2 messages2009-02-23 05:21 UTCthrough 2009-02-23 17:12 UTC
Re: [Cal_Boats] Outboards, oil ratio, Evinrudes...(CH)
Rodney G Johnson2009-02-23 05:21 UTC
I recall reading an article in an issue of SMALL BOAT JOURNAL back in the
1980's that reviewed the ESKA 5hp outboard, the powerhead was air-cooled,
but there was a waterpump to cool the exhaust flowing out down the drive
leg. The outboard ran on 50/1 fuel/oil mix, however if the waterpump
failed you needed to run using 25/1 fuel / oil ratio to keep the engine
cool. I would think that on any 2-stroke engine, up to a point it would
be better to use too much oil than too little. More oil should equal less
friction and thus cooler running.....as I say, up to a point!
Rod Johnson
On Sun, 22 Feb 2009 17:46:35 -0800 (PST) Gerald Sobel
<so… [at] yahoo.com> writes:
--- On Sun, 2/22/09, JB <ca… [at] southslope.net> wrote:
Subject: Re: [Cal_Boats]Sea skiffs, Indy structural Evinrudes...(CH)
Date: Sunday, February 22, 2009, 5:21 PM
JB wrote:
Greetings Sailors,
Something I read a long time ago that is not intuitively obvious. The
more oil you put in the mixture the leaner the engine runs. So more oil
means hotter engine. Not the desired result. Probably best to follow
the manufacturers recommendations as closely as possible.
JB,
Not necessarily does leaner means hotter, sometimes means cooler. I
recall from my time in navy there is a certain optimal ratio where there
is neither excess air nor excess fuel, where the engine runs really hot.
Excess air may mean it runs cooler. So, regards using a 50:1 vs. 100:1
that Suzuki recommends, I'm not sure. Probably best to consult Suzuki.
Meanwhile my mechanic didn't think it was a lack of oil that made my
Evinrude 6 blow it's bearings, but then I'm not sure then why it
happened. Poor engineering?
Find Business Careers here. The source for New Careers.
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTEKqdXvrfimoksOC6Gi8HLV5M5VNqAk99m7wZVSowgpA9j4QDhgRy/
Rodney G Johnson2009-02-23 17:12 UTC
Rod Johnson
JB wrote:
Greetings Sailors,
JB,
$1.99 each for 4 movies & free shipping when you join!
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTNC6eVKV4jFptmEP0cKPFgiiOtus7FgZdGjwxkZwNykP9tvKgV5Fn/
