2 messages2009-01-18 19:15 UTCthrough 2009-01-19 13:42 UTC
Re:Asymetrical Cruising Spinnaker
Alfred Poor2009-01-18 19:15 UTC
Chris, I've been mostly lurking due to workload and travel, but came across
your question.
On our Cal 29, we took a symmetrical spinnaker and just attached one clew to
a line run through a snatchblock mounted on the pulpit, and flew it as if it
were asymmetrical. We probably couldn't point as high as if it were the
proper cut, but from beam reach and further off the wind, it worked great.
It might be a good think to try first before sinking money into an asym
sail.
We ended up getting a 170 headsail out of very light material - a drifter -
and used that instead as it was much easier to manage since it was on the
roller furler. (I'd recommend a sock for the chute if you go that route.)
And with our dual track furler foil, we were able to run up the standard 150
genny with it, and drop the main, for an effortless "wing-and-wing" rig for
dead downwind that is easier and probably more effective than any spinnaker,
at least in light winds.
Alfred
RE: [Cal_Boats] Re:Asymetrical Cruising Spinnaker
Rogers, Christopher C.2009-01-19 13:42 UTC
Thanks for the insight there.
I've hears several foks metion that rigging a s7ymmetrical chute htis
way is a pretty goos "poor man's asym"..
[mailto:Ca… [at] yahoogroups.com] On Behalf Of Alfred Poor
Sent: Sunday, January 18, 2009 2:15 PM
Subject: [Cal_Boats] Re:Asymetrical Cruising Spinnaker
came across your question.
one clew to a line run through a snatchblock mounted on the pulpit, and
flew it as if it were asymmetrical. We probably couldn't point as high
as if it were the proper cut, but from beam reach and further off the
wind, it worked great. It might be a good think to try first before
sinking money into an asym sail.
a drifter - and used that instead as it was much easier to manage since
it was on the roller furler. (I'd recommend a sock for the chute if you
go that route.) And with our dual track furler foil, we were able to run
up the standard 150 genny with it, and drop the main, for an effortless
"wing-and-wing" rig for dead downwind that is easier and probably more
effective than any spinnaker, at least in light winds.
Alfred
