8 messages2009-01-13 02:34 through 2009-01-15 15:26 UTC
Cal 28 lower shroud loose
Kevin2009-01-13 02:34
While beating to windward on either tack, the inner (ie lower) leeward
shroud on my 1969 Cal 28 is very slack, although the outer remains
tight. The rigger says the inners are tight enough (when in the marina)
and doesn't recommend making them any tighter. A Cal 2-27 neighbour has
exactly the same issue.
Should they be tightened, anything specific to be checked, any
suggestions, or do they all do that?
Thanks
Kevin
Re: Cal 28 lower shroud loose
Bruce Stirling2009-01-13 02:42
I am no expert, but if you look at the Cal 28 manual posted on my
site, I believe it states the shrouds are to be somewhat lose. Here
is the link; see page 6:
http://www.stirlinglaw.com/calboats/cal28.pdf
- Show quoted text -
> Thanks
> Kevin
Bruce Stirling2009-01-13 02:44
"loose"
leeward
marina)
neighbour has
> > Thanks
> > Kevin
RE: [Cal_Boats] Cal 28 lower shroud loose
Husar, Charlie [USA]2009-01-13 03:04 UTC
I don't think it's an issue, Kevin. The 28 and the 25 have similar
geometry of sticks, I believe. I know some 25s who swear by leaving the
lowers loose even at rest. Just check to see if the mast is in column
under load on a tack, and if it is, just make sure your turnbuckles are
not turning when the shroud is loose (either pins or nuts on the ends -
my technique). I assume you get the looseness on both tacks? Mast may
be sagging over a bit (in column). It takes very little for shrouds to
be loose or tight. You will see it does not take many turns on the
buckle to go from loose to tight.
Hope some of this makes sense.
Annapolis
Behalf Of Kevin
Sent: Monday, January 12, 2009 9:34 PM
Subject: [Cal_Boats] Cal 28 lower shroud loose
Thanks
Kevin
Yahoo! Groups Links
RE: [Cal_Boats] Re: Cal 28 lower shroud loose
r good2009-01-13 11:38 UTC
Wish I could find a manual like this for the Cal Cruising 36, or perhaps even the Cal Cruising 35. it would be interesting to see what theysay about mast tuning.
To: Ca… [at] yahoogroups.comFrom: br… [at] stirlinglaw.comDate: Tue, 13 Jan 2009 02:44:13 +0000Subject: [Cal_Boats] Re: Cal 28 lower shroud loose
"loose"--- In Ca… [at] yahoogroups.com, "Bruce Stirling" <bruce@...> wrote:>> I am no expert, but if you look at the Cal 28 manual posted on my> site, I believe it states the shrouds are to be somewhat lose. Here> is the link; see page 6:> > http://www.stirlinglaw.com/calboats/cal28.pdf> - Show quoted text -> > --- In Ca… [at] yahoogroups.com, "Kevin" <svbillied@> wrote:> >> > While beating to windward on either tack, the inner (ie lower)leeward > > shroud on my 1969 Cal 28 is very slack, although the outer remains > > tight. The rigger says the inners are tight enough (when in themarina) > > and doesn't recommend making them any tighter. A Cal 2-27neighbour has > > exactly the same issue. > > Should they be tightened, anything specific to be checked, any > > suggestions, or do they all do that?> > Thanks> > Kevin> >>
Bruce Stirling2009-01-13 14:56
Here are a few more manuals.\:
http://www.ewmanchester.com/CalSailboats.html
> Reggie
> To: Cal_Boats@...: bruce@...: Tue, 13 Jan 2009 02:44:13
> "loose"--- In Ca… [at] yahoogroups.com, "Bruce Stirling" <bruce@>
Husar, Charlie [USA]2009-01-13 18:57 UTC
Reg, on a CC36 in Florida, if the mast does not fall down at the dock,
and the icemaker works, the shrouds are fine.
Behalf Of r good
Sent: Tuesday, January 13, 2009 6:38 AM
To: ca… [at] yahoogroups.com
Subject: RE: [Cal_Boats] Re: Cal 28 lower shroud loose
about mast tuning.
"loose"
--- In Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com> ,
<http://www.stirlinglaw.com/calboats/cal28.pdf>
leeward
marina)
neighbour has
> > Thanks
> > Kevin
Re: [Cal_Boats] Re: Cal 28 lower shroud loose
Chris Campbell2009-01-15 15:26 UTC
I'm catching up on e-mails but I went to the manual link and they state
that the mast should not hook to windward. If the lowers are too loose,
relative to the uppers, that's what's going to happen. They state a
preference for the masthead falling off slightly to leeward. It's the
relative tightness of uppers and lowers that affects this more than
absolute tension.
The manual also warns about "bar tight" rigs. Most of our old boats
were not built to the engineering standards that allow modern racers to
do lots of sail-shape things with the standing rigging. It might be
worth checking the structural integrity of your mast step/chainplate
portions to make sure you're not getting excessive motion when the rig
is under stress.
