Outboards, oil ratio, Evinrudes...(CH)
1 messages2009-02-23 01:46 UTCthrough 2009-02-23 01:46 UTC
Gerald Sobel2009-02-23 01:46 UTC
--- On Sun, 2/22/09, JB <ca… [at] southslope.net> wrote: From: JB <ca… [at] southslope.net> Subject: Re: [Cal_Boats]Sea skiffs, Indy structural Evinrudes...(CH) To: Ca… [at] yahoogroups.com Date: Sunday, February 22, 2009, 5:21 PM JB wrote: Greetings Sailors, Something I read a long time ago that is not intuitively obvious. The more oil you put in the mixture the leaner the engine runs. So more oil means hotter engine. Not the desired result. Probably best to follow the manufacturers recommendations as closely as possible. JB, Not necessarily does leaner means hotter, sometimes means cooler. I recall from my time in navy there is a certain optimal ratio where there is neither excess air nor excess fuel, where the engine runs really hot. Excess air may mean it runs cooler. So, regards using a 50:1 vs. 100:1 that Suzuki recommends, I'm not sure. Probably best to consult Suzuki. Meanwhile my mechanic didn't think it was a lack of oil that made my Evinrude 6 blow it's bearings, but then I'm not sure then why it happened. Poor engineering? And...Small outboards are notoriously de-tuned, aren't they?...compared to 2 cycle motorcycles which put out easily twice or thrice as much HP per CC. On the other hand, the motorcycle engines rarely are running at full load and max. RPM. One factor in my outboards demise may be that the motor had been sitting unused on the back of a boat for 15 years..not untypical in Marina del Rey. My mechanic put it up for sale when it's owner refused to pay the repair bill for the overhaul. However I did get a good two years of service from the engine, but it was frequently in the shop, possibly cause I didn't run the carb dry each time after using it, like I do now, it got gunked up frequently. Uggh! Jerry Cal 21 #152 JK Flip Flop ..._/)... Gerald Sobel wrote: > > I > > --- On *Fri, 2/20/09, Gerald Sobel /<sobel_solar@ yahoo.com>/* wrote: > > > From: Gerald Sobel <sobel_solar@ yahoo.com> > Subject: [Cal_Boats] Indy structural Evinrudes... not, waz CAL-20 > outboard(CH) > To: Cal_Boats@yahoogrou ps.com > Date: Friday, February 20, 2009, 2:57 PM > > Indestructable Evinrude..of the 70's and 80's? > Not so, I slopped a slug of oil from the plastic bottle in my gas > in a rush to get the Cal 24 out and to a starting line, and while > running full throttle down the main channel to the breakwater the > engine puttered and died....froze- up!. The bearings were toast, > my mechanic said and it would cost more than the motor was worth > to fix it. > > Ah Ha, now, regarding the fabled Evinrudes, don't get me wrong... > the 1960 Golden Anniversary Evinrude outboard...that' s > another...uh. .outboard. In my garage is my Dad's (he didn't like > the word Pop...) 51/2 HP Envinrude Fisherman. That motor took > us...the whole family... deep sea fishing out of marinas up and > down the coast of New Jersey, on rented wooden skiffs of all > sorts, and never missed a beat. I had it restored a few years > ago...uh..ten years ago, but since it's a short shaft I've never > gotten to use it. > But thar it is, already to go on another expedition for > flounder...or. .halibut as they call them giant man eating flounder > on the west coast. The motor has mixture controls and a > pressurization system, dual fuel lines, and the tank has a built > in priming bulb. Pretty cool. > > Speaking of skiffs, there's a company that makes a plastic replica > of that same wooden skiff out of planks of PVC , glued together. > Goes for a pretty penny too. I wonder if they have simulated > wooden floor grates to keep your feet dry from the leaking seams, > and rusty coffee cans (real full size 16 oz. ones) to do the deed. > > I remeber how fun it was, but thinking how much I wish I we had a > sailboat. > Jerry > > Moral of story, know what amount of oil is in a 'slug of oil'. I > burned up the bearings, and the big six hp sailmaster was history. > > My Suzuki is 100:1 but I usually use at least 50:1 to be safe; but > it's nice to have the hundred to one cushion. And I carefully > measure using the guage on the side of the bottle. > Jerry > PS> And don't wait till the engine dies/freezes up before you > change out your impeller. I thru a blade and it blocked the water > intake. Froze the engine/or overheated and died, but the suZuki > God smiled on my chagrin and gave me another chance. The motor was > ok. Also luckily I wasn't going full throttle, but I admit I did > give it more gas as the motor bogged down. Yuk! > > --- On *Fri, 2/20/09, Chris h /<chris123@magma. ca>/* wrote: > > > From: Chris h <chris123@magma. ca> > Subject: Re: [Cal_Boats] CAL-20 outboard > To: Cal_Boats@yahoogrou ps.com > Date: Friday, February 20, 2009, 8:40 AM > > On Friday 20 February 2009 09:13:12 Chris Campbell wrote: > > > I use the well for aesthetic reasons--there' s no outboard > hanging on the > > transom. Using a bracket is more efficient because there's > no drag for > > the outboard that gets used rarely. > > In our case its different. While you can sail off the mooring > most days, the > water is thin and the wind is typically in the wrong > direction. Mooring field > is very tight. So we mostly motor off. Same on re-entry where > the winds have > changed most evenings and your under bare poles, single handed > trying to > catch that mooring ring. Always exciting as per your point > below. Club house > is on the water and the dingy racers are always eyeballing the > " keel > boaters" and vis versa. So a motor is a requirement. > > > I made a > > new baffle to fit my motor out of truck mudflap rubber with > some angle > > aluminum at the edges to stiffen it on the periphery. It's > held down by > > a piece of fiberglass batten stock, about 1-2" or 5-8" wide, > tucked > > under a little block for that purpose at the top of the well. > > I like that idea. > > > My motor is an old 6 hp Evinrude long shaft because that's > what was > > available on the used market when I needed one. > > Those 60-70's evinrude's are indestructable. Had one on my > last boat. Once > they are tuned, bullet proof. Went with the boat however. > > > The long shaft is > > probably overkill. > > For the well yes, for the transom, no. > > > My boat is moored in front > > of a busy restaurant and the local yacht club, so dumb moves > are visible). > > LOL....yup. Put mine on the rocks in a funcky wind trying to > sail onto the > mooring. Thats the nice part about the swing keel on the CS22. > Start the > motor, relax, who cares who's watching, set everything up, > pull on the keel > light cord, smile politely and bring her around..:) > > > There's a piece of 2x6 built into the starboard seat locker > for securing > > the OB down there if you don't want to leave it deployed. > That was a > > nice touch if you're racing, but then you've got a smelly, > drippy OB > > sitting in an enclosed space, emitting gas fumes. > > No...not a good idea at all. I think I will start with the > well and if doesnt > work out then move to the transom and reinforce it from the > inside. But thats > work and that's why I got this boat. I have a project boat and > want to go > sailing this summer. > > Thanks for your comments. Much appreciated. Nice photo shot as > well. > > -- > /ch > >
