9 messages2009-02-17 21:20 through 2009-02-23 03:46
just bought 1977 Cal 27- help with a leak
bsauls9252009-02-17 21:20
Hi all,
I recently bought my first boat. A Cal 27 built in 1977. Now I will
undertake the task of getting the boat back into shape. On my list is
fixing a leak at the cabin top, around the mast. I noticed a leak on
the wall and traced it to the area by the door to the head/v berth.
There are some wood plugs that seem to hide the screws securing a
cover where the leak seems to originate, I was thinking of drilling a
small hole in them and using a small screw to see if I could remove
them. Has anyone had a similar leak and solution? It seems as if the
water comes down the wiring. Would a mast boot work or is that just a
temproary repair? I also noticed a product at West Marine, Spartite
that seems like it would help but I don't want to cover up a core
problem if the leak has been an issue for a while. Thank you in
advance for your advice!
Bryan Saulsbury
RE: [Cal_Boats] just bought 1977 Cal 27- help with a leak
r good2009-02-17 22:37 UTC
a hole is drilled through the deck and mast step through which the wires pass. that hole plus possibly the bolts/screws holding down the mast step plate are common leak sites.
Recommendation?
unstep mast and re-bed mast step plate. While it is down, inspect all standing rigging. Dye test all swages. inspect all wiring and replace anywhich is corroded. Check out lights and antennas. Replace bulbs while it is down. When re-stepping incorproate a drip loop in the wiring and a drain hole at base of mast. Inspect sheaves at masthead.
Date: Tue, 17 Feb 2009 21:20:47 +0000
Subject: [Cal_Boats] just bought 1977 Cal 27- help with a leak
Hi all,
Bryan Saulsbury
Re: just bought 1977 Cal 27- help with a leak
Dave Leasia2009-02-18 05:48
Bryan,
You didn't mention the model of Cal 27.
I have a '72 pop-top, and had the same problem. Once I got up the
nerve, I unstepped the mast, removed the step plate and removed all
the wiring (antenna and mast lighting). I cleaned out the wiring hole
and used copious amounts of Git-Rot to harden the wood around the hole
(through the deck), and let it set. I then pulled new wiring (extra
wire for masthead, anchor, running light, spreader light, new VHF)up
through the hole using a pull wire attached to the old wiring (I
pulled down- I did not remove the wooden wiring channel) up thru the
deck). I pulled extra through, and squeezed lots of 3M 4200 back into
the hole and SLIGHTLY pulled an inch of the bundle back down. Once
that set, I smeared additional sealant into the hole, and smeared
plenty of sealant on the bottom of the step plate, after feeding the
wiring bundle through the hole in the plate. I re-screwed the plate in
position, not quite tight until the sealant had set-up. Once
everything had cured, I tightened the plate to the deck, verifying the
plate matched the original outline of the gelcoat. I trimmed the
excess sealant, and I added more sealant around the wire bundle exit
above the plate before stepping the mast. I haven't had a leak in 4 years.
If the screw holes are worn or rotted, I suggest filling with
Git-Rot or another epoxy compound, and let set before reseating the
plate. I installed a new VHF connector and a multi-pin connector
(Mil-spec) on the coax and wiring harness (above deck), and added new
matching connectors on the mast wiring. The new wiring was re-run in
the hull to the fuse block(s) and VHF radio. If you replace the
wiring, I recommend using the largest (RG8x) coax that will fit.
At this time, I also re-ran the wiring in the mast to match...
I hope this helps some.
Regards,
Dave Leasia
s/v Candy Cane
1972 Cal 27 pop-top
Grosse Pointe Farms, MI
(CSYC)
--- In Ca… [at] yahoogroups.com, "bsauls925" <bsauls925@...> wrote:
> Hi all,
> Bryan Saulsbury
RE: [Cal_Boats] Re: just bought 1977 Cal 27- help with a leak
Husar, Charlie [USA]2009-02-18 06:01 UTC
As someone else mentioned, put a few mouse holes (at least one) at the
base of the mast for drainage. I have been drilling holes near the base
of the mast and bringing the wiring out to external holes in the deck.
I hate to have a hole in the deck I cannot inspect (like one inside the
mast step).
Annapolis
Behalf Of Dave Leasia
Sent: Wednesday, February 18, 2009 12:48 AM
Subject: [Cal_Boats] Re: just bought 1977 Cal 27- help with a leak
Bryan,
nerve, I unstepped the mast, removed the step plate and removed all the
wiring (antenna and mast lighting). I cleaned out the wiring hole and
(through the deck), and let it set. I then pulled new wiring (extra wire
for masthead, anchor, running light, spreader light, new VHF)up through
the hole using a pull wire attached to the old wiring (I pulled down- I
did not remove the wooden wiring channel) up thru the deck). I pulled
extra through, and squeezed lots of 3M 4200 back into the hole and
SLIGHTLY pulled an inch of the bundle back down. Once that set, I
smeared additional sealant into the hole, and smeared plenty of sealant
on the bottom of the step plate, after feeding the wiring bundle through
the hole in the plate. I re-screwed the plate in position, not quite
tight until the sealant had set-up. Once everything had cured, I
tightened the plate to the deck, verifying the plate matched the
original outline of the gelcoat. I trimmed the excess sealant, and I
added more sealant around the wire bundle exit above the plate before
If the screw holes are worn or rotted, I suggest filling with Git-Rot
or another epoxy compound, and let set before reseating the plate. I
matching connectors on the mast wiring. The new wiring was re-run in the
hull to the fuse block(s) and VHF radio. If you replace the wiring, I
Regards,
Dave Leasia
s/v Candy Cane
1972 Cal 27 pop-top
(CSYC)
> Hi all,
> Bryan Saulsbury
Yahoo! Groups Links
Re: [Cal_Boats] Re: Mast wiring(Dave L)
david dobbs2009-02-18 16:01 UTC
Dave,
I would be interested in how many pins your connector has and where you got it. That job has been on my list for a couple of years.
David Dobbs
--- On Tue, 2/17/09, Dave Leasia <te… [at] yahoo.com> wrote:
> From: Dave Leasia <te… [at] yahoo.com>
> Date: Tuesday, February 17, 2009, 11:48 PM
> Bryan,
> got up the
> removed all
> wiring hole
> around the hole
> wiring (extra
> new VHF)up
> wiring (I
> thru the
> back into
> down. Once
> smeared
> feeding the
> the plate in
> Once
> verifying the
> trimmed the
> bundle exit
> a leak in 4 years.
> with
> reseating the
> connector
> added new
> re-run in
> the
> fit.
> match...
> Regards,
> Dave Leasia
> s/v Candy Cane
> 1972 Cal 27 pop-top
> (CSYC)
> > Hi all,
> 1977. Now I will
> noticed a leak on
> head/v berth.
> securing a
> could remove
> seems as if the
> or is that just a
> Marine, Spartite
> cover up a core
> Thank you in
> > Bryan Saulsbury
r good2009-02-18 17:57 UTC
I also ran my wiring external for Charlie's reason plus being able to install a connector for removing the mast. However, a connector could also be installed inside the mast and disconnected while the mast is suspended over yoru hands,or you could just disconnect the wires inside the boat and pull them through each time you want to unstep the mast.
I've attached a photo
Date: Wed, 18 Feb 2009 01:01:17 -0500
Subject: RE: [Cal_Boats] Re: just bought 1977 Cal 27- help with a leak
mast step).
Annapolis
Bryan,
Regards,
Dave Leasia
s/v Candy Cane
1972 Cal 27 pop-top
(CSYC)
> Hi all,
> Bryan Saulsbury
Yahoo! Groups Links
Dave Leasia2009-02-19 01:13
David,
Funny you should ask! I just ran across the invoice for said
connectors. I purchased them from Mouser Electronics (www.mouser.com)
May of 2005. I should have also purchased the screw-on caps at the
same time. The connectors I bought are:
Amphenol 97-3101A-20-16S cable mount receptacle
Amphenol 97-3106B-20-16P cable mount straight plug
Amphenol 97-3057-1012-1 bushing
These have 7 #16 pins and 2 #12 pins. After soldering the wiring to
the connectors, I filled the back sides of both with silicone sealant
(3M) to prevent corrosion, and use dielectric grease on the exposed
pins/socket as well. I also rewired with Ancor 20 ga. marine wire for
the lighting (positive)feeds, and 12ga. marine wire for the return
(ground). I have a couple of spare pins in case I need them. Total
cost (then) was about $50 for all.
I will be ordering the caps for winter storage of the boat &
unstepped mast soon (currently I bag them).
I hope this helps...
Dave Leasia
'72 Cal 27 pop-top #145
s/v Candy Cane
Crescent Sail Yacht Club
Grosse Pointe Farms, MI.
--- In Ca… [at] yahoogroups.com, david dobbs <tmft567@...> wrote:
> Dave,
> Thanks,
> David Dobbs
Re: [Cal_Boats] Re: Detroit Cals
david dobbs2009-02-22 00:06 UTC
Dave,
Another funny thing, my 29 was originally owned by a guy named Sears from Detroit. He raced it for some years; sail number is 5443, a Detroit number. I will keep it as my sail number.
Dave Dobbs, Cal 29 411, s/n 5443
> Subject: [Cal_Boats] Re: Mast wiring(Dave L)
> Date: Wednesday, February 18, 2009, 7:13 PM
> David,
> (www.mouser.com)
> at the
> wiring to
> silicone sealant
> exposed
> marine wire for
> return
> them. Total
> Dave Leasia
> s/v Candy Cane
> > Dave,
> has and where
> years.
> > Thanks,
> > David Dobbs
Re: Detroit Cals
Dave Leasia2009-02-23 03:46
Dave,
It's not surprising your Cal was from the Motor City. Our club (CSYC)
alone has numerous Cal 20's, 25's, 3-27's, a 28, a 29, 2-30's 2-33's
and a 9.2 (our Commodore's boat, Jade).! Our annual Regatta has plenty
of 20 and 25 fleet entries from all around the Great Lakes.
We bought our 27 pop-top from the original owner, who used to race
MORC on Erie and St. Clair. We kept his boat name AND sail number
(15858). I'll check on your original owner...
Regards,
Telephone Dave
> Dave,
