Kiva.org
> <serv.gif>
DavidOwen2009-01-13 21:33 UTC
For a Cal buddy, pretty cheap. But I have to find it first. I thought it
was in the garage but not so. Gee, may have loaned it out or already given
it away in which case I apologize.
Wilkie
On 1/13/09 11:21 AM, "Fred Haas" <ol… [at] seanet.com> wrote:
> Wilke,
> spinnakers.
> Fred Haas
> 3-30 Nemesis
> Tacoma
>> it cheap?) because I race enough that I just can¹t make myself furl the genoa
>> before I hoist the chute. Even single-handed cruising I hoist the chute and
>> Messages | Files | Photos | Links | Database | Polls | Members |
>> Calendar
>> MARKETPLACE
>> <ma_grp_160.gif>
>> Change settings via email: Switch delivery to Daily Digest | Switch format
>> to Traditional
>> Recent Activity
>> 5
>> New Members
>> 36
>> New Photos
>> 1
>> New Links
>> Visit Your Group
>> Yahoo! News
>> Fashion News
>> What's the word on
>> fashion and style?
>> Yahoo! Finance
>> It's Now Personal
>> Guides, news,
>> advice & more.
>> Group Charity
>> Loans that
>> change lives
>> Kiva.org
>> <serv.gif>
DavidOwen2009-01-13 21:48 UTC
Fred,
Can¹t find the darn thing in the garage, which would be step #1. Then I
remembered talk of loaning it to another Cal buddy, but apparently that
never happened either. So...
First I have to find it then decide if I owe it to anyone else. Sorry for
the confusion. I¹ll update later.
Wilkie
> Wilke,
> spinnakers.
> Fred Haas
> 3-30 Nemesis
> Tacoma
>> Calendar
>> MARKETPLACE
>> <ma_grp_160.gif>
>> to Traditional
>> Recent Activity
>> 5
>> New Members
>> 36
>> New Photos
>> 1
>> New Links
>> Visit Your Group
>> Yahoo! News
>> Fashion News
>> What's the word on
>> fashion and style?
>> Yahoo! Finance
>> It's Now Personal
>> Guides, news,
>> advice & more.
>> Group Charity
>> Loans that
>> change lives
>> Kiva.org
>> <serv.gif>
Fred Haas2009-01-14 00:55 UTC
"of all the things I've lost, I miss my mind the most." Standing by in
Tacoma...
Fred
On Jan 13, 2009, at 1:48 PM, DavidOwen wrote:
> Fred,
> Can’t find the darn thing in the garage, which would be step #1.
> Then I remembered talk of loaning it to another Cal buddy, but
> apparently that never happened either. So...
> Sorry for the confusion. I’ll update later.
> Wilkie
Re: [Cal_Boats] Re: Asymetrical Cruising Spinnaker(Mike K)
david dobbs2009-01-14 03:47 UTC
Mike,
I raced the Chgo-Mac race last year in the cruising division on a Newport 30. We had 2 cruising asyms, tacked to the headstay chainplate. It was my observation that until the wind moved well aft that we did as well or better with the 150 genoa. No science, just my opinion. Not shared by the captain, 'course he bought them for the race,
Regards,
David Dobbs
Date: Saturday, January 10, 2009, 5:05 PM
--- In Cal_Boats@yahoogrou ps.com, "Rogers, Christopher C."
Scuttlebutt.
Mike Kennedy
> Happy New Year
> Chris Rogers
RE: [Cal_Boats] Re: Asymetrical Cruising Spinnaker(Mike K)
Downing, Thomas2009-01-14 13:26 UTC
I'd agree with that. Although you _can_ sail upwind keeping the
asym full if you pull the tack down hard, I would not choose to
go that way. On the 2-27, the 150 did better till the wind was
well abaft the beam. The exception to that rule was in very
light air, when the 150 was just too heavy. Then the asym was
better (I think) even with the wind as much as 10 degrees before.
But when racing in very light air, I think it would be better
to switch to a light genoa or other appropriate sail.
td
From: Ca… [at] yahoogroups.com on behalf of david dobbs
Sent: Tue 1/13/2009 10:47 PM
Subject: Re: [Cal_Boats] Re: Asymetrical Cruising Spinnaker(Mike K)
Mike,
Regards,
David Dobbs
Scuttlebutt.
Mike Kennedy
> Happy New Year
> Chris Rogers
DavidOwen2009-01-14 17:51 UTC
Ain¹t it the truth, brother.......
Wilkie
> Tacoma...
> Fred
>> Fred,
>> remembered talk of loaning it to another Cal buddy, but apparently that never
>> Wilkie
